Old 01-14-2020, 06:33 PM #16
djpope09 djpope09 is offline
djpope09 will become famous soon enough
Originally Posted by That_Titanium_4RNR View Post
Yeah, you need to have nothing on that corner at all. Keep in mind when the caliper comes off that if you hit the brakes the piston will pop out. You'll need to put some kind of block in there to keep it at least semi-compressed.
If the noise isn't there with nothing on, then slowly add parts to see what the issues is. My guess is still the ebrake or something related to it are still contacting with the drum inside of the rotor. This same type of thing happened to me. Super frustrating. Idiotic system if you ask me. The clearances are way too tight.
I was looking at a different thread about something similar. The FSM recommends drawing a chalk line on the drum portion inside the rotor. Put the rotor back on and spin the axle and you'll get a chalk mark on the parking shoes if some part of them is hitting the drum.
djpope09 is offline   Reply With QuoteReply With Quote
Old 01-14-2020, 06:40 PM #17
flsurf flsurf is offline
flsurf is on a distinguished road
Yea really can’t believe this is what Toyota came up with. Wasn’t able to get back out there it started to rain, but going to take everything off tomorrow and inspect. The chalk idea is good, going to give that a try as well.
flsurf is offline   Reply With QuoteReply With Quote
Old 01-15-2020, 11:40 AM #18
Alright just went out there and think its a bad wheel bearing. Took everything off and here is what it sounds like. https://youtu.be/UA6O-RAGcHk
Old 01-15-2020, 01:05 PM #19
Anybody have any recommendations on replacing the wheel bearings? I called toyota and they quoted $467 each side, but said that it is the bearing already pressed into the hub that it would be a bolt off bolt on job? I thought the bearing and hub was bolted on the the axle housing but pressed onto the axle shaft?
Old 01-15-2020, 05:36 PM #20
That's how my front wheel bearing sounded when it failed a couple weeks ago. Like the truck is chewing gravel.
I found these videos recently, but I'm not sure how accurate they are for you.
https://www.youtube.com/watch?v=ua8H0f7X3og
https://www.youtube.com/watch?v=OJE35juQWM8
The second one appears to be for an older Tacoma with drum brakes, but both show a pressed in bearing that you have to press out.
**Edit to add that if you look in the FSM under the Drive Shaft section, there is a file for doing what those videos show. I looked on RockAuto and don't see any hub assemblies for the rear that would be bolt off/bolt on like the front.
Old 01-15-2020, 06:26 PM #21
Thanks I found this writeup if anyone else needs it 4th Gen Rear Wheel Bearing DIY - Toyota 4Runner Forum - Largest 4Runner Forum Ordered timken bearings off rockauto $209 shipped and $100 at toyota for the seals and retainers. Hopefully ill be able to find a shop that will be able to press the old out and the new in for a decent price.
clanking , frozen , hear , noise , wheel
Strange noise coming from within inside the wheel scw1991 4th Gen T4Rs 1 06-20-2018 12:44 PM
grinding noise coming from rear passenger wheel cccolin 3rd gen T4Rs 35 04-20-2018 04:37 PM
Creaking/Clanking Sound Coming From Front End jordan_tm 5th gen T4Rs 18 11-16-2017 01:08 PM
Rear clanking noise grannyzpanniez 3rd gen T4Rs 8 05-02-2015 11:21 PM
Ticking/Crank noise coming from steering wheel jshulins 3rd gen T4Rs 1 04-01-2014 04:00 PM
