Real Name: Elliott
Real Name: Elliott
Ok, so Moog FJ springs up front are no issue at all, you could put them on 5100s and be fine, I'd start with the lowest setting and see how it looks and feels. The rear Moog FJ springs are softer than OEM 4runner springs, avoid those if you're planning to have weight back there, you will be sag-o-riffic. Try the ome 895e, taller spring handling the same weight as stock. In a 2wd, you can do a toytec 1/4 spacer on the driver strut and be pretty level.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
