11-27-2019, 11:47 AM
Toyota phasing out RED coolant?
Went to pick up some coolant to do a change after >100K in my 2008 (at 130K actually) and dealer said they no longer stock red. Service Manager said to change to pink. Need to do through flush with distilled water a few times to really clean out all red as the two shouldnt be mixed.
Anyone have this same experience? If I have to change, is there really a need to use Toyota coolant that I need to buy from the dealer? Any after-market brands you'd recommend that meet/exceed specs?
Bob
2008 4R Limited Salsa Red Pearl 3Q3
AVS Bugflector, Coastal Lockpick 2, Super Z V1 Radar Detector Mount
Please, no more Hope & Change!
11-27-2019, 12:02 PM
You shouldnt be using red anyways. Since 2003 Toyota has been using the Pink SLLC.
I think most aftermarket pink coolants should be fine. But I only have used Toyota.
Ive been doing some research and i found Recochem OEM and Aisin to be pretty close for aftermarket.
OEM Pink - The Easy Match Antifreeze / Coolant for Your Vehicle
Aisin Aftermarket
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
11-27-2019, 12:03 PM
First I've heard of this. Isn't the pink coolant just pre-mixed red coolant?
Burt
2008 SR5 V6 4WD
1984 1/2 GT350 Mustang
2019 F250 SuperDuty
11-27-2019, 12:16 PM
You should be using pink in your 08
11-27-2019, 12:23 PM
No, they're two completely different formulas and should not be mixed with one another.
Recochem makes a good OEM alternative coolant for the Toyota Red. It's a concentrate so it needs to be diluted.
Amazon.com: Recochem OEM 86-374ROEM Red Premium Antifreeze Concentrate Extended Life RED, 1 gallon, 1 Pack: Automotive
My 2003 had the Toyota Red but I ended up switching over to Pink while replacing the water pump. You need to make sure to completely flush all of the Red stuff out the system. And if you see any black FIPG (RTV) used in the cooling system (ie thermostat housing), you'll need to replace it with the white/grey FIPG. The black FIPG is not compatible with the Pink coolant.
11-27-2019, 12:25 PM
Nope thats what I thought too. They have some different properties. The pink has a longer change interval as well. I think its like 100k miles vs 50k miles for the red.
11-27-2019, 01:19 PM
So in essence if you have the original “red” coolant in your car/truck there shouldn’t be a problem filling with the “pink” stuff correct? We used to do it all the time to our personal cars back st the shop.. keeping the left over “pink” stuff we called the “good stuff” and using it on our own drain and fills on our personal cars..
11-27-2019, 01:47 PM
zerex asian, used it on my 05 and in my GX, happy with it and its a great price at walmart
2005 4Runner Sport 4wd v6 -totaled!
2003 Lexus GX470
11-27-2019, 08:22 PM
Real Name: Skip
Real Name: Skip
I second the Zerex Asian, I can't tell the difference between it and the Toyota pink, I've been using it for several years now.
2004 Limited V8
11-27-2019, 10:16 PM
3rd for Zerex Asian. 4 years and 60k miles on my last flush and no issues at all.
11-27-2019, 10:31 PM
Real Name: Elliott
Real Name: Elliott
Another for Zerex Asian. Changed when the thermostat seal failed. New stat and seal, a few gallons of Zerex, all good.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
11-28-2019, 02:06 PM
2003 4Runner SR5 V8
319k and counting...
12-09-2019, 07:07 AM
Real Name: Richard
Real Name: Richard
Originally Posted by djkurious
Another for the Zerex- Much cheaper-
Oh, and I finally got my 15 posts guys! You can send the welcome letters to my girlfriend- And thanks in advance for all the information on this forum- I've read threads for months and now almost ready to start turning wrenches-
12-09-2019, 08:20 AM
Real Name: Skip
Real Name: Skip
Congratulations, would be happy to send a letter, please post her name, address, phone number, measurements, and a photo of her in a bikini.
2004 Limited V8
12-09-2019, 12:06 PM
that is the asian zerex mentioned above, valvoline makes it.
