Old 11-17-2019, 09:17 PM #1
flsurf flsurf is offline
flsurf is on a distinguished road
Clanking Noise coming from Rear Wheel
UPDATE: Took me a littler longer to get to it but I finally had a day to go through the major PITA of tearing apart my parking brake and replacing the springs and retainers. I did find that one shoe the spring broke the retainer and the other side was a little bent. BUT, that did not stop the clanking noise Im getting. I also noticed that it seemed a little hard to turn the tire while I had it up. So I started the truck and put it drive and just let it idle. The passenger wheel spins freely no problem no noises, but the drivers will start spinning then stop, and when it is spinning there is that clanking noise. It seems like it would be a seized caliper but the caliper came off easy and I couldn’t tell for sure but it sounded like the noise might of been there when slowly spinning the wheel hub with the caliper and rotor off. Not really sure? Could this be a wheel bearing or something in the diff? There isn’t any play in the tire. https://youtu.be/PnxV8ji3Qjc
Getting a weird clanking noise from my Drivers rear wheel. I cross rotated my tires about 2 weeks ago which Im not sure if It it was there before that but definitely wasn’t as loud. I jacked it up today and it looks like the caliper is frozen on that wheel, but the sound does not seem like a frozen caliper. Does not change with speed just gets louder at about 15-30mph then can’t hear it much after 50mph.
Could it be a wheel bearing? No play when jacked up. You can hear it the clip, sounds like keys or something?
YouTube
flsurf is offline   Reply With QuoteReply With Quote
Old 11-18-2019, 12:53 AM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
YouTube
Sounds like it could be one of the spring and retainers holding the e-brake shoe/s in place has come loose and rattling around inside the drum part of the rotor.
before tearing anything apart look on the back side of the e-brake mounting plate/dust shield and see if you can see the back/head of the pins for the retainers and see if one of them appears to be loose.
2004 Limited V8
Old 11-18-2019, 10:49 AM #3
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
Sounds like the typical ebrake issues. Have fun with that!
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 11-18-2019, 03:24 PM #4
Ill go under there and look when I get home, but I did check my parking brake when I had it jacked up and tested it on a hill and worked great.
Old 11-18-2019, 03:50 PM #5
Real Name: Michael
Real Name: Michael
Just because it works doesn't mean that it isn't causing the noise. The pins have a tendency to get bent straight by the springs on them and then contact the back side of the axle shaft flange
Old 11-18-2019, 05:26 PM #6
Just took a look under there didn’t take the tire off though. Not sure exactly what the e-brake pins are, but I didn’t see anything loose. Im thinking you meant I need to take the tire and rotor off then look at the pins?
Old 11-18-2019, 05:56 PM #7
Real Name: Michael
Real Name: Michael
Parking brake noise issue
Help to re-install the parking brake | IH8MUD Forum
This may help
Old 11-18-2019, 06:35 PM #8
Thanks Im going to look into it probably tomorrow.
Old 01-13-2020, 07:37 PM #9
Update in OP
Old 01-14-2020, 10:53 AM #10
Real Name: Michael
Real Name: Michael
Update in OP
You aren't using 5th gen rear rotors are you??? People say they work, but they 100% do NOT
Old 01-14-2020, 01:42 PM #11
Only in the front, its been over a year and no problems. I jacked the rear back up and really tried to see any play and nothing solid. But the drivers side wheel is sticking, If I put it in Drive and just let it idle it will spin for about 30 seconds then slowly slow down and stop. If I press and release the brakes it will start spinning again then slow down and come to a stop.
Old 01-14-2020, 02:16 PM #12
Real Name: Michael
Real Name: Michael
When it does this, what exactly do you have on it? Caliper? Rotor? Neither?
Old 01-14-2020, 02:34 PM #13
When I just did it I didn’t take anything off, but Im going to go back and take everything off and try it again. When I took the caliper off yesterday it came off no problem and I was able to easily compress the piston in to put it back on. Thats why I figured it was the parking brake the whole time but now thats fixed time to look again.
Old 01-14-2020, 03:00 PM #14
Real Name: Michael
Real Name: Michael
Yeah, you need to have nothing on that corner at all. Keep in mind when the caliper comes off that if you hit the brakes the piston will pop out. You'll need to put some kind of block in there to keep it at least semi-compressed.
If the noise isn't there with nothing on, then slowly add parts to see what the issues is. My guess is still the ebrake or something related to it are still contacting with the drum inside of the rotor. This same type of thing happened to me. Super frustrating. Idiotic system if you ask me. The clearances are way too tight.
Old 01-14-2020, 03:17 PM #15
cbailey1523 cbailey1523 is offline
cbailey1523 is on a distinguished road
If one side turns freely and one side doesn't it probably just need an adjustment. Also, you want to try to adjust them so they catch at the same with with the same amount of force.
cbailey1523 is offline   Reply With QuoteReply With Quote
clanking , frozen , hear , noise , wheel
Strange noise coming from within inside the wheel scw1991 4th Gen T4Rs 1 06-20-2018 12:44 PM
grinding noise coming from rear passenger wheel cccolin 3rd gen T4Rs 35 04-20-2018 04:37 PM
Creaking/Clanking Sound Coming From Front End jordan_tm 5th gen T4Rs 18 11-16-2017 01:08 PM
Rear clanking noise grannyzpanniez 3rd gen T4Rs 8 05-02-2015 11:21 PM
Ticking/Crank noise coming from steering wheel jshulins 3rd gen T4Rs 1 04-01-2014 04:00 PM
