Originally Posted by KOTOC-79
I picked up a Toyota blank for $12.50 and 2 fobs for $37.50 on eBay. Ace hardware cut the key for me ($2)and I followed a you tube vid to program the key and fobs . It was pretty easy.
Just to point out that if you're going to make a new key for any vehicle, you are doing yourself a disservice if you don't at least buy one and have it cut by a dealer or locksmith (though I don't know how many actually have the tooling for VIN cutting.) Especially for used/high mileage vehicles.
The reason being that you're cutting your brand new key to your old, worn out key which means if your original key is only a few thousands from causing ignition issues, your new key is already pre-worn and wear out just as easily. More often than not when a customer complaints that they can't start the car or unlock the doors its the key that has worn out not the locks.
When you have the dealer cut the key; they'll run the vehicle VIN through Toyota's Database after getting authorization and then get a Key Code to cut the new key as it would be at the factory so it's nice and fresh. Afterwards you can use that key as your Master to copy from. Its a bit expensive upfront, but it pays for itself when you think about it; programming can always be done outside of the dealership through various venues.
