11-06-2019, 10:58 AM
SuperPro LCA
Any opinions on these? Tried doing some searching but could only come up results for the bushings themselves which everyone seemed to agree that SuperPro was a good manufacturer.
I know the golden rule around here is "OEM or go home" but thought these seemed like a viable option.
TRC482 SuperPro Control Arm Kit
11-06-2019, 12:23 PM
Real Name: Elliott
Real Name: Elliott
Interesting.... They claim that these arms will correct CASTER, not sure how you'd do that with a lca. From what I've seen, caster correcting arms are uppers, not lowers. Not necessarily calling bs, but definitely peaked my curiosity. If they aren't an arm and a leg, may be worth trying if you're in the market....(and then I looked them up) $600 for the pair!? Well, OEM are about $330 a side depending on where you buy them. That's pretty close in price, and I can't find any reviews doing a quick search. I'd want customer feedback first before straying away from oem
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
11-06-2019, 12:32 PM
So they do offer 2 different ones, one that is supposed to be for factory vehicles (TRC481 and then those for lifted ones, I did opt for the lifted set (TRC482).
I did order a set, just awaiting the shipping information. Was hoping I wouldn't be the guinea pig for this product but looks like there isn't too many people with this product currently.
Will definitely grab some pics as soon as I get them in to compare!
2007 Limited 4WD V6 | Shadow Mica | 290K
11-06-2019, 12:35 PM
Real Name: Michael
Real Name: Michael
You can do it with lowers as well.
https://www.youtube.com/watch?v=f2YhnldfI50&feature=youtu.be&t=1
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
11-06-2019, 12:42 PM
Real Name: Elliott
Real Name: Elliott
Can't wait to hear feedback. I know a lot of us could use more caster
Real Name: Elliott
Real Name: Elliott
Originally Posted by That_Titanium_4RNR
I stand corrected. Thank you
11-06-2019, 01:55 PM
Real Name: Michael
Real Name: Michael
No worries!
12-04-2019, 06:29 PM
12-04-2019, 11:27 PM
Real Name: Elliott
Real Name: Elliott
Right on! Let us know how it goes, and what your alignment specs are afterward.
12-05-2019, 01:26 AM
Following.
12-05-2019, 12:20 PM
How much you pay for these? I've seen them range for 750-800. Close to OEM but these bushings look a lot more durable.
I ordered a set of mevotech supreme LCAs. Hopefully they hold up long enough for me to swap out the bushings on my oem ones.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
12-06-2019, 05:15 PM
I was able to get these for $600 from an online retailer (I'd rather not name them since their service was the worst I've dealt with).
The bushings alone make me feel great about going with these, but like you said, only time will tell. There doesn't appear to be too many of these out there (based on reviews and Googling), at least in the U.S.
12-06-2019, 05:24 PM
Real Name: Michael
Real Name: Michael
The one thing that would worry me with them is the noise and vibration from these bushings. They may be tougher yes, but will they sacrifice ride quality and noise?
12-06-2019, 05:49 PM
That is a great question! I don't think I will be able to give a precise answer on that unfortunately. My vehicle does have 285k miles with the original LCA bushings, yikes! While I do have 5100s up front, my E-rated Ko2's certainly give a firmer ride already but if I get any type of "softness" after the change tonight, I will definitely let you know!
Plan on doing these this evening and hopefully get in on an alignment tomorrow.
12-06-2019, 08:56 PM
I was looking into these as well. Can't wait to hear your results.
