03-16-2023, 12:22 AM
#76
Originally Posted by Hitmanhink
I found this all a bit interesting! At first I was a little disappointed, most people lifting their trucks to off-road rave about getting extra caster, that’s another topic I’m not going to get too much into here. But how many people are actually wanting to get more “caster” just from their LCA’s? From what I gather - most everyone does that with their UCA’s, so I’m not sure the true advantage here of getting extra “caster” from your LCA’s - but maybe it’s just a clever marketing tactic because in comparison to the 3 to 4 degrees you can get with adjustable UCA’s like JBA or SPC, 0.4 deg with these LCA’s is not very much if your chasing after extra “caster”. But what I’ve concluded so far is that what you ARE getting, if you buy these, is some very well built beefy LCA’s with some very cool poly bushings (hopefully they don’t squeak). And yes they have “some” extra adjustment. I’ll follow with an update again, once I do the install. Maybe some of the other experts here can correct me if I mentioned anything off-base, inaccurate, or if I’m missing something important?
I recall reading here on 4Runner forums that caster gain with the LCA rotates the spindle such that the lower ball joint mount moves forward, making the wheel further away from the firewall (where we normally have interference with the body mount).
The UCA does the opposite, moving the tire rearward, closer to the trouble area.
I'd have to assume that due to the geometry, 0.4 degrees was all that can be attained without affecting other aspects of the suspension.
2005 V8 Limited
Bilstein 6112/5160, ADDCO bars. 18x9 Beast with 285/60R18 BFGs
IPT valve body, DT shorty headers, Dirty Deeds BAMF exhaust
03-16-2023, 10:07 AM
#77
Real Name: Ron
Real Name: Ron
Makes no sense to me to use the LCA for caster as it is "cocked" in position then and seems odd to operate it "cocked". I installed a cam eliminator kit and run it in the center position front/rear on LCA. Have an SPC UCA that I can adjust for caster/camber. I run stock sized tires and wheels and don't off road so probably a little unique in that respect.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
03-22-2023, 08:57 AM
#78
I'm pretty set on getting a pair of the offset arms from SuperPro at this point, I am just nervous about install because their instructions seem very vague. How difficult was the install and how would I ensure my cams are close enough to get it to an alignment shop?
Also, once at the alignment shop (even if I take it to an offroad/high performance specialty shop), will they know how to use the adjustability of the arms that the bushing provides?
Maybe I'm not thinking about it right. If anyone could quell my nerves that would be sweet.
TIA
2007 Sport Edition 4.0 V6 4WD - Dobinsons IMS, JBA HD UCA, SuperPro Double Offset LCA, Sony DSX-GS900 Head Unit, Alpine Type-S 12" Subwoofer, JBL GTR-601 Amplifier
03-22-2023, 10:04 AM
#79
Real Name: Ron
Real Name: Ron
Measure your toe and camber BEFORE you install the SP LCA, it's easy to do.
Mark your LCA cam positions with paint pen or whatever. Install the SP LCAs and set your cams back where they were. Check your toe and camber, should be close to what they were. How much caster is SP LCA supposed to provide with no other changes? Don't worry about your caster and take it for a ride. how does it feel, does steering wheel return to straight after a turn with little effort, does it wander on highway or feel as it did before? If satisfied, don't worry about caster, IMO.
I installed SPC UCAs and have never taken to have it aligned. I checked and adjusted my toe and camber, had a two year old alignment sheet that told me what caster was and set the SPC one position positive, oh, and I installed a cam delete kit in LCAs and set all at center position, drives very well.
03-22-2023, 01:00 PM
#80
Which orientation is the bushing supposed to be in, given that its asymmetrical or "offset" as they call it? It seems to me like it either pushes the LCA out towards the wheel or pulls it in towards the truck, depending on which direction it is "offset" to. Does it come already in the configuration that you'd want for a lifted application (2.5" or so)? This is really the only thing left that I am unsure of.
03-22-2023, 08:59 PM
#81
Real Name: Todd
Real Name: Todd
This is how they should come, out of the box. These were mine when I did the install. Be sure to remove the blue cup from the balljoint before installing. It's only a protective cover for shipping.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
04-20-2023, 02:45 PM
#82
Finally installing these this weekend. Did anyone grease the bushings before installing these?
04-20-2023, 05:46 PM
#83
Real Name: Todd
Real Name: Todd
Not the blue bushings themselves. Per the included (should have been at least) instructions, use anti-seize on the bolts that go thru the sleeves. You can and might need to use some grease (bearing grease or something of the like) on the outside of the bushings, just to help the LCAs slide into the buckets.
04-20-2023, 06:25 PM
#84
I used Mobil XHP 222 grease.
reviews of the grease: Mobilgrease XHP 222 Special grease 13.7 oz. Cartridge
2005 4runner 4.7L v8 - Kings, Icon 52700, SPC UCA, SS brake lines, Duratrac, Odyssey, DCPower Alternator, FN Pro wheels, etc...
2015 Tacoma - Similar stuff,
2012 Tacoma - Also similar stuff...
04-25-2023, 11:20 AM
#85
New sig
That install was brutal on my 16 year old New England truck. Took all of Saturday, Sunday, and Monday. Couldn't resist a quick joyride with all my new hardware despite not being professionally aligned yet. I have to say, these things are the real deal! Quiet, responsive, and tight. Alignment appointment today so we will see what numbers I can get!
Thanks everyone for the help. Finally some suspension mods to tout!
05-30-2023, 11:18 AM
#86
New sig
Any update on alignment numbers?
06 V8 SR5 --Kings--JBAs--RCI armor--Lil B's--33s--Wheel and Party--
05-31-2023, 08:14 AM
#87
I will post a picture of my alignment sheet after work. My suspension has settled a bit since and I will be doing wheels and tires sometime in June so I'll likely get it aligned again at that point for good measure, but I was able to get great numbers even with a regular "chain" alignment shop. (all I could get for a next day appointment)
05-31-2023, 03:55 PM
#88
Looking forward to seeing what you came up with. About to pull the trigger on these. Not sure if I want to go with the offset ones or regular. I think I’m leaning towards regular because I haven’t had issues getting the alignment I want (usually shoot for 3.5-3.7 caster with jba ucas) worried if I get the offsets then I’ll have too much caster?
05-31-2023, 07:33 PM
#89
I was also worried about having too much caster. I pulled the trigger on the double offset ones and couldn't be happier. I also have JBA uppers, love those too. Likely you'd be able to get the same numbers with the standard LCAs but I don't know for sure. I do know that the SuperPro lowers give you a lot more adjustment room because you're not "maxed out" for lack of a better term.
Here's my alignment sheet, I asked for "between 3 and 4 degrees of caster":
05-31-2023, 08:02 PM
#90
Perfect! I guess double offset it is! Thanks for verifying that for me!
