11-10-2019, 11:59 PM
Finally moving on its own power!
Moving on its own first time since the motor being hydro locked. Due to school and work, I spent nearly 6 months replacing the motor, it feels good finally getting it back on the road!
11-11-2019, 09:20 AM
Real Name: Elliott
Real Name: Elliott
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
11-11-2019, 10:04 AM
Real Name: The Native Explorer
You da man. That's the 4Runner way!
"Bumble" '17 Lim w/ 35k, IVD Stage 7, CBI/Prinsu metal, Morimoto lighting, ARB Linx : Build thread in progress...
The AventuRunner Build '07 V8 Sport w/ DO armor, Fox squish, Falken rubber, IVD UCAs, BD lights, Sherpa rack -- gonna miss the V8
The "Iceberg" Build... Natty White 3rd Gen ----gone, but not forgotten...
IG @apohl17
From ye fellow @Konkordmusk... "The 4Runner does not drive. It simply rotates the Earth to your desired position."
11-11-2019, 03:24 PM
Real Name: Michael
Real Name: Michael
......sooo...snorkel next??
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
11-12-2019, 02:33 AM
Great job!!!
11-14-2019, 01:10 AM
I wish it was story like that. But got gas on Friday, it was parked all day on Saturday (heavy rain) went to go start it Sunday morning and hear the amazing sound of a rod knock! Pull off the intake manifold and their is layer of water inside! Next pull off the oil pan and I started pulling out chucks of rod! I still have no idea how water got inside of the engine, everything is stock and wasn’t even driven in the rain!
11-14-2019, 06:08 PM
Great!
11-14-2019, 06:13 PM
Good info.
11-14-2019, 07:35 PM
What the...? So no clue what happened or how? Have you owned it for a long time? This is weird.
11-14-2019, 09:16 PM
No idea what really happened. I’ve owned it for 5 years, bought it at 115k, motor hydro locked at 205k
11-15-2019, 11:24 PM
Sabotage ?
Sent from my Redmi 4 using Tapatalk
11-16-2019, 12:04 AM
Originally Posted by benztech82
Sabotage ?
I’ve considered this but it was locked up and I’m the only one that’s has keys! But it doesn't make since due to the air filter being dry but somehow water getting inside the of the intake manifold!
11-16-2019, 07:24 AM
Real Name: Skip
Real Name: Skip
Are you sure it wasn't coolant from a possible blown head gasket or a cracked water jacket?
2004 Limited V8
11-20-2019, 10:55 AM
Possible but their was actually water in the intake and not coolant, so I’m not sure!
Still on the original tank of fuel that the motor hydro locked, and I put it to work tonight! Besides a exhaust leak on the driver side everything seems good to go!
