Old 11-13-2019, 07:05 AM #16
Diocletian Diocletian is offline
Diocletian is on a distinguished road
Originally Posted by T4R416 View Post
V6 or v8? What springs you end up going with?
V6, I’m on stock springs for now
Diocletian is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 10:10 AM #17
T4R416 T4R416 is offline
T4R416 is on a distinguished road
Originally Posted by royal T4R View Post
Do you have a plate bumper up front?
I am currently running 5100s with OME 887 coils with a 150lbs plate bumper up front. I wish I went for the 888 coils.
The 886 coils gave my v8 WITH the steel bumper an additional 7 inches of lift on the passenger side and were binding the CVs. I do not recommend the 886 coils even though those are the drop down options for our rigs.
Stock bumpers on all around.. 7inch lift!? Damn! Gotta see this.. send pics! I was thinking 895/885 springs ..
T4R416 is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 10:32 AM #18
Wozzy Wozzy is offline
Wozzy is on a distinguished road
Sounds like it was SEMA ready with "Bluetooth" CV axles! ;)
2007 Limited 4wd V6 | Shadow Mica | 280K
Wozzy is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 02:14 PM #19
lolllllllll
Old 11-13-2019, 06:24 PM #20
royal T4R royal T4R is offline
royal T4R is on a distinguished road
lolllllllll
Too high of a CV angle after lift install
The 885 coils will sag once you add weight.
Coil specifications:
OME 883: 375mm in height, 590 pound spring rate​
OME 884: 390mm in height 590 pound spring rate
OME 885: 395mm in height 590 pound spring rate
OME 886: 402mm in height 660 pound spring rate
OME 887: 400mm in height 590 pound spring rate
​​OME 888: 405 mm in height 590 pound spring rate​
royal T4R is offline   Reply With QuoteReply With Quote
Old 11-21-2019, 12:36 AM #21
Thanks for this.. doing the 885/895 combo.
Old 11-21-2019, 12:47 PM #22
schwein schwein is offline
schwein is on a distinguished road
For anyone doing the 5100's I couldn't recommend getting a set of 5th gen coils anymore! I picked up a set of 2017 4runner Trail Edition coils from a fellow member and had them installed using the 1.75" setting on the front 5100 coils. This ended up giving my 2003 4Runner about an 1/2" lift all around and sits dead level. Keeping in mind the lift may have well come from my old 100k suspension sagging. The ride is fantastic (as everyone else contests too).
2003 - 4Runner Limited V8
2014 - 4Runner Limited V6
schwein is offline   Reply With QuoteReply With Quote
Old 11-21-2019, 02:06 PM #23
Originally Posted by schwein View Post
For anyone doing the 5100's I couldn't recommend getting a set of 5th gen coils, i picked up a set of 2017 Trail coils and had them installed 1.75 in the front, gave the 4Runner about an 1/2" all around sits dead level ride is fantastic (as everyone else contests too).
Trail coils ? Sorry new around here.. and also Part number? They will sit on the 03 4runner 5100s? Have pics? Also you mean I “would “ not “couldn’t” lol right? It’s good to have options... thanks !!
Old 11-21-2019, 02:26 PM #24
hinmo24t hinmo24t is online now
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
keep in mind springs that will lift your vehicle arent designed to be used wit 5100s notched up from the lowest setting.
hinmo24t is online now   Reply With QuoteReply With Quote
Old 11-21-2019, 03:09 PM #25
Correction!
Yes "I couldn't recommend the stock 2017 4Runner Trail Edition Coils matched to the 5100 shocks any more!"
ride is fantastic!
Old 11-21-2019, 03:30 PM #26
Drummer1's Avatar
Drummer1 Drummer1 is offline
Real Name: Dennis
Drummer1 is on a distinguished road
Drummer1's Avatar
Real Name: Dennis
I just installed 5100's and OME 886's up front and OME 889's on the rear two months ago. I left the 5100's on the bottom setting because Wheeler's Offroad said it is recommended for my set up. I also added a 1/2" top spacer on the front so I have no more rake and my 4Runner is sitting level and at the height I wanted. I also upgraded and installed new JBA upper control arms.
I am very happy with the ride even though it is stiffer than stock but as others will tell you it reduces the body role and nose dive when braking.
2006 T4R Limited V8 2WD Tinted Windows, Nitto Ridge Grappler 295/70R18, Havok H109 18x9 -12 wheels, Bilstien 5100's, OME 886/889, JBA UCA's, Kicker Sub-Woofer, Pioneer AVIC-5200NEX, complete interior & exterior LED Swap!
Drummer1 is offline   Reply With QuoteReply With Quote
Old 11-21-2019, 04:10 PM #27
Thanks for that... and How you like the JBA? Was looking into SPC?
Old 11-21-2019, 08:40 PM #28
Drummer1's Avatar
Real Name: Dennis
Drummer1's Avatar
Real Name: Dennis
I am really impressed with the JBA UCA's overall build quality. They are solid well made uca's that I'm very happy with. They also provided excellent prompt support when I had questions during my install. I highly recommend them
Old 11-21-2019, 10:02 PM #29
Are they. Known brand? First time hearing about them..
Old 11-22-2019, 12:28 AM #30
ax2021 ax2021 is online now
ax2021 will become famous soon enough
I’ve got JBA UCAs on my 4RUNNER,got them paired with Kings,no problems so far. Excellent choice for my aria,snow ,salt atc.
ax2021 is online now   Reply With QuoteReply With Quote
bilstein , bilsteins , i’m , resist , springs
Lol I couldn't resist kolelt 3rd gen T4Rs 35 01-19-2017 02:01 AM
Saw this beauty and couldn't resist... PRBond Classic T4Rs 2 06-04-2014 03:26 AM
I couldn't resist.... masson74 3rd gen T4Rs 24 09-12-2013 11:33 PM
Couldn't resist sharing some 32's! Doozi Off Topic 15 04-22-2012 01:20 AM
I couldn't resist obkook 3rd gen T4Rs 4 12-31-2011 07:19 PM
Copyright © 2019
