11-09-2019, 01:43 AM
Misfire no CEL
Hello, so recently my 2003 with 236k threw a P0303 code and replaced all 6 spark plugs. I replaced them with Denso iridium plugs. Drove fine for a few days.
Now I'm getting a misfire that I've been able to recreate every time going 55mph with about 1800k rpm. It's not throwing any codes either. I've ran a code scanner on it, plus I have tried running my BlueDriver on it also, with no luck.
Any input on what I should check out? I haven't replaced any coils and have yet to do the O2 sensors.
Sadly funds are currently strapped as someone broke into my friends vehicle while we were in Vancouver stole my keys out of it, so had to fork out $350 for two new keys to get programmed.
Thank you in advance
11-10-2019, 03:58 PM
what are your fuel trims like...long term.
what of the coil pack,
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto...... sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
11-10-2019, 05:09 PM
Real Name: Skip
Real Name: Skip
When you replaced the plugs did you inspect the coils, if not one or some of them could be cracked where they connect to the plug causing a short to ground and not letting the plug/s fire properly?
2004 Limited V8
12-04-2019, 06:58 PM
Sorry it took so long to reply. Finally got a chance today to pull off all the coils. None we're damaged, cracked, e.t.c.
I did notice on the driver's side that it has a sticker to replace with a 'long reach spark plug'. Any possibility that might be causing something?
12-04-2019, 07:43 PM
Just curious, are they Denso 3421 spark plugs like these?
More Information for DENSO 3421
Also, have you noticed if your fuel economy has gone down either using the number on the dash or by calculating at fill-ups?
Reason: Added another question
12-04-2019, 08:06 PM
not too long ago there was another member on the forum that had the same issue using the denso, he bought dealer plugs and the misfire went away
12-05-2019, 02:51 AM
Yes, they were the Denso 3421. They were of course the only one o'Reilly's had 6 in stock of.
So I checked all the coils, removed the plugs and reinstalled them. Went for a drive and it's still happening. You're recommending I get the plugs from the dealership and give them a try? Sadly o'Reilly won't return these as I have no packaging.
I haven't really noticed gas milage going down. I drive 60 miles daily for work and have been getting about 300-320 miles to a tank for a while now. I have to fill up once a week.
Reason: Adding to answer question
12-05-2019, 07:23 AM
Real Name: Elliott
Real Name: Elliott
It almost sounds like something is either interrupting fuel flow or causing an innacurate fuel flow for the given speed and rpm. I second
@ earthrealm
, have you checked your short/long term fuel trims? Could be an issue there, I'm leaning towards bad O2 sensors or air/fuel sensor. Don't think actual fuel delivery is bad as there would be a much more noticeable misfire and likely a light. But if either of the above mentioned sensors isn't performing the way it should, it would affect the flow of fuel at some point.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
12-05-2019, 09:21 AM
Real Name: Michael
Real Name: Michael
They should return them if you gave them your number at checkout. I do most of my returns that way because I never have packaging or a receipt. They just look me up by my number and I'm good to return whatever it is.
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
12-05-2019, 10:15 AM
What are "dealer plugs"?
12-05-2019, 10:53 AM
Real Name: Michael
Real Name: Michael
Plugs bought specifically at a Toyota dealership. That way you can be sure they are genuine and for your specific vehicle.
12-05-2019, 11:37 AM
The misfire was much more noticeable this morning, especially when I was accelerating between 50-60. I'll give the dealership plugs a try and see if maybe that fixes the whole issue. If not then I'll start with the O2 sensors.
12-05-2019, 11:44 AM
Real Name: Elliott
Real Name: Elliott
I'd strongly recommend getting your hands on an OBD2 reader that can give you live data. Even if it's a little ELM327 module that you can pair with the torque app. Would be nice to see what it is actually going on rather than just blindly throwing parts at it.
12-05-2019, 12:49 PM
I was just recently given a BlueDriver a few weeks ago. Not really sure how to use it or what I should be looking at while using it. I did have it on while trying to get the vehicle to misfire so it would read/throw a code with no luck.
12-05-2019, 02:14 PM
Real Name: Elliott
Real Name: Elliott
Never worked with bluedriver before. I bought a cheapy Chinese ELM327 OBD2 module off eBay, think I paid like 12 bucks for it. Paired with torque pro, it gives you the ability to view live data from your running engine. Not sure if bluedriver can do that as well, I would guess it can. You want to know what your long term fuel trims are (ltft1 ltft2), short term trims (stft1 stft2) and also your o2 sensor voltages. This will help narrow down the issue. I would think if the plugs were a problem, you would get a code all the time. With fuel trims, you can be out a little bit or a lot, but the obd won't throw a code unless any of them is +-30%. So you could have a ltft1 reading of +25%, ltft2 of +12%, be running like shite, and still not get a code. Sure, you could just throw parts at it, but if you're in the dark about what's going on, that could get expensive quick, fast, and in a hurry.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
