Old 11-11-2019, 08:03 AM #1
Hunter.Cribb's Avatar
Hunter.Cribb Hunter.Cribb is offline
Real Name: Hunter
Hunter.Cribb is on a distinguished road
Real Name: Hunter
Daytime running lights not working until car is warmed up but turn signals work?
I have a 2006 Limited. I notice my daytime running light sometimes don’t come on for around 10 minutes after I start it Or sometimes not even at all. The turn signals still work normal even if the daytime running lights are not working.
2006 Limited V6 4WD, Natural White (Sold)
2006 Limited V8 4WD, Salsa Red Pearl
Hunter.Cribb is offline   Reply With QuoteReply With Quote
Old 11-11-2019, 09:11 AM #2
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
Sounds like a problem with the flasher relay. A poor connection that heats up until resistance drops enough for voltage to flow thru the pin to the lights. The relay is on the back of the internal fuse box above the e-brake pedal on the driver side. You have to remove the dash trim and dismount the fuse box to access it, it's a big box with a plug on it. If you'd like to check something else, the turn signal harness plugs into the main harness just behind the headlight assembly, and since these vehicles use the turn signals for DRL, they get nice and hot and melt in the socket, especially if the wire is cooked and failing. I'd honestly look there first before diving into the dash. It is possible both turn signal lamps and wires are fried. I replaced my wires and installed anti hyperflash led lamps. But the constant running of the lamp threw off the resistor built in to the lamp and I would inevitably get the hyperflash anyway, so since DRL isn't required in California, I went into the relay and found the pin that puts that voltage out and bypassed it. Problem solved, in my case at least. Can't stand DRL turn signals, and I have my fog lights modded to be on all the time anyway
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
daytime , running , signals , turn , work
Turn signals stopped working, hazards still work fine - need troubleshooting help sierraskier 3rd gen T4Rs 19 06-10-2023 09:31 PM
Turn off daytime running lights ted 4th Gen T4Rs 34 09-29-2019 10:32 PM
Plugged my new trailer into 4R and brake lights/turn signals don't work mac0822 4th Gen T4Rs 3 05-23-2011 12:50 PM
2001 missing fog lights, turn signals won't work scrum4fun Engines / Suspension / Wheels / Tires / Audio / Accessories 0 03-29-2010 06:28 PM
