Old 11-30-2019, 12:13 PM #1
Smurray Smurray is offline
Smurray is on a distinguished road
Front strut stuck in place
Installing new struts and springs in all 4 corners and the factory drivers side front strut is completely stuck. Passenger side was ok getting out, rear two struts required sawzall. Have tried PB blaster, torch and sawzall with no success.
Already pulled xreas so rolling it to a shop will be tough. Does anyone have any advice?
Smurray is offline   Reply With QuoteReply With Quote
Old 11-30-2019, 12:38 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Your image link is not working correctly, it doesn't go to your photo/s.
2004 Limited V8
Old 11-30-2019, 01:38 PM #3
Does this work?
Old 11-30-2019, 03:32 PM #4
Real Name: Skip
Real Name: Skip
Yes and the same photo is in your OP as well.
If you can't cut the top off with a sawzall, I'm not sure what else you can do other than try a grinder with a thin cutting disc to grind/cut it off, WEAR A FACE SHIELD in case the thin disc breaks!!
If you have a cutting torch that would do it as well..BUT you risk setting the entire vehicle on fire if you not careful and things go badly!
2004 Limited V8
Old 11-30-2019, 04:00 PM #5
had the same issue with one side xreas "shock" on mine. (these arent struts)
no need for a sawzall or cutting torch, the body of the shock is stuck in the hole of the shock tower... get a long beefy crow bar or pry bar & wedge it in between one of the top spring coils & the inside of that shock tower, then pry side to side & downward with as much force as you can manage to dislodge it, it should pop out. also try to hit the top of the shock & the 3 bolts with a hammer to help break it free. & make sure the lower control arm is pushed down & not touching the bottom of the shock helping to keep it in there.
if you havent, use some penetrating oil around that whole area to help & if it still doesnt come out try some heat on the outer area of the shock tower hole, not on the shock itself. i suggest a propane torch as the flame is smaller & not as hot so no risk of damaging other parts or catching the vehicle on fire! ;)
but you shouldn't need heat, prying in the right area with the right angle & amount of force it will come out, its just light rust/corrosion holding it in there & its not seized or welded in place from the rust.
Old 11-30-2019, 04:10 PM #6
I really appreciate the detailed instructions. We did try a pry bar but maybe not the correct way. Doused it in PB last night and will head back to try again tonight. We already broke 1 mallet, frustrating as hell.
Old 11-30-2019, 04:26 PM #7
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
Smack that sucker with a BFH (big f##kin hammer) and wiggle it back and forth until it relents and falls out. Hardest part is getting the top hat to move. If that fails, use the no compressor method to remove the shock and spring CAREFULLY, the top hat will remain, and from there you can knock it out with said BFH, or tweak it a little with a pry bar to get the top hat to fall out. I helped a friend of mine swap out xreas last year, same thing. It did not wanna come out. That rubber likes to adhere itself to the bucket.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 11-30-2019, 05:16 PM #8
one side of mine was just like that too when i replaced the xreas 6 months ago. the shock was stuck in the hole & wouldnt budge, a big 2 foot long crow bar popped it right out. i placed it between the top coil & the upper inner corner area of the frame pocket the shock sits in. a BFH will help break it free too but i found the pry bar is what made it actually come out.
you should be able to get it out without taking it to a shop if you are this far along.
Old 11-30-2019, 07:32 PM #9
shine shine is offline
shine is on a distinguished road
Did you remove the rear nut (of the three that hold the shock in place) from inside the engine compartment, or from the wheel well?
You can access it from the inside the engine compartment by pushing the inside sheet metal slightly. Then you might be able to get some good blows in with your BFH and a bolt or something similar that will give you access. I'm a big believer in vibrations from a hammer helping loosen things that are stuck.
Also, make sure the lower control arm is hanging down below and that the shock is not seated in the LCA. You'll have to loosen the alignment bolts to do this.
And one final thing... Make sure you thread the nuts back on to at least 2 of the three bolts on top. You don't want the shock just falling down and damaging anything nearby.
shine is offline   Reply With QuoteReply With Quote
Old 12-01-2019, 03:51 PM #10
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
Same Thing
I ran into the same thing on both sides when I pulled mine. Assuming you've removed all three nuts (there's one tucked on the backside), I took an old chisel and put it between the shock mount and top cap and whacked away with a mallet. Took about 3 blows and dropped free after I wrestled it for hours.
Good luck
eleven14 is offline   Reply With QuoteReply With Quote
Old 12-02-2019, 11:00 AM #11
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
Got to harbor freight and buy this. 12 Piece Industrial Punch and Chisel Set use some of the smaller chisels to drive it between the strut and housing. Then pry. It takes a while. Smack them hard!!
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 12-02-2019, 11:12 AM #12
jcaino jcaino is offline
jcaino will become famous soon enough jcaino will become famous soon enough
Put the bolt back in the strut/LCA mount and pry down on that - used a 2x4 in my case. While holding pressure on it, give the top a few whacks with a BFH.
2003 Galactic Gray Mica Limited V8
Inside: Pioneer AVH-2300NEX w/ backup cam | Dometic CFX3 55im | Custom floor w/ table & drawers
Outside: Hefty Fab Bumper | Warn ZR 10-S | RCI skids & sliders
Electrical: 150w solar panel | Victron MPPT controller | BlueSea breakers and panels
Suspension & Tires: Bilstein 5100's w/ Dobinson c59-314 & c59-329 | 5th Gen Trail wheels & Wildpeak A/T3W 275/70/17
jcaino is offline   Reply With QuoteReply With Quote
Old 12-02-2019, 01:33 PM #13
Elan750's Avatar
Elan750 Elan750 is offline
Elan750 will become famous soon enough
Elan750's Avatar
air hammer, invest now and youl will be eternally greatful
2005 4Runner Sport 4wd v6 -totaled!
2003 Lexus GX470
Elan750 is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 10:48 AM #14
DoctorPopcorn's Avatar
DoctorPopcorn DoctorPopcorn is offline
Real Name: Tyler
DoctorPopcorn is on a distinguished road
Real Name: Tyler
Sorry to revive an older thread, but posting for the 6 hrs I spent removing both stock XREAS coilovers, hoping to help anyone in the future in the rust belt. I had already cut out my LCAs, so I didn't have them for leverage.
Driver side came out after 1.5 hrs of torching with MAP gas, then shooting PB Blaster between the rust-welded top hat and the shock tower, sucking the PB into the crevice with a lot of smoke. I then chiseled (chisels, punches, and pickle fork) and pounded everywhere I could until she finally popped.
Tried the same for the passenger... for 4 hrs. Finally, I roasted the top of the shock tower for 5-10 mins, until the bushings (which had already been on fire several times) started to catch flame without direct torch heat. Then, liberally sprayed in more PB, grabbed my 1" wood chisel (figured it was worth ruining) and chiseled moving back and forth between the top hat and the shock tower, and it finally separated. The last 2 sentences are what I would recommend just doing right away if you're having any issues.
Again, sorry for digging this back up, but I've worked on plenty of 20+ year old MN trucks, but this one really enraged me.
Still stuck after hours of torching, burning, chiseling, and beating:
Surgical equipment used (just skip straight to the wood chisel):
The demented top hat that tormented & taunted me for days:
'98 Limited 4X4 320K (summer truck): OME/5100 lift, LT235/85/16 AT3W WPs, supporting mods, many trails, on 3rd rear diff. Rust.
'05 V8 Sport 4WD 250K (DD, was hoping for pavement princess, turned out to be a work horse): IronMan 4X4 Nitro Gas Stage 2: 2.5" 0-110 lb front, 3" 440-880 lb rear. Sway bar(s). LT255/80/17 Falken AT3Ws. URD Y pipe, Slyfox75 AIP Bypass. Also rust.
DoctorPopcorn is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 12:00 PM #15
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Yeah, I know exactly what you mean, I have an '03 and many projects take twice as long because of rust.
front , sawzall , strut , struts , stuck
Front strut assembly stuck dta1984 4th Gen T4Rs 19 11-04-2018 11:57 PM
Front Strut stuck ndjose 4th Gen T4Rs 10 05-15-2018 01:55 PM
strut wont come out, feels stuck Lyric 4th Gen T4Rs 25 03-26-2017 07:36 AM
Help! Front strut stuck! zRus13 4th Gen T4Rs 4 09-13-2014 10:40 PM
OME 881 Coils-3" Lift Front Strut Assy w/KYB Gas-A-Just strut-3rd gen runner STRRAYNGE For Sale: Suspension/Wheels/Tires 7 04-30-2012 09:44 PM
