Old 11-12-2019, 10:13 AM #1
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
Budbuilt Hidden Winch preparation H
I am going to buy everything for running a budbuilt hidden winch plate and winch. if you have experience with bumper installs, budbuilt plate, or i think LFD has one too, feel free to chime in. If the LFD design and install is superior to budbuilt than let me know your thought on that...might justify an additional $100 for theirs. @jafrush
has anyone currently on here installed one of these? itll be for my 04 v6. i think the install follows some of same for a full bumper changeout, where the front crossmember is undone (the budbuilt gets sandwiched between the front crossmember). I see 4 big bolts (not removable?) on each side that ill have to remove nuts for and i heard replace with grade 8 nuts during reinstall. mine arent overly rusty thankfully but i do have some undercoating spray on the bottom crossmember bolt/nut on one side, i plan to wirewheel and liquid wrench these bolts and areas soon and hopefully break that front crossmember loose... other than that I have to unclip the AC line in front of radiator so it can move and allow the winch to fit without being damaged. if you have ever unclipeed that AC line or have any tips on that please let me know. What happens if that breaks? My AC doesnt blow cold or get used now anyway lol...wasnt sure if it was critical for anything else. that AC line doesnt look too crusty on my truck which is reassuring.
questions:
-does anyone know the grade 8 nut sizes i need for replacing on the crossmember?
-is it okay to remove it and drive short distances to work with it off, while i attach the plate and winch? does anything twist or stress without it there (i know not ideal for an accident/insurance...shouldnt be too long from time removed to reinstall, a week maybe)
-PIA to remove crossmember with bumper on? plan was to remove bumper when it is time to install assembled plate/winch.
-as for the winch, i want something light and reliable. i wheel my truck in some muddy/watery spots, so i need a good watertight and reliable setup. I am going this route over semi/full bumpers to save weight. total plate + winch is like 85lbs. Im thinking Warn m8000 with synthetic if i can find one, Warn VR8 synthetic, or Engo 9000S synthetic. Any input on the winch feel free. Those two Warns are only 8000lb pull but many people say people over do it with winch size, those Warns pull full size LCs, and i heard theyre reliable. I dont plan to pull full size trucks with 8,000 winch, but myself I am pretty sure they could do just fine (and only 60lbs)
curb weight on our trucks is like 4200lb? say 4500 for mine x 1.5 = <7k lb
Thanks,
Tom
time to get back to work...sorry for novel
hinmo24t is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 10:44 AM #2
jafrush's Avatar
jafrush jafrush is offline
Real Name: Jacob
jafrush is a jewel in the rough jafrush is a jewel in the rough jafrush is a jewel in the rough
jafrush's Avatar
Real Name: Jacob
So for ours, you need to remove the front bumper plastic (which isn't that bad, about maybe 10 bolts/screws and then just pull it off), and remove the front aluminum bar and its two support brackets. Re-use the existing bolts and bolt the Winch Mount base back on. The part that takes the longest is marking out where the fairlead is going to go and cutting the hole in the bumper.
We've always just gently bent the hard line back out of the way, it only usually needs to go back a half inch to an inch. Largely depends on your winch size.
At least on ours (and Id assume with others) you won't be able to do the install with the plastic bumper on. But again its really not bad to remove it.
You can drive around without any of the bumper on, you're just exposing the radiator to debris and don't have as much cushion if you hit something. Also depending on your year your turn signals may be in the bumper lights so you'd be missing those. We've driven one of our 4Runners without the front bumper for a month while working on a bumper prototype.
jafrush is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 10:54 AM #3
thanks for the info. i saw aluminum bar for the 5th gens...the 4th gen is mine, 2004, steel crossmember, and the turn signals are for 5th gen front bumpers. this is the one from your sight i would need:
LFD Off Road - Adjustable Hidden Winch Mount - 4th Gen 4R
do you have install instructions you could link or reference, from pics looks like yours replaces the crossmember? maybe not. if you guys have a decent sale ill consider this over the bud built. looks like the LFD in your picture on 4th gen sits low where you had to cut lower bumper as opposed to just the center of the bumper on a lot of the budbuilt ones.
thanks
Tom
Old 11-12-2019, 11:11 AM #4
gfxcruncher's Avatar
gfxcruncher gfxcruncher is offline
gfxcruncher has a spectacular aura about gfxcruncher has a spectacular aura about gfxcruncher has a spectacular aura about
Not trying to take business from anyone, but if budget is a concern, you could roll your own fairly easily... even add some recovery points (higher up than way under the truck)
winch plate from Amazon: ~45.
miscellaneous 3/16" angle: ~30.
1x2 bar stock: 20.
Budbuilt Hidden Winch preparation H-winch1-jpg  Budbuilt Hidden Winch preparation H-winch2-jpg
2007 SR5 4WD Nautical Blue -- Build Thread
gfxcruncher is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 11:16 AM #5
1x2 bar stock: 20.
thats sweet, thanks. i dont weld...do you have a writeup on yours with exact links to the plate you used?? without a writeup i dont know if id wing something like this or should try if self recovering my truck depends on it. i love the protruding recovery points with your. your smitty holding up despite all the haters out there?
Old 11-12-2019, 11:59 AM #6
This is the plate I got, basically the widest one I could find to straddle the frame rails
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I used this writeup as a guide and added a few more braces...
Factory Bumper Winch Install
Ha, yeah the Smitty works fine. In fact, used it last weekend.
Edit: hit a deer the other weekend so the bumper cover is basically zip tied on and missing fogs etc... Waiting on a steel bumper
Budbuilt Hidden Winch preparation H-winch3-jpg
Old 11-12-2019, 12:18 PM #7
jafrush's Avatar
Real Name: Jacob
jafrush's Avatar
Real Name: Jacob
thanks
Tom
Ours replaces the crossmember. I think the one on our 2003 was aluminum still. Not sure yet if those are going to be part of the black friday sale or not yet.
Old 11-12-2019, 12:34 PM #8
alia176 alia176 is offline
alia176 will become famous soon enough alia176 will become famous soon enough
For what it's worth, I was going to go this route myself by using a generic winch plate like the one from Amazon (mine is from HF) and fab up my own hidden winch mounting solution. However, given the state of both of my bumpers and how they've lost some of the mounting holes due to either age or the previous owner doing who knows what, I've decided to simply purchase a DIY bumper kit and go that route. I'm waiting for the Black Friday deals to pop up.
A winch by itself is probably close to 75#s plus another 80-95# for a bumper, you're definitely going to be going with the correct springs and perhaps upgrade the front suspension. Even just the winch + mounting solution will come near 100# of weight up front so you're changing out the front springs, at the very least.
I guess my point is to do some deep reflecting and see the long term end goal.
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 12:57 PM #9
thanks. i think i saw your thread. im leaning with the LFD now because it replaces the crossmember, which might save more weight than budbuilt that you sandwich between the oem crossmember (and is a pain to install i heard). the LFD seems like an easier install. i dont love how it sits so low with the LFD. as for the weight...i have bilstein 5100s and old man emu springs, and ill be getting a lightweight winch in the 60lb range, synthetic line. that will be maybe in the 75lb range total factoring in deleting oem front crossmember...i read with budbuilt setup a .25" or .5" sag, but im pretty sure on a softer suspension than what i run. i didnt anticipate the sagging from what im doing to be significant, and if it does, I will add tools or an accessory to the rear to compensate.
Old 11-12-2019, 12:58 PM #10
interesting, it might be aluminum. throw that thing on sale haha ill buy it
Old 11-12-2019, 01:41 PM #11
Wozzy's Avatar
Wozzy Wozzy is offline
Wozzy is on a distinguished road
Wozzy's Avatar
1x2 bar stock: 20.
Love this! Do you have link for the shackle mounts you used? Can't seem to find any of that length.
2007 Limited 4WD V6 | Shadow Mica | 290K
Wozzy is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 01:56 PM #12
@Wozzy
Thanks! Yeah, I couldn't find any that length either. Calling around seemed like 400 was the best I could find for someone to make them... Yeah right.
Wound up getting a 1"x2"x3' piece of bar stock from the local yard for 20 bucks and a 1" drill bit from amazon for like 30 bucks... and A LOT of patience and cutting fluid using my Ryobi drill press lol.
Old 11-12-2019, 05:07 PM #13
@Wozzy
did you get much sagging in front when you installed this?
can anyone tell me their opinion on what i saw mentioned once and my theory on .25 to .5 inch lower front after this?
Old 11-12-2019, 06:12 PM #14
It went down, but pretty minor, somewhere between 1/4 - 3/8". It wasn't really noticeable so I didn't bother adjusting the coilovers up... (running the Toytec adjustable one's w 5100s) winch is the Smitty 10k
Old 12-31-2019, 09:08 PM #15
Alainzen Alainzen is offline
Real Name: Alain
Alainzen is on a distinguished road
Real Name: Alain
Late on the winch plate thread...
I do have another option in mind for a winch plate. I am looking at the high clearance front receiver hitch from CBI
Toyota 4th Gen 4Runner High Clearance Front Receiver Hitch - CBI Offroad Fab
with a universal winch mount plate for a 2" receiver like this one:
https://www.amazon.com/dp/B07JFK9SWY...xpY2s9dHJ1ZQ==
Pros:
-Lighter than some other options? To be confirmed
-Winch is removable so, no extra weight for daily driving
-Winch can be moved to the rear bumper if needed, with proper power setup.
-You attach whatever you want in the front receiver and use it as a recovery point, winch or not.
-Solid base to add a bull bar? Maybe? Why not!
-Winch mount fit more winch models, less space constraints.
-No fabrication needed for basic setup.
Cons:
-Does not look cool... Like your T4R belongs behind a RV...IMHO
-Not sure about the installation (not really a "con")
-Still a pricey option overall
There are cheaper front receivers, but not high clearance. Not sure yet what I want to do, but the front receiver does open some options.
Your thoughts?
Alainzen is offline   Reply With QuoteReply With Quote
budbuilt , bumper , crossmember , front , winch
Budbuilt Hidden Winch hinmo24t 4th Gen T4Rs 3 08-29-2018 05:56 PM
Budbuilt Hidden Winch Plate and Engo 10K Winch Setup cmoua 4th Gen T4Rs 0 07-01-2015 09:22 PM
Budbuilt Hidden Winch Plate Mick1 5th gen T4Rs 60 03-13-2015 02:27 PM
Budbuilt hidden winch plate? ebg18t 4th Gen T4Rs 28 11-24-2013 11:45 PM
Budbuilt hidden winch system Newyorker2LA 5th gen T4Rs 2 05-26-2012 01:31 PM
