Originally Posted by ads2539
I bought the OEM Toyota “smoker’s kit”. It replaces the storage cubby next to the shifter and gives you two lighter sockets. The installation was very simple. All the necessary wiring was under the console. The empty socket is 10A, but I don’t know the rating of the socket with the lighter in it. Hopefully 10A also. There’s a new one on eBay right now for $60. I forget where I bought mine last year.
I don’t use it for anything heavy duty, just to charge an iPhone/iPod/iPad and my aftermarket TPMS readout.
I found that the factory wiring had too much voltage drop, so I ran two 12 gauge wires from the batteries. With the Toyota factory wiring a single Engel refrigerator was OK, but when two were running at the same time you could hear the compressors slow or strain a bit.
There are two problem areas with my set up.
1.) The only cigarette lighter sockets I could find to go on the end of my 12 gauge wires are very light duty and get warm even though one runs 5 amps and the other 8 amps.
2.). I need a Y with a single cigarette lighter male plug and two female sockets. The ones I have been able to buy are light duty one have 18 or 16 gauge wire. The get warm to the touch and I've had one melt.
So what I need is a source of high quality 10 amp rated cigarette lighter plugs (male) and sockets (female). Both need to fit on the end of a cable, not in a hole in a bulkhead or panel.
