12-06-2019, 09:10 PM
#31
Real Name: Elliott
Real Name: Elliott
I went with NGK. Work flawlessly
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
12-10-2019, 02:33 PM
#33
Replacing both the downstream sensors today. After replacing them, do I need to pull the battery cables off and let it sit for a bit? Or am I good to start driving once they're replaced.
12-11-2019, 12:42 AM
#34
Real Name: Elliott
Real Name: Elliott
Not a bad practice. With modern vehicles, the computer stores and remembers everything. Blanking it out will make it relearn so if there is another problem it will be obvious. Don't be alarmed, engine will start and die the first time. That's normal, start it again and it should be fine
12-11-2019, 01:09 AM
#35
Thanks, will most definitely do. Just got both the sensors installed. It definitely didn't misfire nearly as much as it was before with the old sensors. Maybe 6 times total? And that was at the very beginning of my drive. On the way back, nothing that I noticed.
12-11-2019, 12:50 PM
#36
Real Name: Elliott
Real Name: Elliott
Right on. Sounds promising
12-11-2019, 05:12 PM
#37
Unplugged the battery for a good 20 minutes. Drove around town, around the freeway 55-60mph no problems for about 30 minutes. Stopped at the store, decided to take it on the freeway... it starts happening again. Same misfires at 55-60 and sometimes at low like 25 whenever I'm at the 1800 rpm mark.
Any other thoughts?
12-11-2019, 06:52 PM
#38
Any other thoughts?
Check your fuel trims and O2 sensor voltages again and see if anything changed after putting in the new sensors.
12-11-2019, 07:14 PM
#39
So I decided screw it. Called the Toyota specialist here avx they ran a diagnostics on it. My 3rrd coil is bad. They hooked it up to a computer and found the misfire. Moved the 3rd coil to #5 and the misfire moved with it. So off to buy a new coil!
12-13-2019, 07:43 PM
#40
Any idea how they test for that?
12-21-2019, 02:23 AM
#41
They basically put it on a 'scope'. Hooked up a computer to it and found the misfire on the coil. Moved the coil from #3 to #5 and the misfire followed. I have since replaced the coil and no problems at all!
12-21-2019, 04:01 PM
#42
Real Name: Ron
Real Name: Ron
This was an interesting situation ( from my perspective). Glad you got it sorted out. With coil-on-plug arrangement it seems they would act as one (almost) and that a scope would be able to sort it out, as you discovered.
