Old 11-30-2019, 03:46 PM #1
philipalberti_'s Avatar
philipalberti_ philipalberti_ is offline
philipalberti_ is on a distinguished road
Amp/Sub with stock jbl radio
I always wanted to have more bass in my 4runner, so after searching through threads and youtube vids, I decided to pick up an amp and hook it up. Major shoutout to this thread in particular. Replaced JBL Sub/Added Amp: Install Pics/Info
For the amp, I bought a RockFord 250 mono amp. This amp has a high level input with two positive and two negative wires, and magically, the 4runner oem sub has two positive and two negative wires.
For the oem replacement sub, I bought a pioneer 8 inch shallow mount. It bolts right up and works pretty good with the stock jbl amp.
The amp's power is easily connected by running a power wire through the fire wall, to the battery. I ran mine on the driver side under the doorstep panels to the trunk. As for a ground, I used an eyelet connector and bolted it to a random bolt under the trunk carpet. The amp's wire to power off when the car is off is ran to the rear panel's 12v car charger port with a snap lock connector
Sorry for the large photo sizes, I'm still learning how to resize them. and feel free to ask any questions.
anyways. wiring goes like this, with some pics attached. snip off the connectors connecting to the stock subwoofer. The red and black wires are positive btw. the yellow and green are negative. connect those wires to the matching pos/neg wires on the high level input wiring harness that came with the amp. I used some spare 14 gauge wire because the wire given isn't long enough.
Once the high level input is connected, run some cable from the amp output to the subwoofer. The pioneer has two inputs, so just pick one and it'll work perfect. No need to split the wire with a Y-connector or whatever.
As for tucking the wires and reassembling the trunk panel, the sub fits back in the normal spot with the wires pouring out. They will be squeezed by the sub It's probably best to just cut a whole in the jbl sub box, but I was lazy.
Running the wires is up to you, with however neat you want to be. I just found what works for me and tucked them the best I could. The amp just lays in the back of my trunk right behind the seat, so the wires come from just under the side panel and straight to the amp so there isn't a wiring mess.
If you dont want to use a factory sub, like I chose not to after a couple days. You can always get a sub/box. I got a used kicker comp c 10 inch sub in a closed box. Just connect the output wire to the box instead of the oem sub and all works mint.
This was done around midnight after work during the one night San Diego decides to rain heavily, so if I can do it with very little wiring experience, I'm sure anyone else on here can do it better.
Here's some pics of the amp inputs, the connection to the oem sub wiring, and what I bought.
Amp/Sub with stock jbl radio-img_0398[1]-jpg  Amp/Sub with stock jbl radio-amp-jpg  Amp/Sub with stock jbl radio-sub-jpg  Amp/Sub with stock jbl radio-img_0476[1]-jpg
05 limited 4runner 4x4 Philip Alberti's 05 4Runner Build
philipalberti_ is offline   Reply With QuoteReply With Quote
Old 11-30-2019, 03:57 PM #2
I forgot to mention. Along with the bass controller that comes with the amp, you can also control the bass from the head unit controls. Also, if you use the factory sub location, the panels will rattle a lot. At least mine did. That's why I ended up picking up a used sub box.
Old 12-02-2019, 03:56 AM #3
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
is that sub a dual voice coil? hope your using both of them if it is.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 12-07-2019, 03:38 AM #4
The box I got has a single voice coil kicker subwoofer. I only used the pioneer for for a day to test the amp before I got a kicker sub.
Old 02-24-2021, 11:38 PM #5
Ace5477 Ace5477 is offline
Ace5477 is on a distinguished road
How has this worked for you long term? I'm looking to do the same thing. Any issues with the wiring or anything like that?
Ace5477 is offline   Reply With QuoteReply With Quote
Old 06-30-2021, 11:57 AM #6
sorry, been a while since I've logged on. No issues so far. 10" Kicker CompVR bumps nicely. The toughest part was deciding where to run all the wiring.
amp , oem , wire , wires , wiring
Replacing the Stock JBL Synthesis Radio & Sub-Woofer, while keeping the Stock Amp 03limited2WD 4th Gen T4Rs 22 02-05-2019 12:17 PM
FS: 3rd gen stock radio and amp bak3rme For Sale: T4R Items 0 11-14-2011 12:22 AM
add on toyota satellite radio to stock 4runner radio matthewkristof Engines / Suspension / Wheels / Tires / Audio / Accessories 14 06-13-2011 01:11 PM
Swapping out old radio for a new stock radio? prhime Engines / Suspension / Wheels / Tires / Audio / Accessories 8 05-26-2009 04:54 PM
XM Radio, Garmin 2730 & stock radio msanta Engines / Suspension / Wheels / Tires / Audio / Accessories 7 11-28-2006 03:08 AM
