04-22-2020, 11:04 AM
#31
I don't recommend Vivid Racing. You can look at their reviews and see a lot that says they don't update you on your parts without you contacting them, this is 100% true.
It was 2 weeks before any contact was made after ordering, which I had to initiate. Another 2 weeks went by after initial contact, saying they would update me, no word back. After a month, I finally hear something, in which they ask me to pay more $$ for shipping to get it to me in the next 3-4 days from Australia. I defer and they offer to cover it (mind you this is a month after ordering). Never received tracking number [they put a signature on everything fyi] until it I got a letter on my door from FedEx saying I had missed a delivery (surprise!).
Pretty much everything that is covered in reviews, sadly happen with me as well. Ignore the nice site, order elsewhere. In the end, they stepped up and did the right thing but this has clearly been going on for awhile based on their reviews.
2007 Limited 4WD V6 | Shadow Mica | 290K
04-22-2020, 11:25 AM
#32
Real Name: Ron
Real Name: Ron
Originally Posted by RivMan
Thanks, guys.
I originally ordered from Vivid Racing, and they contacted me to let me now that they're out of stock and weeks out of Australia, so I canceled that order.
I contacted Apache, and initially they said they were out of stock. He called me back about 10 minutes later and told me that there is one set left in stock.
So far great customer service from Apache Offroad!
-Rob
Please keep us posted. Thanks.
04-26-2020, 11:43 PM
#33
They showed up yesterday!
I haven’t opened them up yet, may not actually need them.
I had a PPI done on my new 4Runner (bought site unseen from Montana) and the mechanic identified the LCA bushings as blown out. When the truck showed up, I found the “blown bushing” seems to be a loose bolt. I’ll be ripping it apart soon to confirm, but I may be selling these.
-Rob
05-01-2020, 05:22 PM
#34
Installed the SuperPro’s last night.
Extremely impressed. The inner sleeve is captured, but not bonded to the poly. With the alignment cams torqued, the arms swing freely. Everything fit great, and so far I’m very impressed with the quality.
I installed these with JBA UCA’s.
I requested ~4.2 degrees of caster and slight negative camber. They got it just right! All 4 alignment cams are almost centered. Tons of adjustment in any direction.
-Rob
2006 Sport V8 4x4 4Runner | Mods: ARB Front Bumper | Warn XD9000 Winch | Custom Sliders | ECGS 4.56 Gears | Eaton Truetrac rear | JBA UCA | SuperPro LCA | Icon 2.5 Front Coilovers | MetalTech Icon 2.0 Long Travel Rear Shocks | Dobinsons Long Travel Rear Springs | Energy Suspension Front Bumps | Durobump Rear Bumps | Falken WildPeak 285/70/17 | SCS F5 wheels | Custom Roof Rack | Gobi Ladder | OrangeBoxx Molle Panels | Icom IC-2730a HAM Radio | Rigid Ditch Lights | Custom Rear Drawers | 23Zero Walkabout 62 | ARB Awning | Dual Battery System | CVJ Axles | Victory 4x4 Rear Bumper with Dual Swingouts | Front Runner Table
05-01-2020, 05:52 PM
#35
That's really good to hear. With them being able to move freely up and down without any bushing resistance like the stock ones, the truck "should" ride better up front with those.
Do you feel like it changed the ride at all?
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
05-01-2020, 06:00 PM
#36
I honestly couldn’t say. I’ve only owned the truck a week, ~100 miles before swapping. Before I swapped them the alignment was trash too.
I can say that the truck rides great now though.
-Rob
05-01-2020, 06:23 PM
#37
Real Name: Ron
Real Name: Ron
I ordered the SuperPro bushing kit for my LCA's and now have them. Will install soon. Reason being just what rivman says, frees up the LCA movement as it should be.
06-11-2020, 05:41 PM
#38
Thanks for sharing these! Been searching options for awhile.
Just ordered the standard replacement Superpros from Apache Offroad as they are a little cheaper than the adjustable ones. I now have JBA UCAs on the way so caster will not be an issue with my 2.5 inch lift.
Was about to have my LCAs rebuilt with poly bushings but this will be about the same cost or less than paying my mechanic hourly to rebuild my old crusty ones. I like that these have beefier cam bolts and are built for offroad use.
2004 SR5 V8, 275/70/16 KO2's, Eibach Pro Lift, JBA UCA, SuperPro LCA, DT Headers.
06-11-2020, 05:55 PM
#39
Real Name: Ron
Real Name: Ron
The bushing kit requires different cam bolts?
06-11-2020, 06:50 PM
#40
I bought the full lower control arms not the bushing kit.
07-08-2020, 01:29 PM
#41
After a few months with them, how do you like the SuperPros?
Leaning towards buying a pair.
07-08-2020, 05:19 PM
#42
-Rob
What made you go with ~4.2 degrees of caster and slight negative camber?
07-09-2020, 11:34 AM
#43
At least in the drifting world if you have a slight negative camber when the wheels are pointed straight ahead then at full lock the tire will be “flat” with the ground. Although normally you’d see -1.5 or “less” degrees of camber to actually make a difference.
07-09-2020, 01:36 PM
#44
Thank you.
How are you liking the SuperPros thus far?
12-22-2020, 07:50 PM
#45
I'm installing the Superpro double offset LCA right now. I got them in fine however, I'm having clearance issues with the outboard CVboot clamp. I'm using a worm drive clamp and at full drop (when on jack stands) the worm drive housing hits the lower control arm. I think when compressed it will be ok but I'd hate to be wheeling and at full drop break off my clamp and have my boot come lose.
anyone have this issue? You think an alignment will fix this or do i need to get the OEM clamp which is probably not as tall?
Not my pic or actual pic. Just a pic I found online for illustration purposes. I'll take a pic of my rig later.
2003 4Runner Limited 4wd V8. JBA UCA, Dobinsons MRA Front Coilovers, Dobinsons MRA Long Travel rear. Cooper AT3 XLT 285/70R17
91 Ext Cab 4x4 Yota, black with 4" front IFS trailmaster lift, 3" Downey rear springs, Downey Rubicon extended shackles, and 2" body lift. 35" BFG M/T w/ 4.56. Centerforce II clutch, Rancho 5000s all around and Rancho traction bar, K&N Air filter, Flowmaster, ARB Rear Diff Air Locker, Custom "Mad Eyes" light covers, Extended Diff Breathers, Hella Vision Plus Headlights. [SOLD]
