Old 11-05-2019, 02:58 PM #1
Quiero Quiero is offline
Quiero is on a distinguished road
V6 noisy at high RPM. Exhaust manifold leak?
My truck has 160k miles on it and it began to tick loudly at higher RPMs. I dont think its valvetrain noise as its silent at idle. At higher RPMs though its very noticeable.
Oil level is good (mobil 1 full synth changed per the manual since it was new).
Is this a common problem on these vehicles?
Quiero is offline   Reply With QuoteReply With Quote
Old 11-05-2019, 04:13 PM #2
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
good luck OP, you could be onto something there...
just curious typical higher rpms some of you reach? i cant seem to shift mine much past 2k rpms...i prob just baby the thing but was curious what some of you touch with your RPMS?
hinmo24t is offline   Reply With QuoteReply With Quote
Old 11-05-2019, 05:30 PM #3
rwelch53 rwelch53 is offline
Real Name: Ryan
rwelch53 is on a distinguished road
Real Name: Ryan
In normal driving I generally don't get any over 2300 or so, but when passing on the highway I've revved it up towards 4000 and it makes a hell of a racket LOL. Cruises at 2000rpm at 80mph all day long and pretty damn quiet in my opinion.
rwelch53 is offline   Reply With QuoteReply With Quote
Old 11-05-2019, 05:42 PM #4
mar5168 mar5168 is offline
mar5168 is on a distinguished road
Check your y pipe. Very common to leak there and typically sounds mostly normal at low load/RPMs, but gets louder with loud and higher RPMs
mar5168 is offline   Reply With QuoteReply With Quote
Old 11-05-2019, 06:40 PM #5
MikeinNH67's Avatar
MikeinNH67's Avatar
My V6 had a leak at the manifold to cylinder-head gasket. Also leaked at different flanges but the manifold one was elusive. What I did was connect my air compressor to a male coupler which I threaded into a hole I drilled in a paint can cover. I cut a slit in the cover and clamped it on to my tailpipe then put 15 to 20 pounds of pressure on it. I could hear and feel all the leaks seeing the engine was off so no noise.
As for the revving up conversation, I've wondered the same as it doesn't seem to like to rev and it gets loud. My Honda V6 loves to rev which makes it kinda fun even though it's a van. Guess the 4runner is setup more truck like.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 11-05-2019, 06:42 PM #6
Real Name: Ryan
Real Name: Ryan
As a recovering 90's Honda fanboy, VTEC BABY!
Old 11-07-2019, 03:59 PM #7
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
A tech who claimed to be a "master mechanic" from my local Toyota dealership told me the ticking I hear from my v6 is normal injector noise and has nothing to do with the exhaust system. He also said that is not necessarily an indication of impending injector failure, and that some injectors are just louder than others. He doesn't know why, but this guy seemed credible and pretty smart. One day, I'll probably test this theory by deactivating the fuel injectors one at a time.
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 04:23 PM #8
Interesting feedback, thanks. I'll check the y pipe. That could be it, or the injectors. I've never heard another vehicle that really replicates this, so that could be it.
Old 11-07-2019, 06:20 PM #9
Mantilgh Mantilgh is offline
Mantilgh will become famous soon enough
The exhaust manifolds are known to crack. Most likely from the cat hanging off the long manifold pipe. I think the bracket that connects to trans brakes first then the weight is on the upper manifold.
My V6 is beyond cracked and is fully broken. FTW
Open the hood in the dark and look at the manifolds, you may be able to see it.
Mantilgh is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 06:22 PM #10
DBL Post
Old 11-07-2019, 06:41 PM #11
MikeinNH67's Avatar
MikeinNH67's Avatar
Another way that may help show it's exhaust is a quick blip of the throttle. If you hear exhaust popping sounds as the RPM drops then you have a leak. My truck failed inspection for it, sounded ok to me at idle but I had that manifold leak. I could smell the fumes under the hood though.
Mike
03 4runner Limited
Old 11-08-2019, 08:53 AM #12
UrbanRunner651's Avatar
UrbanRunner651 UrbanRunner651 is offline
Real Name: Newell
UrbanRunner651 will become famous soon enough
Real Name: Newell
The ticking is somewhat normal but it will be amplified if you have a crack in one of your headers. Take it to an exhaust shop and they will typically do a free inspection.
The OEM headers are just cheap double-wall steel that rusts out especially if you live north of the rust belt where they see a lot of salt/snow.
My 08 had a bad tick that you could hear at idle, but I could also see a physical crack in one of the manifold welds since it was a custom header put in before I bought it. Obviously the OEM one had an issue or they wouldn't have replaced it. I ended up dropping in some stainless JBA shorties and custom Y-pipe.
UrbanRunner651 is offline   Reply With QuoteReply With Quote
Old 12-12-2020, 11:21 PM #13
DaveCS4RnnR DaveCS4RnnR is offline
DaveCS4RnnR is on a distinguished road
I have a 5th Gen, and I've been noticing abnormal sounds out of mine, perhaps some of you could help diagnosing.
Google Drive: Sign-in
2011 Toyota 4runner LTD
2000 Toyota 4runner LTD
2011 Toyota Corolla
DaveCS4RnnR is offline   Reply With QuoteReply With Quote
Old 12-12-2020, 11:59 PM #14
Warwicke36's Avatar
Warwicke36 Warwicke36 is offline
Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough
Warwicke36's Avatar
If you think it's an exhaust leak have someone hold a rag over the tailpipe as you look for the noise. Noise should increase as you add more back pressure with the rag.
The injectors are pretty loud on these trucks, but I sure can't hear mine from inside the cabin. Outside the truck I do hear mine ticking away. Injector noise obviously won't increase with the above mentioned rag procedure.
2004 Sport 4.0
Warwicke36 is offline   Reply With QuoteReply With Quote
higher , noticeable , oil , rpms , synth
Exhaust manifold leak/tick hamiltonj2w1 4th Gen T4Rs 269 11-25-2020 07:42 PM
Before you rule in your tick as an exhaust manifold leak run4lander 4th Gen T4Rs 13 12-23-2018 08:36 PM
Oil Leak on Exhaust Manifold stever1000 3rd gen T4Rs 2 10-29-2017 01:31 PM
Exhaust Manifold leak. Explict 4th Gen T4Rs 15 09-12-2016 09:21 PM
exhaust leak after manifold replacement Fleethammer 4th Gen T4Rs 5 04-27-2014 09:22 PM
