Old 11-08-2019, 06:54 PM #1
46runner's Avatar
46runner 46runner is offline
46runner has a spectacular aura about 46runner has a spectacular aura about
46runner's Avatar
DIY: Spark plugs and ignition coils
I have 186K miles on my 4Runner (‘04 V8).
The spark plugss were last changed with the timing belt at 116K miles.
There were no issues but I decided to change the plugs after 70K miles. I ended up changing the ignition coils too.
I hope some will find this DIY helpful.
to be continued...
DIY: Spark plugs and ignition coils-slide1-jpeg  DIY: Spark plugs and ignition coils-slide2-jpg  DIY: Spark plugs and ignition coils-slide3-jpeg  DIY: Spark plugs and ignition coils-slide4-jpeg  DIY: Spark plugs and ignition coils-slide5-jpeg  DIY: Spark plugs and ignition coils-slide6-jpg  DIY: Spark plugs and ignition coils-slide7-jpg
46runner is offline   Reply With QuoteReply With Quote
Old 11-08-2019, 07:02 PM #2
46runner's Avatar
46runner's Avatar
continued...
DIY: Spark plugs and ignition coils-slide8-jpg  DIY: Spark plugs and ignition coils-slide9-jpg  DIY: Spark plugs and ignition coils-slide10-jpeg  DIY: Spark plugs and ignition coils-slide11-jpeg  DIY: Spark plugs and ignition coils-slide12-jpg  DIY: Spark plugs and ignition coils-slide13-jpeg  DIY: Spark plugs and ignition coils-slide14-jpeg  DIY: Spark plugs and ignition coils-slide15-jpeg
Old 11-08-2019, 07:30 PM #3
Zippy0n Zippy0n is offline
Zippy0n is on a distinguished road
i followed your transmission fluid guide which helped me very very much
i will follow this too!!
Zippy0n is offline   Reply With QuoteReply With Quote
Old 02-14-2021, 07:44 PM #4
bradynasty bradynasty is offline
bradynasty is on a distinguished road
Thanks for the write up! Just finished this job on my 04. Really helpful with the air filter housing.
bradynasty is offline   Reply With QuoteReply With Quote
Old 02-14-2021, 08:09 PM #5
cooper30 cooper30 is offline
Real Name: Ted
cooper30 is on a distinguished road
Real Name: Ted
Nice clear pictures. Well written.
2008 4Runner Limited 4wd V8
2005 Tundra SR5/TRD Off Road 4wd V8
cooper30 is offline   Reply With QuoteReply With Quote
Old 03-22-2021, 12:44 PM #6
awhitney1 awhitney1 is offline
awhitney1 has a spectacular aura about awhitney1 has a spectacular aura about awhitney1 has a spectacular aura about
Very helpful, thank you!
awhitney1 is offline   Reply With QuoteReply With Quote
Old 06-09-2021, 07:57 PM #7
huskylover huskylover is offline
huskylover is on a distinguished road
at what mileage should spark plugs be changed
i just bought a low mileage 61 k 2005 4runner.
from what i can see from carfax and dealer, they have just changed the oil regularly.
Do I need to change the engine coolant, transmission fluid and spark plugs as the truck is 15 years old now.
Do I need to change all these now for preventive maintainence?
huskylover is offline   Reply With QuoteReply With Quote
Old 06-09-2021, 09:29 PM #8
triethylborane triethylborane is offline
triethylborane will become famous soon enough
Plugs should be changed when the gap is out of spec or if the spark plug is faulty; to make these determinations requires pulling plugs and given plugs are cheap, usually makes sense to pull them with the intent to replace on a 86k mi vehicle. Get Denso.
Coolant can be tested with a cheap tester from any parts store. If its not been changed . . . it probably needs to be changed. The "Asian" red formulation from Zerex or Peak are cheap and work well.
Trans fluid is something I change at 70k miles or so and Ive not seen evidence that lifetime fluid is anything but perhaps lifetime of a lease or such. Go with the Toyota WS stuff
triethylborane is offline   Reply With QuoteReply With Quote
Old 06-10-2021, 12:13 AM #9
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Use only WS type fluid in the 2005 transmission....DO NOT USE TYPE T-IV FLUID!!
Type T-IV fluid is the old type fluid use in the non-sealed transmissions and shouldn't be used in the newer sealed 5 speeds transmissions!!!
Trans fluid is something I change at 70k miles or so and Ive not seen evidence that lifetime fluid is anything but perhaps lifetime of a lease or such. Go with the Toyota WS stuff or anything T-IV spec.
The info you posted above that I highlighted in red is incorrect info...please no one use type T-IV fluid in the newer sealed transmissions, use only WS type fluid!!!
2004 Limited V8
Old 06-10-2021, 08:16 PM #10
i only have RWD . I dont have sealed transmission issues?
please confirm. i will change the coolant and brake fluids just to be safe.
Old 06-10-2021, 08:24 PM #11
for 2005 4 runner with RWD do I need to do transmission Flush or Transmission drain and fill? thanks.
Old 06-10-2021, 11:33 PM #12
Real Name: Skip
Real Name: Skip
The 2WD and 4WD transmission are mechanically the same with the exception of the 4WD transmission connects to a transfer case which connects to the 2 drive shafts and the 2WD transmission connects directly to a drive shaft.
That being said to answer your question, if the ATF has never been changed before, then yes I would recommend doing so, as far as a "flush" or a "drain and fill", I would completely replace the fluid vs. simply a drain and fill, but not do a "power" flush where the fluid is completely exchanged by external pressure, but instead a complete fluid replacement using the transmission to pump the old fluid out while adding new fluid until all the old fluid has been exchanged, there are many step by step topics on how to do this on the forum.
You may also want to change power steering fluid as well, which just an FYI uses ATF instead of actual power steering fluid, look on the cap for the correct type ATF to use.
2004 Limited V8
Old 06-15-2021, 05:13 PM #13
Thanks for the advice. I changed all the fluids including power steering, transmission, brake as well as coolant. I brought it to my old mechanic. I think he used some pump to take out old fluid and pump in new fluid.
I am just satisfied that there all new fluids in the truck now
Old 06-15-2021, 05:15 PM #14
Along with all fluids, I also changed the spark plugs with original Denso.
How long the spark plugs last? So next time I need to change the spark plugs would be after another 60 K miles? Thanks in advance.
Old 06-15-2021, 09:08 PM #15
Real Name: Skip
Real Name: Skip
The spark plug duration depends on the type of plug, copper plugs are good for 30,000 miles, iridium last much longer.
Usually the V6 engine uses copper plugs..but some owners use the iridium plugs instead, the V8 engine uses iridium, I don't think you've mentioned which engine you have, or which plugs were installed?
2004 Limited V8
diy , ignition , miles , plugs , spark
Replaced spark plugs and ignition coils now will barely start and dies immediately trevhutch1 3rd gen T4Rs 29 11-15-2017 02:51 PM
Ignition Coils and Spark Plugs at 39k? ProjectMayhem713 5th gen T4Rs 7 11-03-2017 01:35 PM
Spark and ignition experts I need your help BrianSD_42 3rd gen T4Rs 24 03-13-2015 12:45 PM
pultar pulse plugs (not spark plugs) 3rdgengrog 3rd gen T4Rs 2 11-15-2008 04:44 PM
Best ignition wires and spark plugs ... SpeedyG Classic T4Rs 6 10-18-2007 09:33 PM
