Old 12-22-2020, 08:52 PM #46
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
Originally Posted by joshik View Post
I'm installing the Superpro double offset LCA right now. I got them in fine however, I'm having clearance issues with the outboard CVboot clamp. I'm using a worm drive clamp and at full drop (when on jack stands) the worm drive housing hits the lower control arm. I think when compressed it will be ok but I'd hate to be wheeling and at full drop break off my clamp and have my boot come lose.
anyone have this issue? You think an alignment will fix this or do i need to get the OEM clamp which is probably not as tall?
Not my pic or actual pic. Just a pic I found online for illustration purposes. I'll take a pic of my rig later.
Either rotate the clamp and tighten it where it won't make contact with anything (probably facing front or rear), or use a thinner OEM type clamp.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 12-22-2020, 08:54 PM #47
joshik joshik is offline
joshik will become famous soon enough
Ok upon further inspection, it seems that the LCA that were sent to me are SLIGHTLY different than my stock LCAs.
My stock LCA is stamped with "L7" and "R7" right where the lower ball joint attaches to the LCA.
The new Superpro ones are stamped with "L6" and "R6" and upon comparing them closely, the raised section where the lower ball joint attaches is taller on my OEM one compared to the Superpro one. I'll post pics later.
Good thing my old LCA wasnt frozen and I didn't cut it off. I'll just have to reinstall it and reachout to Superpro.
2003 4Runner Limited 4wd V8. JBA UCA, Dobinsons MRA Front Coilovers, Dobinsons MRA Long Travel rear. Cooper AT3 XLT 285/70R17
91 Ext Cab 4x4 Yota, black with 4" front IFS trailmaster lift, 3" Downey rear springs, Downey Rubicon extended shackles, and 2" body lift. 35" BFG M/T w/ 4.56. Centerforce II clutch, Rancho 5000s all around and Rancho traction bar, K&N Air filter, Flowmaster, ARB Rear Diff Air Locker, Custom "Mad Eyes" light covers, Extended Diff Breathers, Hella Vision Plus Headlights. [SOLD]
joshik is offline   Reply With QuoteReply With Quote
Old 12-22-2020, 09:40 PM #48
yeh, i was going to install the OEM clamps as I have a set laying around. However, I think it will still be close as there is still a "hump" protruding from the OEM clamp. Also, at full droop, the boot gets AWFUL close to the LCA.
Also, my previous post about the LCA differences concern me (R6,L6 vs R7,L7).
Old 12-22-2020, 11:26 PM #49
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
Originally Posted by phatcheeks View Post
How much you pay for these? I've seen them range for 750-800. Close to OEM but these bushings look a lot more durable.
I ordered a set of mevotech supreme LCAs. Hopefully they hold up long enough for me to swap out the bushings on my oem ones.
One of my mevotech cheapies from rock auto already tore a boot. They work fine, and have a lifetime warranty, but rockauto won't just send a new boot! They said send the whole thing back and they'll give me a new one. Crazy, right? I chose to just spend $6 on a replacement boot and I'll eventually get it on there. Technically, they say no guarantee on lifted or modified vehicles so no worries.
gaber6 is offline   Reply With QuoteReply With Quote
Old 10-02-2022, 06:14 AM #50
Hitmanhink Hitmanhink is offline
Hitmanhink is on a distinguished road
@Wozzy @RivMan @rdruss @Silver Stallion @joshik You guys still liking these LCA’s?
Silver 05’ 4Runner V8 4.7L Sport, Bilstein 5100 shocks, Dobinsons C59-314B front springs, Dobinsons Aluminum Billet UCA’s, Superpro offset LCA’s, OCD sway bar endlinks, Toytec Superflex RCC2.0-P rear springs, Cooper Discoverer A/T 3 285/70/17 tires, SCS Blaze 10 Wheels with -10mm offset, and lots of plans for future mods…
Hitmanhink is offline   Reply With QuoteReply With Quote
Old 10-02-2022, 10:13 AM #51
Silver Stallion's Avatar
Silver Stallion Silver Stallion is offline
Silver Stallion is on a distinguished road
Mine have been great, no issues on or offroad. The Poly bushing are also quiet, no squeeking.
2004 SR5 V8, 275/70/16 KO2's, Eibach Pro Lift, JBA UCA, SuperPro LCA, DT Headers.
Silver Stallion is offline   Reply With QuoteReply With Quote
Old 10-02-2022, 03:54 PM #52
@joshik did you ever get this resolved with Superpro?
Old 10-02-2022, 08:56 PM #53
Yep, I shipped back the LCA and just rebuilt my OEM ones with new OEM bushings and a balljoint kit.
Old 10-03-2022, 11:34 AM #54
Cool thanks for the update! We’re you able to figure out what was wrong, did they just sent you the wrong ones? Or was it really that bad of a fit? Thanks for your feedback!
Old 10-03-2022, 12:27 PM #55
I think they just have one model. Not sure what the issue was. If you look at the arms carefully you can see the difference from the OEM arms but also taking measurements with calipers, angle finders, etc. the measurements are not the same dimensionally.
I would not have noticed initially but after I installed the arms I checking out my outboard CV boot and noticed that the clamp hit the lower arm. This is at extreme full droop of course so when driving it would have been ok. But when wheeling... could have hit especially when at full flex or a tire off the ground.
One thing to note is that I am not using OEM CV clamps but stainless wormdrive clamps which are ever so slightly taller (at the clamp part) than OEM. However, I never had clearance issues with my OEM lower arms.
I really wanted it to work out because I liked their eccentric bolt design... but oh well.
Old 10-03-2022, 01:15 PM #56
… after I installed the arms I checking out my outboard CV boot and noticed that the clamp hit the lower arm. This is at extreme full droop of course so when driving it would have been ok. But when wheeling... could have hit especially when at full flex or a tire off the ground.
Thanks for the feedback I’m a rookie I’m just trying to understand.. would it still have hit if you rotated the clamp? Or was there some reason you didn’t want to rotate the clamp?
Old 10-05-2022, 02:16 PM #57
RivMan's Avatar
RivMan RivMan is offline
RivMan has a spectacular aura about RivMan has a spectacular aura about
RivMan's Avatar
Mine are ok, but one of the LCA bushings have failed after ~40k hard miles. I'm working with SuperPro on a warranty replacement.
Thank you
-Rob
2006 Sport V8 4x4 4Runner | Mods: ARB Front Bumper | Warn XD9000 Winch | Custom Sliders | ECGS 4.56 Gears | Eaton Truetrac rear | JBA UCA | SuperPro LCA | Icon 2.5 Front Coilovers | MetalTech Icon 2.0 Long Travel Rear Shocks | Dobinsons Long Travel Rear Springs | Energy Suspension Front Bumps | Durobump Rear Bumps | Falken WildPeak 285/70/17 | SCS F5 wheels | Custom Roof Rack | Gobi Ladder | OrangeBoxx Molle Panels | Icom IC-2730a HAM Radio | Rigid Ditch Lights | Custom Rear Drawers | 23Zero Walkabout 62 | ARB Awning | Dual Battery System | CVJ Axles | Victory 4x4 Rear Bumper with Dual Swingouts | Front Runner Table
RivMan is offline   Reply With QuoteReply With Quote
Old 10-05-2022, 10:08 PM #58
Thank you
-Rob
Great to know 👍🏼 Keep us up to date on how this goes if they honor the warranty or not.
I’m in the market right now to replace my LCAs and some of the things mentioned here and in other chats have me on the fence which route to go. Granted 40k miles is a heck of a lot better than some aftermarket bushings which I’m hearing that some are failing after only 7k miles… yikes! I will say the switch out of a bushing on a Superpro LCA seems much more user friendly than an OEM LCA bushing. Thanks for the feedback @RivMan
Old 10-12-2022, 10:07 AM #59
smc08i smc08i is offline
smc08i is on a distinguished road
Following
smc08i is offline   Reply With QuoteReply With Quote
Old 10-12-2022, 10:45 PM #60
OopsIBrokeIt OopsIBrokeIt is offline
OopsIBrokeIt will become famous soon enough
That particular clamp rotates all on its own.
OopsIBrokeIt is offline   Reply With QuoteReply With Quote
good , manufacturer , option , rule , superpro
