Old 11-08-2019, 11:31 AM #1
hinmo24t hinmo24t is offline
hinmo24t has a spectacular aura about hinmo24t has a spectacular aura about
decisions decisions, air compressor garage vs portable
thinking of getting an air compressor for my garage, or something to tote around when i go offroad. i have a full size spare and hilift and wheel often times just 10 mins from my house, making me lean the tank/garage route. do the air compressors like bostitch or porta cable deal with deflating tires efficient or is it best to get some separate devices for that? i have a BJs wholesale with free air close to me too that ive used to air up and down, but thinking the garage setup would be nice. not looking to go air tools in future, probably get into cordless impacts instead.
thanks for suggestions
hinmo24t is offline   Reply With QuoteReply With Quote
Old 11-08-2019, 12:13 PM #2
TodiN's Avatar
TodiN TodiN is offline
Real Name: Todi
TodiN is on a distinguished road
TodiN's Avatar
Real Name: Todi
Hehehe, both if you can afford it.
2018 TRD OR
- SSO Full Rack
- FJ TRD Pro Kit with: Front - 1.25" Lift Poly Front Coil Preload Spacer Kit (DAY TA3273), Rear - Eibach E30-82-071-01-02; M.O.R.E. aluminum skid plates; RCI front filler skid plate
- Pedal Commander; ARB diff breather; on-board Smittybilt 2781 Compressor
TodiN is offline   Reply With QuoteReply With Quote
Old 11-08-2019, 01:18 PM #3
good point considering the portables ones can be had for like $30
Old 11-08-2019, 03:49 PM #4
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo is just really nice Bumbo is just really nice Bumbo is just really nice Bumbo is just really nice Bumbo is just really nice
Bumbo's Avatar
I would say both...
I use portables primarily for tire fill. I have a Viair 400P and a 88P, both live in different vehicles.
In the garage I have a basic 20 gallon compressor which I use for air tools, tire fill, and just compressed air for dusting things off which tends to be surprisingly useful depending on what you do. I plumbed my garage and have the compressor in a closet, and have a retractable reel which makes use very convenient. Itís usually always pressurized as well.
Old 11-08-2019, 04:10 PM #5
Originally Posted by Bumbo View Post
I would say both...
thanks for the insight...
Old 11-08-2019, 10:16 PM #6
AuSeeker AuSeeker is offline
Real Name: Skip
AuSeeker is a glorious beacon of light AuSeeker is a glorious beacon of light AuSeeker is a glorious beacon of light AuSeeker is a glorious beacon of light AuSeeker is a glorious beacon of light AuSeeker is a glorious beacon of light
Real Name: Skip
Just an FYI for a garage compressor I would get a compressor with the highest CFMs (air flow is rated in Cubic Feet per Minute)and largest tank you can afford, I know you say you're not considering air tools in your garage BUT there are many air tools beside impacts that will be very useful when working on your T4R or any other vehicle, air chisel for cutting bolt loosening rusted parts, etc., needle scaler for rust removal, die grinder for fine detailing/shaping metal parts, nail guns and staplers if you do some woodworking and there are many others as well, most of these use a lot of CFMs with the exception of the nail guns unless you shoot a lot of nails and a compressor with low CFMs will not keep up with using them effectively, also when using compressed air for blowing dirt and debris out of nooks, crannies, cracks and tight places the more CFMs you have the better for less wear and tear on the compressor or it will be running continuously and it will shorten it's life, the same it true with the aforementioned air tools.
I would say a compressor of no less than 6 CFMs but the more the merrier.
2004 Limited V8
Old 11-08-2019, 11:40 PM #7
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm is a name known to all Inv4drZm is a name known to all Inv4drZm is a name known to all Inv4drZm is a name known to all Inv4drZm is a name known to all Inv4drZm is a name known to all
MY GARAGE
Inv4drZm's Avatar
MY GARAGE
With everything I've done to my truck I've gotten by with electric power tools. Never had a compressor in my garage other than the ARB twin in my truck. Just bought a Makita die grinder, should be pretty slick.
2005 4R Sport 4WD "The last of the V8s!" - Dirty Deeds 20" SS Exhaust - Icon 2.5 Resi's. - 1.5" BL - SCS SR8's - 35's - Dana 60 - Build Thread
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 11-09-2019, 01:28 PM #8
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner will become famous soon enough
81runner's Avatar
Real Name: Elliott
As a compressor mechanic of 15 years, I would add to this, make sure if you buy a home unit, it's belt driven and oil lubricated. The direct drive units are JUNK. If it's an oil free unit, then it has an aluminum cylinder and a carbon piston ring. Can't handle much in the way of heat, and they fail pretty quickly. I have a 20 gal belt driven unit, 2hp from the 80s, rebuilt about 13 years ago. It puts out about 8 cfm, which is plenty for just about anything you'd ever plan to do in a garage. I have an MV 50 mounted in the runner, plumbed to a 2 gallon tank so I can charge it to 120 psi while I'm on the trail, and be fully inflated within 20 minutes.
2007 SR5 V6 4WD, Titanium Metallic. 5100s, FJ/OME springs, extended rear links, Cooper ST Maxx 255/75 R17, mud flap delete, throttle body spacer, Cold Air Intake, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, COB LED OEM replacement lights all over,12" light bar, rear bumper lights, cbi ditch light brackets w/lights, atrac off, on board air w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, Rigid Armor tire carrier, Sport Edition hood w/functional vent, Pedal Commander, JET MAF, Kenwood TM-V71a w/motorized antenna, dual battery, custom roof rack, external 12v hookup, dash mounted tablet, rear diff breather, custom stereo....for now....
81runner is offline   Reply With QuoteReply With Quote
Old 11-09-2019, 04:33 PM #9
Terminator03 Terminator03 is offline
Terminator03 has a spectacular aura about Terminator03 has a spectacular aura about Terminator03 has a spectacular aura about
Excellent points! Donít forget a sandblaster too... those use a lot of air!
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Terminator03 is offline   Reply With QuoteReply With Quote
air , compressor , decisions , garage , thinking
Blown motor what to do? decisions decisions Bean#310 Classic T4Rs 8 07-27-2018 10:30 AM
Recommend a Garage/non-portable Air Compressor IL_Fletch Off Topic 8 09-07-2017 04:15 PM
Decisions Decisions: Help with a P0420????? Jbot 3rd gen T4Rs 2 07-07-2015 12:49 AM
Get new motor? Yes/no? Decisions decisions! VA4runnerchic 3rd gen T4Rs 30 01-23-2012 12:29 PM
Instrument Cluster - Decisions, Decisions SQ.MD 5th gen T4Rs 21 03-21-2010 04:41 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
