Old 11-19-2019, 02:56 PM #1
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
4th gen T-stat jiggle valve location?
Pulled the thermostat out to flush cooling system.
Have to pull T-stat apart because it is built into the housing.
I think the jiggle valve was at 12'o clock/top side... only getting back 3rd gen search results, they seem to be in the 6'o clock position.
Anyone have a 4th gen T-stat on the bench you can check?
Guess i can get a new one...
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 11-19-2019, 03:12 PM #2
rallypoint_1's Avatar
rallypoint_1 rallypoint_1 is offline
Real Name: Bill
rallypoint_1 is on a distinguished road
Real Name: Bill
Yes put it at the 6 o’clock position. It will/should run about 10-13 degrees cooler!!
1998 T4R SR5 V6 2wd Evergreen Pearl OME 880 Toytec 1/4" spacer OME 906w/OME20mm(10mmx2)spacers Bilstein 5100 BFG KO2 31's Satoshi mod 1.5" BL(Fat Pats)
My 4Runner build:
http://www.toyota-4runner.org/3rd-ge...8-sr5-2wd.html
rallypoint_1 is offline   Reply With QuoteReply With Quote
Old 11-19-2019, 04:45 PM #3
BackOff's Avatar
Real Name: Derek
BackOff's Avatar
Real Name: Derek
I guess unconsciously i just take pictures of everything anymore.
Answered my own question.
Looks like it is 12 o'clock.
4th gen T-stat jiggle valve location?-4thgen-tstat-jpg  4th gen T-stat jiggle valve location?-4th-gen-tstat-jpg
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
Old 11-19-2019, 06:34 PM #4
L8Shift's Avatar
L8Shift L8Shift is offline
L8Shift will become famous soon enough L8Shift will become famous soon enough
L8Shift's Avatar
The OEM Stat I removed, the jiggle was at 10 o'clock.
The Stant I installed, the jiggle is at 12 o'clock.
2007 T4R Sport V8 4WD, 145K, Seat Warmers, Pioneer NEX
2007 T4R Limited V8, 4WD, 181K, OME 2"
2014 GX 460 Premium
1997 FZJ80 OME 2.5"
2006 T4R Limited V8 - R.I.P.
L8Shift is offline   Reply With QuoteReply With Quote
Old 11-19-2019, 09:31 PM #5
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
One of its functions is to bleed air from the cooling system on initial fill so you would want it at 12 o'clock so in highest position to allow air to escape and not 'pocket' above it.
Old 11-22-2019, 01:25 PM #6
Real Name: Bill
Real Name: Bill
Sorry I just realized I posted in the 4th Gen Section. The above said info is for a 3rd Gen. Sorry!!
My 4Runner build:
4th , gen , jiggle , t-stat , valve
jiggle valve around the clock tarsun 3rd gen T4Rs 5 09-08-2017 09:14 PM
A salute to the jiggle valve wemslie97 3rd gen T4Rs 3 04-25-2016 10:57 AM
No Jiggle Valve on the Stant 170? T4RunnerSteve 3rd gen T4Rs 2 01-31-2016 12:07 PM
replaced thermostat, jiggle valve eflo 3rd gen T4Rs 2 01-25-2015 03:41 PM
How do I check Jiggle Valve Position? GVL 3rd gen T4Rs 3 04-13-2014 03:12 PM
