Originally Posted by T4R03
So I narrowed it down. It seems to be the LCA. After work I torqued the nuts I could which were the two closest to the rear on each side to 130 ft lbs. still makes the noise and I couldn't reach the front ones w my torque stick. Will try again tomorrow. Doesn't help that I didn't bring my swivel from work and it's 15 degrees outside. So I will see if I can get to those suckers tomorrow. Does anyone know what would happen if I wait like two weeks to get to them?
Re-visiting this, the sleeves through which the LCA bolts pass CAN and WILL rust/corrode leaving a gap between the sleeve wall and bolt. When I replaced mine, they came with delrin sleeves which were not an interference fit/mm gap fit which causes my knock from ID/OD differences.
2006 Shadow Mica SR5 v6
1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
