Old 05-22-2021, 11:03 AM #16
Originally Posted by Capt Kirk View Post
Not sure if I said this already, but are the shocks you mentioned listed for the Toyota 4runner, to replace the existing struts(F) and shocks(R) or will I have to provide measurements to get a proper fit?
just an FYI for you & others calling these struts... they are not struts, just standard coil over shocks.
KYB are an excellent option for replacement, priced nice & lifetime warranty. used OEM shocks are ok too but no warranty & usually already have at least 10k miles on them. the kyb's come with new springs on the fronts too, the springs & shocks valving is 10% stiffer/tighter than stock to provide a little firmer ride/handling & about 1" lift over stock.
Old 05-22-2021, 11:30 AM #17
Capt Kirk Capt Kirk is offline
Capt Kirk is on a distinguished road
They are very similar to the precharged refrigeration lines, and have check valve/schrader like connections, and no I didn't know before hand, but I like to know and not guess. Problably got this way from being an electrician, we don't get to guess alot, and if you let the smoke out then its game over for that part. Thanks for your info
Capt Kirk is offline   Reply With QuoteReply With Quote
Old 05-22-2021, 08:16 PM #18
Humble Leader's Avatar
Originally Posted by Rocket3004 View Post
Not to derail the conversation too much, but any details on this? Did you do it yourself or went with the dealer? I've read snippets on replacing it (i.e. at the proper disconnect spots with check valves to not loose too much fluid, etc.). I may be in the minority, but XREAS is actually pretty nice... would be great to see more on replacing it rather than the many threads on discarding it
Sorry to go on that tangent!
I replaced my front two absorbers and rear two absorbers after 152K miles. my rear absorber was starting to weep slightly (no drips, no streaks). I actually like the XREAS as well and since everything was original from factory I replaced all 4 corners. I figured if I was going to replace I wasn't going to just do the one half of the "X". If I did that I'd have two brand new absorbers and two that were 152K old. so I opted to replace all four corners
you can replace components as long as there are no leaks in the hard-lines and not too much fluid has been lost from an absorber. Absorbers come over pressurized with fluid from the factory to account for slight fluid loss but if you have a puddle or active dripping in your driveway you might need to replace all the lines as well because you cannot refill them -it's a closed system. there are pintle valves that allow for replacement of individual components. In my case I did not lose any fluid so component replacement was a solution, any weep lost would be more than compensated for the over pressurization of the two new absorbers. I had toyota do the work, this is not something I'd attempt on my own (I simply don't have the skill or tools to do so). the truck feels a bit more firm and corners really well. no body lean on onramps even if I give it some good speed. It wasn't bad before but I believe my factory absorbers were just 'tired' , braking nose dive is a bit better as well
I paid about $2500 US dollars after taxes and labour, again I did this at a toyota dealer
I did look at bilstein 5100s and fox 2.0s, everywhere was sold out, would have had to wait 3 months+ for those, shops booking 16 weeks out for work. and my toyota dealer would not install standard OEM suspension-it's a dealer decision not toyota decision so I'd have to drive to another city and find a new toyota dealer if I wanted XREAS removed and OEM installed. Investigate all your options to make the right decision. replacement with new components made the most sense for me vs a different set up and my toyota dealer has built up some good trust with me so I knew they would do the work well
Old 05-24-2021, 12:57 PM #19
Rocket3004 Rocket3004 is offline
Rocket3004 is on a distinguished road
Thanks for that information! $2500 is a healthy sum, but like you, I'm a fan of the XREAS (at least when working!) What dealer? I assume in Canada
Rocket3004 is offline   Reply With QuoteReply With Quote
Old 10-19-2021, 06:21 PM #20
The only real reason to eliminate the XREAS is because of the excessive cost to keep it maintained. The accumulators are pre charged with nitrogen and oil, and connect like a precharged A/C line set. If separated at the correct fitting the system can be taken apart with little or no oil loss
add , front , kit , level , toyota
2006 Toyota 4Runner Sport 4x4 Hitech R3dneck For Sale: Vehicles 6 04-24-2013 08:52 PM
FS: 2006 4Runner Sport V-8 Toyota 4 Runner airfranz Classifieds - buy & sell (no commercial ads please) 0 04-27-2011 02:11 PM
FS: 2006 Toyota 4runner Sport V6 4x4 barc111 Classifieds - buy & sell (no commercial ads please) 3 08-15-2008 01:07 PM
