Old 11-19-2019, 08:31 AM #1
Gtbone Gtbone is offline
Gtbone is on a distinguished road
2006 Toyota 4Runner SR5 sport suspension question
Greetings I have a 2006 Toyota 4Runner SR5 sport. It has the xreas system which is going to be removed looking for a shock recommendation for front and rear. Also the tires that I had on the vehicle were 265 70 R17AS I replaced them with 265 70 R17 AT. The clearance is good and I have no rubbing but the front tire looks a little stuffed. Im going to add a 1.5 level kit up front. The question is do I need to add a differential spacer with this size level kit?
Thanks!
Gtbone is offline   Reply With QuoteReply With Quote
Old 11-19-2019, 09:24 AM #2
apohl17's Avatar
apohl17 apohl17 is offline
Real Name: The Native Explorer
apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light
apohl17's Avatar
Thanks!
Nope. Definitely not. On our 4th gens, the diff drop is pretty much unnecessary unless you want to run like 4, 5, 6+ inches of lift, above the norm!
I have Fox shocks and struts on mine and they treat me well for daily driving and getting off the beaten path, but the Bilsteins are most popular.
"Bumble" '17 Lim w/ 35k, IVD Stage 7, CBI/Prinsu metal, Morimoto lighting, ARB Linx : Build thread in progress...
The AventuRunner Build '07 V8 Sport w/ DO armor, Fox squish, Falken rubber, IVD UCAs, BD lights, Sherpa rack -- gonna miss the V8
The "Iceberg" Build... Natty White 3rd Gen ----gone, but not forgotten...
IG @apohl17
From ye fellow @Konkordmusk... "The 4Runner does not drive. It simply rotates the Earth to your desired position."
apohl17 is offline   Reply With QuoteReply With Quote
Old 11-19-2019, 10:30 AM #3
4RunnerB's Avatar
4RunnerB 4RunnerB is offline
4RunnerB is on a distinguished road
4RunnerB's Avatar
Instead of adding a leveling kit, you could consider a setup that levels it out using the coil-overs themselves. For example, I and others swapped the 3rd Generation Tacoma suspensions onto our 4th Gens, and in my case it leveled it out (I have a V6, and I didn’t see whether you have a V6/V8). The Taco suspension take-offs can often be found almost new and cheap. Lots of great threads and helpful people on here whatever you choose.
2005 Sport, Pioneer Bluetooth, Falken Wildpeak AT3w, 2019 Taco TRD Bilsteins
4RunnerB is offline   Reply With QuoteReply With Quote
Old 11-19-2019, 12:25 PM #4
what shocks to recommend depends on what you plan to do with the 4runner. if you plan to do any regular off roading then you probably want some of the more expensive shocks designed for that like bilstein 5100 or fox etc
but if its more of a daily driver with only occasional light off roading then something more like a OEM replacement will work fine. lots of guys use stock shocks from other vehicles that will fit 4runners like FJ cruisers or tacomas or newer 5th gen 4runners.
or what i did since i rarely do any real off roading is to use the KYB shocks & complete front shock/springs. they are made about 10% stiffer than stock & teh fronts will provide about 1-1.5" lift over stock so no need to mess with spacers, if you want a true front level you can always add spacers to them. i replaced my xreas on my 08 at 145k miles & while the xreas wasnt leaking & seemed to still work, they were tired & the front springs were sagging some. the ride now is excellent & controlled & it lifted the front to close to level. cant beat the kyb's for the price. rockauto has the best price on them & there may still be a rebate from kyb.
Old 11-19-2019, 07:07 PM #5
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
The “X-REAS delete...” post linked in my sig may be useful. Let us know what you decide to do.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 05-21-2021, 01:15 PM #6
Capt Kirk Capt Kirk is offline
Capt Kirk is on a distinguished road
2006 4runner sport XREAS question
Just picked up my first 4runner Sport ED, and started brakes and suspension repairs. The XREAS system on the rear shocks is intact, but looks like original equipment. Question is does this work automaticlly
?? Can't find a button/switch anywhere. Also when I loosened the hose bolt a small amount of clean oil leaked out under pressure, is this a air or oil system? Cannot seem to find any reference to this system on the places I have looked, any help would be appreciated.***
After alot of searching ,reading, and looking at my 4runner after searching and reading, I think I'm ready to do this. Ordered the KG 9025's for the rear, and KG171371L with moog coils for the front. Thank you all for your input, Finally got rain here in Michigan, so the shade tree mechanic is heading to the work shop until the sun comes back out.
Capt Kirk is offline   Reply With QuoteReply With Quote
Old 05-21-2021, 02:38 PM #7
xreas is a hydraulic fluid system, no switch to turn on/off.
the oil that came out of the hydraulic fluid, it doesnt get dirty since its completely sealed. if it was too much it may have introduced air in the system, wont make it stop working but too much could make it not funtion as designed.
depending on the mileage on teh 4runner, it may very well be worn out & time to replace.. the dealer will charge thousands of dollars to replace it & most shops wont touch it... best option is to remove the front & rear shocks & replace with standard shocks for the intended purpose of your 4runner. if you off road a lot then look into bilstein or other brands for that purpose, if its a daily driver or majority on road/highway use, the best option IMO is teh KYB complete front with springs & rear shocks, they are about $100 ea for front & $50ea for rears. the fronts will add about 1" lift over stock in the front & they ride very nice. lifetime warranty too. some look for low mile pull offs from other toyotas like 5th gens or tacomas.
hope that helps
Old 05-21-2021, 02:46 PM #8
Humble Leader's Avatar
check this thread. do not open the system unless you know what you are doing and where to open from. I have xreas on my 5th gen and recently replaced front and back absorbers after 153K miles and it was not cheap. many opt to swap for aftermarket or OEM as others have noted, but you can definitely replace components as long as minimal to no fluid is lost or has been lost if an absorber is leaking. also there are hardlines running along the frame under the vehicle that connect to control absorbers so be careful of those
xreas - how does it work?.
Old 05-21-2021, 05:39 PM #9
Thanks, I figured out how the system works(XREAS), and its coming out, the brakes are another story, I also ran into the different rotor size 319/338 question, looked on the calipers and found a 14BD. I measured the outside edge of the rotor at the center, and got 12.250 inches which is 311.5 MM, HUH? is that 319 just a ballpark figure, or do I possibly have the wrong rotors on this thing?? Just bought it last week, its interesting. Also if I want to replace the shocks and struts, are they a stock part or do I have to do all the measurements? 45 years as an electrician , and all the electrical works great
Old 05-21-2021, 05:44 PM #10
went on you tube, Toyota has a complete video on the hydraulic system for the XREAS, and yes if you want to keep it don't mess with it. Though I do have a nitrogen tank and regulator, I'm guessing they are using an accumulator, gas over oil system. It will be gone with all the associated components.
Old 05-21-2021, 05:48 PM #11
Not sure if I said this already, but are the shocks you mentioned listed for the Toyota 4runner, to replace the existing struts(F) and shocks(R) or will I have to provide measurements to get a proper fit?
Old 05-21-2021, 05:48 PM #12
FordF150 FordF150 is offline
Banned
Real Name: Tommy Bahamas
FordF150 is an unknown quantity at this point
Banned
OEM shocks and struts are way to go, IMO.
2005 4runner bought new in 2005. Now 16,000 miles.
Amazing how well they hold up against American made stuff - like the GMC Jimmy I bought new and watched the body rust away and sold it for $800.
Book value on my 2005 4runner is still around $10 grand. Not a speck of rust on the painted body anywhere in 15 years.
GM brand is done - never to return.
Make sure you get your old shocks back. You may not like the ride in the aftermarket stuff. Been there done that with the JIMMY.
FordF150 is offline   Reply With QuoteReply With Quote
Old 05-21-2021, 05:53 PM #13
Just figuring out how this site works, appreciate the help and info.
Old 05-21-2021, 06:09 PM #14
Hello, I have the same year and model, The Fox shock, if I go to the dealer, will he have a listing for the toyota 4runner, or will it be a DYI?? Also doing a brake job on the back, and the rotors are 311.5 MM (12.250") not the 319mm/338mm that I see listed. Are these numbers ballpark, or do I have the wrong rotors on the vehicle? The caliper has a -14BD on it
Old 05-21-2021, 06:30 PM #15
Rocket3004 Rocket3004 is offline
Rocket3004 is on a distinguished road
Not to derail the conversation too much, but any details on this? Did you do it yourself or went with the dealer? I've read snippets on replacing it (i.e. at the proper disconnect spots with check valves to not loose too much fluid, etc.). I may be in the minority, but XREAS is actually pretty nice... would be great to see more on replacing it rather than the many threads on discarding it
Sorry to go on that tangent!
Rocket3004 is offline   Reply With QuoteReply With Quote
add , front , kit , level , toyota
2006 Toyota 4Runner Sport 4x4 Hitech R3dneck For Sale: Vehicles 6 04-24-2013 08:52 PM
FS: 2006 4Runner Sport V-8 Toyota 4 Runner airfranz Classifieds - buy & sell (no commercial ads please) 0 04-27-2011 02:11 PM
FS: 2006 Toyota 4runner Sport V6 4x4 barc111 Classifieds - buy & sell (no commercial ads please) 3 08-15-2008 01:07 PM
