Old 11-22-2019, 03:29 PM #1
SAS T4R's Avatar
SAS T4R SAS T4R is offline
SAS T4R is on a distinguished road
SAS T4R's Avatar
Cooked Transmission 07 T4R?
07 4runner sport v8
Hey guys, so driving down the highway last week something flew and hit the front of my 4runner and pierced my transmission cooler line. I didn't notice, and all of the trans fluid pumped out of the torn line to the point where the truck started slipping. Same point when I started smelling the fluid coating the underside of the truck.
Had it towed home, replaced the lines and the cooler, followed proper filling procedure after flushing it 4 times (using correct fluid) and replacing the main trans filter.
Now here's the problem, downshifts from OD/5th gear cause the truck to search for the gear for 2-3 seconds and then shift. If I floor it (at a speed where I'm in 5th) it searches for a second and bangs down gears hard.
Is the trans shot? The shifting issue only happens from 5th going down. All other shifts are perfect. The problems don't exist if I keep the shifter in "4", instead of "D". Something else notable, is that it takes 3-4 seconds going from "P,R, or N" to "D" for it to engage.
If the trans is shot, how hard are they to pull out and replace? Any tips?
07 Sport T4R
06 SAS T4R
15 Taco TRD
11 Taco TRD
SAS T4R is offline   Reply With QuoteReply With Quote
Old 11-22-2019, 08:26 PM #2
Brutalguyracing Brutalguyracing is offline
Real Name: 03 v8 Limited
Brutalguyracing is on a distinguished road
Originally Posted by SAS T4R View Post
07 4runner sport v8
Have you tried disconnecting battery for some time
It will relearn the shifting
Best of luck
Sent from my SM-G950U using Tapatalk
Brutalguyracing is offline   Reply With QuoteReply With Quote
Old 11-22-2019, 09:01 PM #3
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
Sounds like the pump is toast and line pressure is too low.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 11-22-2019, 09:30 PM #4
radlynx radlynx is offline
Registered User
radlynx will become famous soon enough
Registered User
It does not take too long to destroy a transmission with empty oil. Maybe try to replace all the solenoids first then decide from there if you need to change the transmission.
radlynx is offline   Reply With QuoteReply With Quote
Old 11-22-2019, 10:11 PM #5
Captsolo Captsolo is offline
Captsolo will become famous soon enough
Bad luck. One Tundra tranny lasted 700,000 miles.
Scotty Kilmer (50 years mechanic - owns only Toyotas - based in Houston - multimillionaire) says if you can shift through the gears and drive down the highway, keep going.
Captsolo is offline   Reply With QuoteReply With Quote
Old 11-25-2019, 11:42 AM #6
SAS T4R's Avatar
SAS T4R's Avatar
Best of luck
Yes. Truck even got a new battery too
07 Sport T4R
06 SAS T4R
15 Taco TRD
11 Taco TRD
Old 11-25-2019, 11:45 AM #7
SAS T4R's Avatar
SAS T4R's Avatar
Every other gear shifts fine, it's only downshifts from 5th that are sloppy. It doesn't slip at all either. Do you know if there a solenoid that is specific to that sequence?
07 Sport T4R
06 SAS T4R
15 Taco TRD
11 Taco TRD
Old 12-04-2019, 11:32 AM #8
SAS T4R's Avatar
SAS T4R's Avatar
Does anyone know which solenoids control what? I would like to troubleshoot this before dropping a new trans in a 4runner with 90k miles.
Also, anyone local to denver wanna pm me a quote to do the install if I supply the new trans?
07 Sport T4R
06 SAS T4R
15 Taco TRD
11 Taco TRD
Old 12-05-2019, 03:03 PM #9
Montego Murph's Avatar
Montego Murph Montego Murph is offline
Montego Murph will become famous soon enough Montego Murph will become famous soon enough
To answer your question -- yes, there are individual solenoids in the valve body. This will identify which ones are which:
Sonnax Toyota/Lexus A750E/F Solenoid Identification
and this tells you a lot more about that info:
http://www.gearsmagazine.com/resourc...2010_4_all.pdf
Give these a read and share your thoughts. I might be inclined to dig in there and replace the solenoids before shelling out for a new trans -- especially if it passes the abovementioned Scotty Kilmer Shift Test which seems reasonable enough to be true in this particular case -- if you can make it shift into each gear, that means the gears all work, but the electronics don't know how to make it happen correctly which is where the solenoids and such come in.
I have done similar work (removing the valve body and replacing failed solenoids) on a Grand Cherokee. It's not difficult work -- just nuts and bolts -- but it is really messy and you'll want to be meticulous about keeping parts clean.
Montego Murph is offline   Reply With QuoteReply With Quote
Old 12-05-2019, 05:00 PM #10
JONBOY345 JONBOY345 is offline
JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about
Kilmer is an idiot about A LOT of things. Some of it he gets right, other stuff he gets so so wrong.
Take everything he says with an iceberg sized grain of salt.
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
JONBOY345 is offline   Reply With QuoteReply With Quote
Old 12-05-2019, 05:47 PM #11
No argument there.
Sauce: This Emmy-Award Winning YouTube Mechanic Is Full Of Shit
fluid , gear , trans , transmission , truck
DIY: Changing transmission fluid/ dropping transmission pan thumper 4th Gen T4Rs 11 12-18-2023 05:21 AM
Transmission flush vs. transmission fluid drain and refill... Bad_Influence 5th gen T4Rs 18 03-08-2022 12:03 AM
Transmission Fluid - bg transmission service Yuri 4th Gen T4Rs 2 02-09-2018 02:01 AM
Front O2 Sensor Cooked After 70k Miles? Robb235 3rd gen T4Rs 12 12-15-2014 05:18 PM
Cooked the engine Surf89 Classic T4Rs 11 02-09-2012 07:18 AM
