06-20-2017, 12:47 PM
Real Name: Edward Teach
Center Channel Speaker
I've been searching and have been unsuccessful in finding the last number for this speaker. It is blown and there are no aftermarket parts so I would like to go oem. Anyone have a part number or know if this is interchangeable with other Toyota parts? Thanks in advance
Update did a search on dash speaker and found s little more. Some are saying dash speaker and front tweeters are the same. They may have differ t part numbers so are they plug and play?
YouTube Videos(mostly beach driving)
https://www.youtube.com/playlist?lis...URWuu4xN6X9RvS
2005 Sport Edition V8 4x4 [] Bilstein 5100s[] OME 885/895 [] Yakima [] 255/75/17 Duratracs Wrapped around 2017 TRD Off Road wheels
06-20-2017, 12:57 PM
Update I think the part number is 86160 0w660
06-20-2017, 01:51 PM
Same speaker as the tweeters in the doors.
It's just for dialogue anyway so any speaker of similar size will do.
06-21-2017, 07:05 AM
Do you know if I order a side speaker of the brackets will fit? Is it possible to remove the speaker from the bracket and replace with aftermarket? A bit of a noob to electronics.....although I did have to replace the sub last week
06-21-2017, 07:49 AM
I don't recall 100%.
I removed mine altogether when I upgraded the system.
No more center channel.
There's a lot of space under that grille though.
06-21-2017, 10:01 AM
Real Name: Chris
Real Name: Chris
It's the exact same speaker as the doors, same brackets and everything as well
06-21-2017, 10:17 AM
Thanks, was thinking of just ordering one off eBay (it was $15 compared to the $60) for a center one
Is that the tacotunes bracket?
06-21-2017, 12:34 PM
You could also use a 3.5" coaxial speaker in there as well. Just check on the depth and find one to match. This would give you a much better sound field than just a tweeter. This location is full range sound, not just highs.
SOLD2007 4Runner Sport Edition V6 4X4 - Natural White - Perf: Doug Thorley Long Tube Headers | 4.56 Gears ARB Front / TrueTrac Rear Off Road: Fr: Bilstein 6112 w/1/2" Toytec Spacer / Rr: MT ICON Long Travel | JBA UCAs | VTX Rogue 17x8.5 -10 | GY Duratrac 285/70R17 | Rear Diff Breather Mod | 1" Toytec Body Lift | Custom Cut Axle Joints ICE: Auto Pumpkin 10.1" Android | 3.5" Tweeter Mod Exterior: Quad Bi-Xenon HID Retrofit
2019 4Runner Limited 4x4 - MGM - Hers | Ironman4x4 FCP's & UCA | Fuel Rebel 20x9+1 | GY Duratrac 275/60R20 | Victory 4x4 FLRR
06-22-2017, 04:23 PM
Real Name: Chris
Real Name: Chris
Yep, those are tacotunes
04-14-2019, 01:12 PM
Is there a way to replace this speaker from the top without having to remove the dash? I just took off the top grill and unscrewed the speaker and it looks a little tricky to get to. Is there a tutorial I'm missing?
Thanks fellas
04-15-2019, 02:46 PM
Thanks fellas
If I remember correctly, I think you can pop it out from the top with a pry tool.
01-09-2020, 11:03 AM
Thanks fellas
Sorry to resurrect a zombie thread but I thought it would be best to keep all this specific knowledge together for future searchers.
My speaker just blew yesterday. Are there any hints to popping that grill off the center speaker? I tried to get something under there to pry but it didn't give right away so I thought I should make sure there wasn't a clip or something before I broke it
01-09-2020, 11:19 AM
Real Name: Todd
Real Name: Todd
I just replaced the speaker grill on mine. There are 4 clips holding it in place. You can kinda see the rectangular holes in the blurry Photobucket pics above. Those are where the clips go. Haven't tried removing it since I just installed it but at least you know where the clips are located now.
01-09-2020, 03:11 PM
Dumb question: Even if the failed speaker is a JBL? I thought I remember reading somewhere that the JBL Speakers are unusually low impedance and don't play well with mixed types. (I know a lot of big words but don't really fully understand how it all works)
Or is that just for the main larger speakers in the door?
