Originally Posted by hinmo24t
L range or 2 in 4h? you just keep it in Drive?
Depends on how sloppy it looks, how familiar I am with the the area, how deep it'll be, if there's stuff hiding in it, it depends.
If I know it's not super deep or nasty, I'll just leave it in drive (have a V8 with full time AWD) but just lock the center diff.
Depending on how sloppy it gets, I may drop to a lower gear. Still in High range.
If it's REALLY nasty, or there are obstacles nearby that could grab the tire and stop it in a hurry, I'll drop to low range 2 or 3.
In most cases I've found that keeping the wheel speed up helps clean the lugs out, which helps you to grab more earth to either get out, or dig down to the hard bottom (hopefully its there and you've checked for it).
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes |
GSport 2.5" Cats | DT Y-Pipe |
Magnaflow Cat Back |
2.5" Vibrant Ultra Quiet Resonator
