11-22-2019, 04:10 AM
#16
Originally Posted by phatcheeks
I have these as well. They are pretty beefy. Got them on sale for like 140 a while back. They bolt into existing threaded locations.
How long was install? What size shackle can you fit?
11-22-2019, 10:44 AM
#17
Originally Posted by AuSeeker
I like the 150 series one much better.
Just not feeling these recovery points that are using the radiator support frame no matter what is said. I feel much better with something that is mounted to the main frame of the truck.
SOLD2007 4Runner Sport Edition V6 4X4 - Natural White - Perf: Doug Thorley Long Tube Headers | 4.56 Gears ARB Front / TrueTrac Rear Off Road: Fr: Bilstein 6112 w/1/2" Toytec Spacer / Rr: MT ICON Long Travel | JBA UCAs | VTX Rogue 17x8.5 -10 | GY Duratrac 285/70R17 | Rear Diff Breather Mod | 1" Toytec Body Lift | Custom Cut Axle Joints ICE: Auto Pumpkin 10.1" Android | 3.5" Tweeter Mod Exterior: Quad Bi-Xenon HID Retrofit
2019 4Runner Limited 4x4 - MGM - Hers | Ironman4x4 FCP's & UCA | Fuel Rebel 20x9+1 | GY Duratrac 275/60R20 | Victory 4x4 FLRR
11-22-2019, 11:49 AM
#18
Took about an hour. Uses a 3/4" shackle. As you can see by the pic, I ended up removing my front sway bar as well.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
11-22-2019, 02:07 PM
#19
Yes, I have 4th Gen 4Runner (2008). I was about to purchase that 120 series model, but then their customer support recommended me this Prado 150 series model since I am planning to get ARB bumper sometimes next year? From what I understand this model will also fit for 4th Gen 4runner.
But you are right, that BBG-RP120 model is better for 4th Gen 4runner and also cheaper ..
- GL
11-22-2019, 07:11 PM
#20
Real Name: Skip
Real Name: Skip
I agree that the ones for the Prado 150 look to be much better as it looks to have 3 mounting points...BUT the tow weight rating is lower for the 150 than it is for the Prado 120 with only 2 mounting points, for the 150 it states and it's also stamped on the pieces..."Rated to a Working Weight Limit (WWL) of 3250Kg per tow point"...but for the 120 it states and also stamped on the pieces..."Rated to a Working Weight Limit (WWL) of 5000 Kg per tow point"....which is 1750Kg more per tow point than the 150 for a total of 3500Kg if using both tow points!!!
2004 Limited V8
11-23-2019, 09:39 AM
#21
I'm installing the Apex Overland recovery points this weekend.
Sent from my SM-G965U using Tapatalk
11-23-2019, 02:03 PM
#22
Easy peasy
11-23-2019, 03:42 PM
#23
Real Name: Carlos V.
Originally Posted by KrisB410
Easy peasy
Nice set up Kris. Kind of what I want for my 03 4R.
For the 120 series, I see 2 holes for the bolts on the external side of the frame of my 4R but only one in the internal.
Did you had to drill holes in the internal side to insert the bolts and attach nuts?
Can you please give more details of that first plate that protects the radiators?
Thanks K. I am new at this things
Gold 2003 4Runner SR5 V6 2WD A340E
Grabber A/T, Brembo rot, Akebono pads, Optima batt, HKB Volt. booster, Buffalo Bayou recovery
Sony XAV1000, LED interior and reverse, Weathertech, Flux-Turbocharged tire valve caps.
11-27-2019, 01:16 PM
#24
Skid plate is RCI
Engine Skid Plate | 03-09 4Runner / GX 470 – RCI Offroad
And
Bumper Filler Plate | 03-09 4Runner / GX 470 – RCI Offroad
Easiest install you will ever do.
These bolt on front recovery points are a 100% bolt on.
No cutting. No Drilling. No welding.
Designed to allow a bow shackle, soft shackle, and even winch hooks to pass through the main eyelet.
Bolting directly to the frame in 4 locations, these recovery points are a much safer option for rigging than the factory tie down loop, which should never be used for towing or recovery of a stuck vehicle.
Allows the factory sway bar to still be used.
A single mount bolt with this recovery point has the sheer strength of just over 20,000 lbs. This recovery point is secured by 4 bolts in total. AKA, super strong and rated for more than most recovery straps and ropes.
Side braces are MIG welded to the main body and the whole assembly is painted safely red for a long lasting and easily identifiable recovery point.
All necessary Grade 8.8 Hardware is included with each set of recovery points.
Here are the instructions for installing
Recovery Point Installation Instruction
11-27-2019, 09:38 PM
#25
Thanks a lot Kris. Is the info I needed
12-09-2019, 07:15 AM
#26
Real Name: Richard
Real Name: Richard
Very cool- Good information. Thanks guys!
12-24-2019, 03:11 PM
#27
I may have to weld front rebar to front frame adapter, just in case 4 studs that hold rebar to frame let go. Pretty happy with how it looks though
Sent from my Redmi 4 using Tapatalk
12-26-2019, 07:08 AM
#28
Apex Overland offer great recovery point, but it's tucked too high for my taste, ARB offer a rated recovery point of 8000KG and it's car specific with Left Or Right side, sold per point, too expensive, I like the Treaty Oak recovery point, it comes with class 10.9 hardware.
12-26-2019, 07:59 AM
#29
Real Name: Skip
Real Name: Skip
It appears that Treaty Oaks doesn't offer recovery points for 4th Gens, so doesn't do us in the 4th Gen forum section any good, maybe post this in the 5th Gen forum since they do make them for the 5th Gens.
2004 Limited V8
12-28-2019, 05:18 PM
#30
Registered User
Registered User
I like this. Where did you attach it?
