Old 11-16-2019, 08:30 PM #1
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
Just had 4 studs broken after simple cross rotation
For my kumho at51...ended up breaking 4 studs 2 on one wheel 30 mins before close on a Saturday. Ended up getting it to 2 new studs, 2 spare studs, rocking 5/6 lugs on two wheels im pretty sure right now. What sucks aside from having to go back sometime for studs soon is they were aftermarket black ones now I have to get more. This happened at a local shop i trust. They put them on initially but another shop did a little work once so not sure whats up... Was like 30* today
hinmo24t is offline   Reply With QuoteReply With Quote
Old 11-16-2019, 09:23 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Assume air guns used? if not and using hand tools/torque wrench then studs are questionable. I have my wheels off/on couple times a year and studs have 130K on them, using hand tools/torque wrench.
Old 11-16-2019, 11:14 PM #3
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Agree - a lot of techs air gun them way beyond the specified torque. Very frustrating
Old 11-17-2019, 04:14 AM #4
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
This is bound to happen at shops that use impacts to reinstall tires, a impact is for removing lug nuts and maybe initial install of lug nuts but not to completely tightening them only to get them down close to tight and then they should be using a torque wrench, anytime I have my tires serviced/rotated or replaced I watch them like a hawk when they reinstall the lug nuts and make sure they don't tighten them with the impact, only a torque wrench .
Anytime you over torque lug nuts too much you stretch the lug stud and over time they will break, 5, 10 even 20 lbs of over torque is not going to hurt anything but most commercial impacts can over torque the lug nuts twice to three times or even much much more then they should be, commercial impacts can easily torque 200 to 500 lbs or more!!
2004 Limited V8
Old 11-17-2019, 12:27 PM #5
radlynx radlynx is offline
Registered User
radlynx will become famous soon enough
Registered User
Happened to me when I had my tires replaced. They tightened it so much my electric impact gun can't do it. I had to use a 3 feet breaker bar and I was struggling on that too. I thought the lug bolts will break. If you get a flat tire where no one else can help, you will be stranded.
I rotate my tires now and torque it and and anti seize my rim and hub mating surface and will never come back to that repair shop. That's 1 less customer for them.
radlynx is offline   Reply With QuoteReply With Quote
Old 11-17-2019, 12:53 PM #6
Real Name: Skip
Real Name: Skip
Yes other than broken studs, as you mentioned it's very hard to impossible to get the lugs loose on the side of the road with no real tools other than what comes with the vehicle when you have a flat if they tightened them with a high torque impact wrench, that scenario was exactly what got me watching them like a hawk when doing my tires, it took me over 2 hours to get my lugs broken loose with just a L shaped lug wrench on the side of the road to change a flat on my work truck, I actually broke the L shaped lug wrench on the last 2 lug nuts and had to call a builder I knew was close by since I had just left his job site before the flat and it still took a good effort using his L shaped lug wrench which luckily didn't break and got the last 2 loose, never again!!
2004 Limited V8
Old 11-17-2019, 04:02 PM #7
DBR4runner DBR4runner is offline
DBR4runner is on a distinguished road
Sounds like over-torquing. Dumbasses
DBR4runner is offline   Reply With QuoteReply With Quote
Old 11-17-2019, 04:27 PM #8
montijo505's Avatar
montijo505's Avatar
I HATE those lazy asses that do this. If I ever do go to a shop that required them to remove the tires, I literally stand there and stop them from using impacts. They get annoyed but it’s my damn car and I’m paying for their time. My first set of wheels got some wicked damage from them using impacts to start the lugs. I didn’t notice till way later and too late to do anything about it. Idiots. /end rant lol
Old 11-17-2019, 07:22 PM #9
Chris In Milwaukee's Avatar
Chris In Milwaukee Chris In Milwaukee is offline
Chris In Milwaukee will become famous soon enough Chris In Milwaukee will become famous soon enough
I’m at a local farm store getting some KO2s installed. I told the counter person no pneumatic tools, please. To which the reply was, “I don’t think they have those back there.” Lord help me.
2019 MGM TRD ORP
BFG KO2 265/70-17
Dobinsons C509-302/GS59-700, C59-505/GS59-705, UCAs
Victory 4x4 Blitz Bumper w/Zeak 12000
Chris In Milwaukee is offline   Reply With QuoteReply With Quote
aftermarket , black , ended , shop , studs
Broken wheel lug studs with Pro Comp 7069s? Road Bull 3rd gen T4Rs 5 10-07-2017 09:06 PM
Three broken studs... Adventuring_Earl 4th Gen T4Rs 31 02-11-2016 09:38 PM
broken wheel studs LandCruiser 5th gen T4Rs 7 11-02-2014 04:58 PM
Brakes are shot, 3 broken studs vctehbro Classic T4Rs 2 05-09-2012 07:29 PM
replacing 22re manifold studs w/ 7/16x14 studs Alow Classic T4Rs 0 12-17-2010 04:40 AM
