Old 11-26-2019, 09:22 AM #31
apohl17's Avatar
apohl17 apohl17 is offline
Real Name: The Native Explorer
apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light
apohl17's Avatar
Originally Posted by Kryptoroxx View Post
Lights are on order. Saved a ton but it still hurts the pocketbook.
Ordered all the goodies to build with.
Sent from my SM-G965U using Tapatalk
Lightwerkz? My order is going in today... Haha
"Bumble" '17 Lim w/ 35k, IVD Stage 7, CBI/Prinsu metal, Morimoto lighting, ARB Linx : Build thread in progress...
The AventuRunner Build '07 V8 Sport w/ DO armor, Fox squish, Falken rubber, IVD UCAs, BD lights, Sherpa rack -- gonna miss the V8
The "Iceberg" Build... Natty White 3rd Gen ----gone, but not forgotten...
IG @apohl17
From ye fellow @Konkordmusk... "The 4Runner does not drive. It simply rotates the Earth to your desired position."
apohl17 is offline   Reply With QuoteReply With Quote
Old 11-28-2019, 02:32 AM #32
Kryptoroxx's Avatar
Kryptoroxx Kryptoroxx is offline
Real Name: John
Kryptoroxx has a spectacular aura about Kryptoroxx has a spectacular aura about
Kryptoroxx's Avatar
Real Name: John
Got some goodies.....
98 Toyota 4runner 3rz 5spd 4x4 - Sold Build Thread
06 4runner 2uz Build Build Thread
Instagram: @Kryptowerkz
Kryptoroxx is offline   Reply With QuoteReply With Quote
Old 11-30-2019, 12:54 AM #33
Kryptoroxx's Avatar
Real Name: John
Kryptoroxx's Avatar
Real Name: John
Well theres the rest of it. Now for the build.
Old 12-04-2019, 08:49 PM #34
Kryptoroxx's Avatar
Real Name: John
Kryptoroxx's Avatar
Real Name: John
Ok so not a ton of exciting progress but I have the lenses off and the lights fully disassembled.
Low beams with the fixed shield removed. They'll be extra parts at the end and they have zero damage so if you're interested please message me.
d2s 5.0 test fit. I'll have to do a little dremel work with the fixed shields to make them mount but fitment is definitely not an issue. I'm also considering shoehorning the rx350 projectors in as well. There is plenty of room for each but mounting the rx350 might prove challenging to get centered.
The RX-350 lights were modified to accept STiR lenses. Looks like it will be a great upgrade over the stock glass.
Fully re-assembled RX-350 projector with the new glass.
Next stop for the housing will be sandpaper followed by primer and some interesting paint colors (hopefully)
I'm keeping this in for now since I have to do all of my fitment off of this piece. I'm going to have to drill out the center on the high beam to get the projector to fit but honestly it should not be a big deal at all. Holesaw should take care of it very quickly. The interesting part will be seating the shroud so it meets up with the bowl. I imagine at some point it will be sandpaper fitting.
Just an example of how clear the STI-R lens is. It was made to fit though. Tomorrow I'm going to try and get the drilling and fitting done. If I get lucky I'll move on to priming all of the pieces. I've taken the orange reflectors out and there will be halos replacing the turn signals. I think the halos will really set everything off and make something unique. Not sure if I will add in the LED strips but I certainly have enough room to make it all work.
Old 12-04-2019, 08:57 PM #35
KrisB410 KrisB410 is offline
KrisB410 is on a distinguished road
I'm interested on seeing how your mounting the projectors
KrisB410 is offline   Reply With QuoteReply With Quote
Old 12-04-2019, 09:02 PM #36
Kryptoroxx's Avatar
Real Name: John
Kryptoroxx's Avatar
Real Name: John
Right now I'll be cutting out the fixed shield to make a mount for the rx350s and for the high beam I'm setting the d2s 5.0 in there. I just set everything in for giggles and to see how much room I really have to play with. This is a huge headlight. Plenty of space for all kinds of stuff.
Old 12-05-2019, 01:31 AM #37
montijo505's Avatar
montijo505's Avatar
Looks good so far!
Old 12-05-2019, 03:01 PM #38
Kryptoroxx's Avatar
Real Name: John
Kryptoroxx's Avatar
Real Name: John
Lots of progress today. Well some at least. I have a little more trimming to do for the d2s in the high beam area and now I have to make the plate for the rx350. Best tool for the job is honestly a dremel and a hacksaw.
Lots of work still to be done and I still have the other light to modify but so far so good. Not only in the trimming part but the rigidity remains in the mounting plate to where I do not think jiggling will be an issue.
The pictures are all messed up for order but I tried to take pictures at every step of progress.
My humble work area that I've carved out of a garage. It works for such an intricate project though.
The goodie table. At least now everything is organized somewhat.
First test fit in the high beam area. This is actually the easier of the two to mount and fit. I would have been done with the mounting if I had not gone with the rx350 projectors for the outer.
Fully seated.
Tested with the cover on. Lots of room. With the shroud on it will blend in pretty well I think. Time will tell though. I can sink it more but honestly I like how stiff this mount is currently. If I have to cut into the bowl more I will erase strength from the reflector housing.
Another shot mounted. It's dead on for aiming purposes or at least the beginning of the aiming process.
I had to cut the throat a little bit. The rear of the projector matches the rear of the housing which is great for sealing. I might have to shave some more off to fit the ring. I don't want any twisting on this at all.
Looking at the gap for the rx350 projector
It's tough to tell but I had to cut quite a bit from the outside to get this to fit with the OEM shield control.
I managed to save the mount for the stock fixed shield. It's going to be my new mount for the rx350 projector after I get done with it. Gotta wind up the dremel with the metal cutter.
Dropped the main piece on after I finished (kinda) with the rx350 just to make sure I'm square. So far it looks great. After I modify the shield it will be perfect.
Just a comparison of the unmodified housing and the modified housing. All in all it didn't take much to get things where I want them. The awesome thing is I did not have to mess with the aiming controls so everything should remain as normal.
I knew this would be a big project but honestly I am pretty happy with the progress so far and it is pretty straight forward as well. It might be easier to fit smaller projectors......but go big or go home for this build. I've got a couple of cool details up my sleeve. More to come.
Krypto
Old 12-06-2019, 08:18 AM #39
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
Fully seated.
Krypto
i think you should cut the high beam bowls and sink the projector in, i think it can be a naked projector or use a shroud. now its interesting seeing the rx350 in the lows, i wouldnt use the brackets, i would try to mount the projector in modified headlight bracket. might need to cut a slit on the side of the high beam. after all my final adjustment, my projector doesnt sit too 100% middle of factory shroud.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 12-06-2019, 12:21 PM #40
Kryptoroxx's Avatar
Real Name: John
Kryptoroxx's Avatar
Real Name: John
I do have a shroud and I think it will blend in very well. I might have to slit the bowl just to tuck it a little further. That's a good idea though thanks.
The shroud is really skinny. I went with the new design that I can't remember the name of lol. Supposedly it's the skinniest on the market.
The rx350s won't be fixed for lows. They will have a high beam as well but I am going to cut a hole in the fixed shroud and attach the projector as the factory did. It's a simple solution and an easy secure mount. I think the projector sticks out the back just a little but it shouldn't cause any clearance issues.
I am changing the drl setup and the turn signals. The orange reflector is removed so it will be clear only. I won't have any time today to work but perhaps tomorrow. Lots more to get done!
Old 12-06-2019, 02:10 PM #41
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
These? SL-1M - Projector Shrouds - Components
Will you be running switchbacks in place of the signals?
Old 12-06-2019, 02:31 PM #42
Kryptoroxx's Avatar
Real Name: John
Kryptoroxx's Avatar
Real Name: John
Those are the ones!
Yes I will have switchbacks as the turn signals. I got 2 different sizes. I was going to do 2 different sizes of projectors but this does the same effect without the difference in mounts and such.
Old 12-06-2019, 04:02 PM #43
Ed_C's Avatar
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
I'm not sure what you meant about two different sizes regarding the signals, unless you meant repurposing the original 194 size parking light to DRL duty and the original signal/DRL as signal only.
Old 12-06-2019, 04:21 PM #44
Kryptoroxx's Avatar
Real Name: John
Kryptoroxx's Avatar
Real Name: John
Switchbacks are generally in the shrouds now however they used to be halos that were installed separately around the projector. I've got 2 different sizes of angel eyes halos. Should work pretty well for turn signal duties. Got a few other interesting things to install as well but those are still being configured.
Old 12-06-2019, 04:23 PM #45
Ed_C's Avatar
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Ahh, didn't know you were doing halos or backlit shrouds
build , dual , headlights , high , setup
Quad Repair 4runner_kid Nor Cal 0 08-20-2018 10:54 PM
Hello from the Quad Cities! QC4runner New Members 4 06-06-2014 01:11 AM
Quad with a Ferrari engine trev0006 Off Topic 1 10-26-2013 01:44 PM
7s surfboard 7'2 quad fish 4runnerwithasack For Sale: Non-T4R Items 0 09-19-2012 05:42 PM
lexus quad cam 4sale jakeyeah06 Classifieds - buy & sell (no commercial ads please) 0 08-31-2009 07:52 AM
