Old 12-05-2019, 04:31 PM #1
jscott6's Avatar
jscott6 jscott6 is offline
Real Name: Scott
jscott6 is on a distinguished road
jscott6's Avatar
Real Name: Scott
hub centric wheel question
Almost positive my hubs are 106mm (2008 V6 Sport 4WD). So to be truly hub centric, what measurement am I looking for in the wheels? I've seen 106.2, 106.8, 108, and up. I know 2mm is not much bigger on a wheel with 108 hub measurement, but would that fit snug on the Runners 106 hub?
jscott6 is offline   Reply With QuoteReply With Quote
Old 12-06-2019, 09:05 AM #2
UrbanRunner651's Avatar
UrbanRunner651 UrbanRunner651 is offline
Real Name: Newell
UrbanRunner651 will become famous soon enough
Real Name: Newell
They are 106mm. 0.04"/side is not what I would consider a close fit, but they will fit "snug" if you bolt them down properly. As long as the bore is not smaller than 106 and the bolt pattern is the appropriate size you should be fine. Might notice a little extra vibration though.
UrbanRunner651 is offline   Reply With QuoteReply With Quote
Old 12-06-2019, 05:32 PM #3
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
I think most parts search engines take this into consideration if you're looking at wheels on tire rack, etc.
Regardless, mounting a hub centric wheel on the wrong bore size will be bad news... but as long as the wheel bore is larger, an adapter can be used to center it.
Anyway, most aftermarket wheels are lug centric. It might be worth confirming with the supplier for sure before you buy. Most of the 6x139.7 bolt pattern Toyota trucks are all 106mm hubs
Keros is offline   Reply With QuoteReply With Quote
Old 12-08-2019, 03:49 AM #4
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
I do know that Stealth Custom Series-SCS are Toyota hub centric. If you are gonna drive it on tough trails off road, hub centric is a good idea. It will also help eliminate
high speed balancing excuses a tire shop could potentially throw at you.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 12-08-2019, 07:31 AM #5
MrSeth's Avatar
MrSeth MrSeth is offline
Real Name: Seth
MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough
MrSeth's Avatar
Real Name: Seth
106.2mm is the most snug fit you'll get. Anything 108mm will most likely be lug-centric, who makes 106.8? I don't recall ever seeing that bore size. Odd.
2006 Shadow Mica SR5 v6
1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
MrSeth is offline   Reply With QuoteReply With Quote
Old 12-08-2019, 11:22 PM #6
Terminator03 Terminator03 is offline
Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough
Some aftermarket wheels have a larger bore, but supply plastic spacers to maintain the hub centric fit.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Terminator03 is offline   Reply With QuoteReply With Quote
bigger , centric , hub , measurement , wheel
Wheel spacers, Lug centric in front Hub centric in back? joeynational Classic T4Rs 3 09-06-2018 04:00 PM
Wheel Spacers - Hub Centric or Lug Centric? thomasugenius Off-Roading 15 04-14-2015 09:36 PM
Stock Hub vs A-market Wheel Bore & Hub vs Wheel Centric Questions Drak 4th Gen T4Rs 6 08-18-2014 08:13 AM
Question about hub centric wheel spacers/adapters I haven't seen verified elsewhere SURF RUNNER 3rd gen T4Rs 3 01-18-2014 04:49 PM
Wheel Question - Bead Lock & Hub-Centric ArcticEd 5th gen T4Rs 9 07-29-2010 10:03 PM
