Old 11-12-2019, 01:09 AM #1
T4R03 T4R03 is offline
T4R03 is on a distinguished road
Pop/Knock in front end after new tires?
Just got Duratracs installed in my 03 4Runner Sport. Everything drives fine except now there's like a pop/knock when I get to a stop sign or when I take off from a stop. I can sometimes feel it in my foot on the drivers side front. This does not happen all the time. It's intermittent. But I was wondering what it could be? Are the Duratracs just so heavy and exposing something that was wrong with the suspension already?
T4R03 is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 08:45 AM #2
MrSeth's Avatar
MrSeth MrSeth is offline
Real Name: Seth
MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough
MrSeth's Avatar
Real Name: Seth
It may be your LCA bolts. I replaced my LCA's with new hardware and they pop/crack under the same situations as yours. I can't seem to find any catastrophic failure or catastrophic wear points that would cause similar noises either. I'll keep you updated with what I find
2006 Shadow Mica SR5 v6
1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
MrSeth is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 10:32 AM #3
That would make sense. I had most of my suspension replaced about three or 4 years ago including control arms so you may be right. I can't see anything else making that noise.
Old 11-12-2019, 12:40 PM #4
Wozzy's Avatar
Wozzy Wozzy is offline
Wozzy is on a distinguished road
Wozzy's Avatar
I've seen in some older threads that when getting an alignment, the shops aren't torquing the cam bolts up to spec (or loosening over time). Check out your cam bolt torque (and possibly tightening them to 100 ft/lbs) to see if the pops go away. Wheels should be on the ground when tightening.
2007 Limited 4WD V6 | Shadow Mica | 290K
Wozzy is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 02:48 PM #5
Will check that out because I got my alignment about three months ago. Also holy crap do these tires effect gas mileage! Ride quality isn't bad on highway but the mpg just gets raped! Lol
Old 11-12-2019, 03:37 PM #6
Wozzy's Avatar
Wozzy's Avatar
Double check your tire pressure PSI. I'm not sure which exact tires you have (meaning load range, I do see you have Duratracs. If they are load range C, disregard). On my K02s, E load range, I have to use ~40PSI for them to feel good and have a good balance of off-road and street-use. When I was using them at ~33 PSI (stock tire PSI) I could feel every bump on the road and my MPGs went down 2 MPGs.
Old 11-13-2019, 12:49 AM #7
ktom3001 ktom3001 is offline
ktom3001 is on a distinguished road
Increasing tire pressure reduced road bump feedback? Interesting
ktom3001 is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 12:50 AM #8
check your lug nut torque asap.
Old 11-13-2019, 03:04 AM #9
Think it can be lug nuts? I just drove 2.5 hours from Illinois to Iowa and I don't believe the tires are going to fall off or anything. I don't think it's a lug nut issue.
Old 11-13-2019, 03:24 AM #10
So I narrowed it down. It seems to be the LCA. After work I torqued the nuts I could which were the two closest to the rear on each side to 130 ft lbs. still makes the noise and I couldn't reach the front ones w my torque stick. Will try again tomorrow. Doesn't help that I didn't bring my swivel from work and it's 15 degrees outside. So I will see if I can get to those suckers tomorrow. Does anyone know what would happen if I wait like two weeks to get to them?
Old 11-13-2019, 10:22 AM #11
Wozzy's Avatar
Wozzy's Avatar
My understanding is that an E load range tire is marketed for 3/4 tons and up. Also the max PSI on an E load range tire is 80 PSI whereas a C range for instance is only 50. It's pretty "under inflated" at 33 PSI.
Old 11-13-2019, 11:57 AM #12
I've heard noises like that when wheels weren't torqued. They aren't necessarily going to fall off but they will make noises under braking and acceleration.
Old 11-13-2019, 02:28 PM #13
No worries I saw the guy torque them. I was actually cringing bc he overtorqued them with the impact. Good ok tire shops hiring anybody lol.
Old 11-13-2019, 07:39 PM #14
Real Name: Skip
Real Name: Skip
The only way to torque a nut or bolt properly is with a torque wrench, an impact is for removing the fastener and initial tightening, any more then that and you will always have over tightened nuts and bolts, I always watch them when they remove, replace and or rotate my tires...if they don't use a torque wrench or I see that if they do and don't still tighten the lugs a little bit more because they are already over tightened I immediately bring it to someone's attention (usually the manager) to have them torque them properly, and I still check them with my own torque wrench when I get home!
Too many tire stores over tighten lug nuts because they just use impacts and no torque wrench, this will over time stretch the studs and could cause them to break at some point and could happen while you're driving.
2004 Limited V8
Old 11-18-2019, 12:19 PM #15
This is absolutely accurate. I had tires put on the wife's corolla and 8 or 9 months later I had to do the rear brakes. After re-installing the wheels I attempted to torque the lug nuts. Instead of coming up to torque the studs began snapping one after another. With very little torque actually.
I'm certain the tire shop over torqued them and stretched them to failure.
duratracs , front , happen , pop/knock , stop
Low Speed Front End Knock tral 5th gen T4Rs 1 08-15-2019 04:01 PM
Knock in Front End Tie Rods?? SirWilliamGoes 5th gen T4Rs 4 02-15-2019 11:31 PM
Front mystery knock! emmodg 3rd gen T4Rs 3 11-28-2015 03:26 PM
Knock/Rattle in steering column or front end Dustin4185 4th Gen T4Rs 0 03-03-2012 11:17 PM
Knock-like noise from front end live4swell Problems & Warranty Issues 0 01-22-2005 12:37 PM
