Old 11-21-2019, 11:02 PM #1
benztech82's Avatar
benztech82 benztech82 is offline
benztech82 will become famous soon enough
benztech82's Avatar
Lift question. Billies 5100+ FJC Moog+ front daystar 1"+1"back
X-reas finally started to leak!
After going through all kinds of threads to select proper lift setup.....
I already have 33'" tires on the truck, i dont have extra weight and I want to keep stock lca's and uca's for now( just replaced all arms and joints). Also I dont quite understand the point of having diff drop of 1 inch if i'm loosing clearance of 1 inch to gain extra 1 inch with suspension lift.
Bottom line, will I benefit with the 1 inch daystar on top of new setup or change setting 1 notch up ? And will it be enough to have only 1 inch spacer on the back with fjc Moog's ?
Sent from my Redmi 4 using Tapatalk
benztech82 is offline   Reply With QuoteReply With Quote
Old 11-25-2019, 12:01 AM #2
benztech82's Avatar
benztech82's Avatar
Wow, not a single reply, too many questions?
Fine, then here is just one.
Who has 3 inch lift at the front with stock uca/lca and had no problems with joints driving etc ?
Old 11-25-2019, 08:13 AM #3
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
maybe diff drop help the cv angle a little?
i think reading some threads, the stock uca has a limit, aftermarket uca will give you additional caster, this helps with steering and control. if they can get at-least 3 at the caster with stock uca, you might be good. im no suspension expert, but others can chime in.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 11-25-2019, 12:42 PM #4
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
I'm curious about this as well. I have 5100s w/ Moog springs and stock UCAs and alignment is in spec. But I'm going to eventually swap out the Moogs for OME springs which is going to push me up another 1"+.
Also curious about the best aftermarket UCAs. I've seen a lot of people switch from Total Chaos UCAs to SPC but just wondering what the concensus was.
eleven14 is offline   Reply With QuoteReply With Quote
Old 11-25-2019, 01:38 PM #5
PJ2zero9 PJ2zero9 is offline
Real Name: Pj
PJ2zero9 is on a distinguished road
Real Name: Pj
-Bilstein 5100 all the way around (set the front to 2.5") w/ 1.5" spacers in the back.
-275/70/17 BFG K02 A/Ts
-1" Hubcentric spacers (bought from eBay, working great had them for about 10k)
I attached a picture next to another T4R. It's not the best pic.
I experienced rubbing in the front and pushed the plastic wheel wells away from the tires. I eventually ended up trimming the front bumper to improve the approach angle. OE UCA/LCA with no problems. Drives great.
Lift question. Billies 5100+ FJC Moog+ front daystar 1"+1"back-20191121_152751-jpg
PJ2zero9 is offline   Reply With QuoteReply With Quote
Old 11-25-2019, 09:01 PM #6
benztech82's Avatar
benztech82's Avatar
I would love to get OME springs but the prices bite in comparison to moog brand. I bet articulation is better with OME due to bilsteins are usually being set at 0 with them.
daystar , extra , fjc , inch , lift
5100's and daystar 1.5" rear lift. Bohicagain 5th gen T4Rs 7 05-19-2020 06:28 PM
Bilstein 5100 kit with sotck spring, 2.5" lift up fron 1.5" daystar spacer in rear jb24dolphins 5th gen T4Rs 13 02-26-2020 08:21 PM
What rear coil is recommended for 2" lift? 6112 in the front, 5100 in back minimalist 5th gen T4Rs 29 05-24-2019 01:14 AM
Billy 5100 @ 1.75" + Moog Front FJ Coils = 4" .... Why? How much will it settle? niko303 4th Gen T4Rs 14 10-30-2017 10:13 PM
Steve's budget lift: Tundra 5100's, stock front springs, rear daystar 1.5" spacer sjwelna 3rd gen T4Rs 20 01-31-2016 12:36 PM
