Old 11-15-2019, 02:56 AM #1
T4R916 T4R916 is offline
T4R916 is on a distinguished road
Vibration/Done
I've been noticing vibration on my floor board or gas pedal area and drone noise between 70mph-75mph. Any body know what it can be? Does not vibrate in the steering wheel. Tires are new 285/70/17 Wildpeak that are 2 months old. Had this vibration before the tires. Lifted on Icon and JBA UCA incase these info helps. Also its a v8 full time 4wd
T4R916 is offline   Reply With QuoteReply With Quote
Old 11-15-2019, 04:02 PM #2
apohl17's Avatar
apohl17 apohl17 is offline
Real Name: The Native Explorer
apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light
apohl17's Avatar
@T4R916 If you don't have any feedback at the wheel, you can likely rule out front end linkage, CV axles, tires, etc. Do you feel it all the time when the engine is running? If you shift it into neutral does it go away? I've never heard of it on 4runners, but you might want to look at the engine mounts if that's the case... Or it's just the power of the mighty V8
"Bumble" '17 Lim w/ 35k, IVD Stage 7, CBI/Prinsu metal, Morimoto lighting, ARB Linx : Build thread in progress...
The AventuRunner Build '07 V8 Sport w/ DO armor, Fox squish, Falken rubber, IVD UCAs, BD lights, Sherpa rack -- gonna miss the V8
The "Iceberg" Build... Natty White 3rd Gen ----gone, but not forgotten...
IG @apohl17
From ye fellow @Konkordmusk... "The 4Runner does not drive. It simply rotates the Earth to your desired position."
apohl17 is offline   Reply With QuoteReply With Quote
Old 11-15-2019, 05:43 PM #3
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
Put vehicle in park, engage ebrake, then get under vehicle. Grab your front driveshaft at the back near the tcase u-joint and try and move it. If you have any play then the u-joint is toast.
The zerk fitting on that specific u-joint is the most overlooked lube point due to the shield in place making it difficult to acccess with your grease gun. Dealer serviced trucks always have this ujoint fail first due to the tech not lubing it. LONGO TOYOTA in El Monte specifically if you catch my drift.
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 11-15-2019, 08:42 PM #4
Tried that. No play at all and I always grease the fittings.
Old 11-15-2019, 08:44 PM #5
The vibration is constant after 70mph. Tried shifting it into neutral and still vibration. Im thinking it could be from my front diff.
Old 12-08-2019, 08:27 PM #6
mechahayai mechahayai is offline
mechahayai is on a distinguished road
I have the same hum/vibration. Have you had any luck figuring it out? I'm looking at having the tires road force balanced as I have already serviced the transmission, replaced U-joints, Hub/bearings and CV. If the tires aren't the problem, I wonder what else could cause it. What are you looking at in the front diff?
mechahayai is offline   Reply With QuoteReply With Quote
Old 01-04-2021, 11:03 PM #7
U.G.N.'s Avatar
U.G.N. U.G.N. is offline
U.G.N. is on a distinguished road
U.G.N.'s Avatar
Question
Did you ever figure out what was the source of the issue? Was there anything else you completed later that did or did not help with it?
2006 Lexus LX 470
2008 Toyota 4Runner Limited V8
TLCA# 26527
U.G.N. is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 02:31 PM #8
ktom3001 ktom3001 is offline
ktom3001 is on a distinguished road
Mine did this when I bought it with 60K miles. It was a front wheel bearing.
Very subtle but almost felt like the engine was revving higher than what the tachometer showed.
ktom3001 is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 07:50 PM #9
montijo505's Avatar
montijo505's Avatar
You'll feel it in the floorboard too, like a hum.
Sent from my SM-G986U using Tapatalk
285/70/17 , lifted , tires , vibration , wildpeak
Vibration ( I know-another vibration thread) jreask 4th Gen T4Rs 1 03-16-2018 02:14 PM
Bad vibration on my 99 4R, can't tell what it is. Please help! diddlybo 3rd gen T4Rs 9 06-25-2012 11:21 PM
Vibration... 911Etarga 4th Gen T4Rs 0 11-29-2010 11:44 AM
Vibration brick 4th Gen T4Rs 0 12-10-2005 09:35 AM
'05 with a Vibration iceman140 Problems & Warranty Issues 3 10-12-2005 12:30 PM
