Old 12-06-2019, 09:10 PM #31
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
I went with NGK. Work flawlessly
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 12-09-2019, 04:20 PM #32
djpope09 djpope09 is offline
djpope09 will become famous soon enough
Originally Posted by 08TxRunner View Post
Didn't know there was a problem with fake plugs for the wrong application being sold. Got any links?
PSA: Beware of Fake Iridium Spark Plugs (Ex. Denso SK20R11)
djpope09 is offline   Reply With QuoteReply With Quote
Old 12-10-2019, 02:33 PM #33
blindloser1080 blindloser1080 is offline
blindloser1080 is on a distinguished road
Replacing both the downstream sensors today. After replacing them, do I need to pull the battery cables off and let it sit for a bit? Or am I good to start driving once they're replaced.
blindloser1080 is offline   Reply With QuoteReply With Quote
Old 12-11-2019, 12:42 AM #34
81runner's Avatar
Real Name: Elliott
81runner's Avatar
Real Name: Elliott
Not a bad practice. With modern vehicles, the computer stores and remembers everything. Blanking it out will make it relearn so if there is another problem it will be obvious. Don't be alarmed, engine will start and die the first time. That's normal, start it again and it should be fine
Old 12-11-2019, 01:09 AM #35
Thanks, will most definitely do. Just got both the sensors installed. It definitely didn't misfire nearly as much as it was before with the old sensors. Maybe 6 times total? And that was at the very beginning of my drive. On the way back, nothing that I noticed.
Old 12-11-2019, 12:50 PM #36
81runner's Avatar
Real Name: Elliott
81runner's Avatar
Real Name: Elliott
Thumbs up
Right on. Sounds promising
Old 12-11-2019, 05:12 PM #37
Unplugged the battery for a good 20 minutes. Drove around town, around the freeway 55-60mph no problems for about 30 minutes. Stopped at the store, decided to take it on the freeway... it starts happening again. Same misfires at 55-60 and sometimes at low like 25 whenever I'm at the 1800 rpm mark.
Any other thoughts?
Old 12-11-2019, 06:52 PM #38
Any other thoughts?
Check your fuel trims and O2 sensor voltages again and see if anything changed after putting in the new sensors.
Old 12-11-2019, 07:14 PM #39
So I decided screw it. Called the Toyota specialist here avx they ran a diagnostics on it. My 3rrd coil is bad. They hooked it up to a computer and found the misfire. Moved the 3rd coil to #5 and the misfire moved with it. So off to buy a new coil!
Old 12-13-2019, 07:43 PM #40
Any idea how they test for that?
Old 12-21-2019, 02:23 AM #41
They basically put it on a 'scope'. Hooked up a computer to it and found the misfire on the coil. Moved the coil from #3 to #5 and the misfire followed. I have since replaced the coil and no problems at all!
Old 12-21-2019, 04:01 PM #42
rdruss's Avatar
rdruss rdruss is online now
Real Name: Ron
rdruss's Avatar
Real Name: Ron
This was an interesting situation ( from my perspective). Glad you got it sorted out. With coil-on-plug arrangement it seems they would act as one (almost) and that a scope would be able to sort it out, as you discovered.
rdruss is online now   Reply With QuoteReply With Quote
code , keys , misfire , plugs , replaced
P0301 misfire, replaced "everything", still a misfire, but no CEL...what next? Heyduke 3rd gen T4Rs 7 06-25-2018 10:50 AM
Misfire, with no CEL '99-4Runner 3rd gen T4Rs 16 06-12-2017 07:17 PM
Misfire on #6 swedge 3rd gen T4Rs 5 12-01-2012 07:50 PM
Misfire #5 jimbob86 3rd gen T4Rs 7 09-04-2012 12:09 AM
Cylinder one misfire error code without the misfire MJW 3rd gen T4Rs 4 05-03-2012 09:07 AM
