Old 12-03-2019, 04:21 PM #1
hdhp65 hdhp65 is offline
hdhp65 is on a distinguished road
Has anyone seen this befor?
I ordered a set of front 1.5" lift spacers. The total thickness of the spacer is .750 of an inch. So far so good. But here is where the problem is (I think). The stock studs on the strut plate stick out past the spacer plate about 7mm. With this condition, the top of the strut will not sit flush with the bottom of the strut tower ( The stock studs and nut will crash into the bottom of the strut tower) Am I missing something? I included some pics... NOTE: the studs with the nuts on them and how they stick up past the lift plate...
Has any seen this before? I can trim the stock studs and get a shorter nut but I really do not want to do that... Also with the lift plate only being 3/4 of an inch thick it seems that is the only option.
Please advise!
HDHP
Has anyone seen this befor?-20191203_144732-jpg  Has anyone seen this befor?-20191203_144750-jpg
hdhp65 is offline   Reply With QuoteReply With Quote
Old 12-03-2019, 04:25 PM #2
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
following
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 12-03-2019, 07:44 PM #3
SR502JAI SR502JAI is offline
SR502JAI is on a distinguished road
You 2 options
1. Cut the studs
2. get a thicker wheel spacer.
I had to do the same on my 06 GMC when i put spacers on it, the stud was too long and in order to get a flush mount, i cut the stud.
SR502JAI is offline   Reply With QuoteReply With Quote
Old 12-03-2019, 08:24 PM #4
Yea I have been looking into it and Yea that is what I am going to do. I will also have to get shorter nuts or turn the factory ones down on the lathe...
HDHP
Old 12-03-2019, 08:34 PM #5
jcaino jcaino is offline
jcaino will become famous soon enough jcaino will become famous soon enough
Have you checked with the vendor you got them from?
2003 Galactic Gray Mica Limited V8
Inside: Pioneer AVH-2300NEX w/ backup cam | Dometic CFX3 55im | Custom floor w/ table & drawers
Outside: Hefty Fab Bumper | Warn ZR 10-S | RCI skids & sliders
Electrical: 150w solar panel | Victron MPPT controller | BlueSea breakers and panels
Suspension & Tires: Bilstein 5100's w/ Dobinson c59-314 & c59-329 | 5th Gen Trail wheels & Wildpeak A/T3W 275/70/17
jcaino is offline   Reply With QuoteReply With Quote
Old 12-04-2019, 07:28 AM #6
I did not check. However, being this spacer is only .750" thick, There is not enough material to make the pocket any deeper. Now if I was to get a 1"
(2" lift) or thicker spacer the studs would not stick up past the top of the spacer.
Thanks for your input !!
HDHP
lift , plate , stock , strut , studs
Befor and after!!! New Wheels 99Yotarunner 3rd gen T4Rs 24 03-22-2009 09:54 AM
Car back from the bodyshop. Befor and after pix inside gzkrutoy 3rd gen T4Rs 5 07-26-2008 09:04 PM
