Old 11-29-2019, 08:50 PM #1
CharlieV CharlieV is offline
Real Name: Charlie
CharlieV is on a distinguished road
Real Name: Charlie
2008 V8 Looking for a front skid plate
Looking for a front skid plate for my V8 4Runner. Seems that all the ones I have looked at have to be totally removed to get at the oil filter? I dont do my own oil changes and really dont want anyone removing the whole plate every time.
Does anyone know of a plate that has an access cover for the V8 Oil filter?
CharlieV is offline   Reply With QuoteReply With Quote
Old 11-29-2019, 10:44 PM #2
Boort's Avatar
Boort Boort is offline
Boort will become famous soon enough Boort will become famous soon enough
Boort's Avatar
I've been eyeing the one from RCI (they are a Vendor here! and currently running a BF sale) Engine Skid Plate | 03-09 4Runner / GX 470 – RCI Offroad One of their highlights is "Service openings for easy service and oil changes without removal"
For an Extra $30-40 they offer a Fumoto valve upgrade to more easily drain the oil. Fumoto Valve – RCI Offroad
No affiliation other than a happy customer (Have their sliders on my '06)
Boort
-- 1997 Tacoma v6 Std Cab
-- 2006 4Runner v8
Boort is offline   Reply With QuoteReply With Quote
Old 11-29-2019, 11:47 PM #3
jcaino jcaino is offline
jcaino will become famous soon enough jcaino will become famous soon enough
Have the RCI skids and the V8. I do not remove the skids for the filter and oil change. There's a hole to access the drain plug and drain oil - might go the fumoto route, but hasn't been an issue, only getting a drop or 2 on the topside of the skid. For the oil filter, i cut the side off a windshield washer fluid jug and use that beneath the filter to catch anything that drains out. Makes for a pretty easy change.
2003 Galactic Gray Mica Limited V8
Inside: Pioneer AVH-2300NEX w/ backup cam | Dometic CFX3 55im | Custom floor w/ table & drawers
Outside: Hefty Fab Bumper | Warn ZR 10-S | RCI skids & sliders
Electrical: 150w solar panel | Victron MPPT controller | BlueSea breakers and panels
Suspension & Tires: Bilstein 5100's w/ Dobinson c59-314 & c59-329 | 5th Gen Trail wheels & Wildpeak A/T3W 275/70/17
jcaino is offline   Reply With QuoteReply With Quote
Old 11-30-2019, 02:09 AM #4
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
If you don't change your own oil unfortunately there's no shop that's going to go to the trouble of making a "catch can" for the dripping oil when removing the filter, they're either going to remove the skid or just let the oil drip all over the top of the skid!!
Most of the guys they have doing oil changes are usually low paid employees and either don't have the brains, experience or just don't care to do it the easy way and if they remove the skid they are most likely going to strip or break skid plate bolts!!
2004 Limited V8
Old 11-30-2019, 08:02 AM #5
Actually think that depends a lot on the shop and anyone with an ounce of sense will go that route that saves them some time. If you're 'shop' is a jiffy lube or something, well, they definitely would be removing the factory skid to do your oil change anyway and you should probably find somewhere else to have it done.
Old 11-30-2019, 08:59 AM #6
Real Name: Skip
Real Name: Skip
I sorta agree with you, but I should have worded that a bit better and said...most shops....instead of...no shops...also I'm of the opinion that most shops are going to remove the skid plate because they're using impacts and that's faster than finding a jug and cutting it to suit the job and as we all know that going lead to broken, stripped, and crossed threaded bolts.
2004 Limited V8
Old 11-30-2019, 10:29 AM #7
Terminator03 Terminator03 is offline
Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough
I agree, especially since they’ll also use an impact to put them back on, which will strip them for sure. When I got my truck it was missing the skid, so I ordered a replacement from RCI with the filler panel. I opted for powder coated aluminum since it’s way lighter, but still way stronger than the factory sheet metal junk. I had to drill out and retap 3, out of 4 of the factory bolts which had their heads sheared off by a previous shop, or owner... I would never have my oil changed at a shop for that reason. There’s only 4 bolts, so it takes less than 2 minutes to drop the skid if you don’t want to deal with a mess, or make a diverter out of plastic for the filter, as someone suggested. I may try that next time, but removing the skid also allowed me to clean the inside while it was off, so the extra few minutes to remove it was worthwhile. I also coated the bolts with anti-seize so they will always come out easily when needed to. I thought about getting a Fumoto, but once the skid is off, I don’t see any real time savings there, for the risk of a potential leak at some point. If doing the change with the skid in place though, it would be a big help.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Terminator03 is offline   Reply With QuoteReply With Quote
filter , front , oil , plate , skid
5th gen T4R front skid plate/filler plate, Fort Worth TX Chubbypanda Want to Buy/Trade 1 10-05-2019 08:06 PM
DIY Front Skid Plate? dkyleb 4th Gen T4Rs 4 08-09-2016 02:24 PM
WTB: 4th Gen OEM Skid Plate for my 2008 Pancho1115 For Sale: T4R Items 19 10-14-2015 06:15 PM
WTB: Front skid plate 3rd gen Stretch1100 Want to Buy/Trade 2 09-21-2011 12:23 PM
WTB 2008 bottom Skid plate boostedprozac Classifieds - buy & sell (no commercial ads please) 1 05-26-2009 11:52 PM
