Old 11-06-2019, 12:17 PM #1
jscott6's Avatar
jscott6 jscott6 is offline
Real Name: Scott
jscott6 is on a distinguished road
jscott6's Avatar
Real Name: Scott
4L and differential lock use question
I drive in 4H several times a month to keep it functioning. My question is, can I switch to 4L and lock the differential and just go straight, back and forth in my driveway to keep it functional, or do I need to drive while in 4L/diff lock? And if I need to drive around in 4L/diff lock, how miles many would be sufficient? I drive it in 4L/diff lock on dirt roads only, once or twice month. It is starting to take much longer getting out of diff lock when in 4L and I would like to work it more often.
jscott6 is offline   Reply With QuoteReply With Quote
Old 11-06-2019, 12:34 PM #2
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
I wouldn't suggest locking the center diff on anything other than say, grass, dirt, mud, snow, sand, etc. I also wouldn't drive around very far in 4LO either, just find a grass or dirt field and put it in 4HI and lock/unlock the center diff a few times along the way. Then try putting it in 4LO and lock/unlock center diff a few times while driving it a short distance. I have found it helps engage the center diff better when in a soft ground surface such as sand etc. Puts less strain on everything too 4x4 on a flat surface can be harmful and puts a lot of undue stress on components.
Also if your center diff takes awhile I have found that putting it into drive or reverse from neutral with the brakes still lightly applied helps. Sometimes it just needs that last little bump into gear to help it fully engage.
Hope that all makes sense
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 11-06-2019, 01:05 PM #3
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
I usually try to get mine in dirt once a month. With fires lately, that's a challenge in southern California. In a pinch, I'll cycle everything back and forth a couple times in the garage, then drive around a few miles in 4 hi unlocked. I think the issue is more in actuators freezing than actually turning gears. Haven't had any issues in that department and it's been a regular practice for me since I bought mine
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 11-06-2019, 02:12 PM #4
techno's Avatar
techno techno is offline
techno is a jewel in the rough techno is a jewel in the rough techno is a jewel in the rough
techno's Avatar
Also, you don't need to be in 4L to lock the center diff. It works in 4H too. You're ok gong back and forth a few feet in your paved driveway with it locked, just try not to turn at all to avoid driveline bindup.
I cycle all the actuators every now again without actually moving.
techno is offline   Reply With QuoteReply With Quote
Old 11-06-2019, 08:50 PM #5
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
There are times I can’t get away from the concrete to do my exercising… I switch into 4H unlocked pretty often just for kicks, totally fine to drive around in it. Ill do the same for 4L unlocked in residential areas. Ill lock / unlock a few times in a straight line. Typically not a problem at all until you start applying some steering input.
I know its not ideal, but I think its still better than not doing it at all.
Old 11-06-2019, 09:19 PM #6
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
For what it's worth, I drive in 4H with the center diff locked on a stretch of straight paved road at least once/month if I'm not able to use the system in the woods/dirt/snow/mud.
Never had an issue or experienced any binding, it should be fine as long as you're not making any turns. And the CDL activates within seconds of pushing the button, every time - much quicker than when I first started doing it routinely.
eleven14 is offline   Reply With QuoteReply With Quote
4l/diff , differential , drive , lock , month
08 4R AWD? differential lock? SavinWillyWonka 4th Gen T4Rs 16 03-18-2015 12:13 AM
Rear differential lock Reverenddude 3rd gen T4Rs 5 02-23-2014 03:42 AM
Do I Really Need the Differential Lock? -help GVL 3rd gen T4Rs 43 02-17-2014 10:49 PM
differential Lock runnerfreak 4th Gen T4Rs 4 10-23-2007 09:59 AM
when do u use DAC and differential lock? 4runnerman 4th Gen T4Rs 2 10-28-2004 11:11 PM
