Old 12-06-2019, 12:17 PM #1
sport2004's Avatar
sport2004 sport2004 is offline
Real Name: James
sport2004 is on a distinguished road
sport2004's Avatar
Real Name: James
UPDATED With Pic: Adjust Headlight Aim
After replacing both low beam bulbs, the driver side is a tad higher and dispersed/wider as compared to the passenger side. It looks like the passenger side is somehow pointed lower, which is surprising because it was much easier and quicker to install. Both beams were fine before the driver side bulb failed.
My thought is to remove/reinstall both and hope for the best when I shine them on the garage door after dark. Any words of wisdom on the cause and fix, before I start messing with them and totally screw them up...?
Any insight appreciated...thanks.
Regards, sport2004
Gotta Start Somewhere 2004, V6 Sport 4WD (French Speaking), All LED interior lights, LED reverse lights, Weathertech-laser cut floor mats up front, 2nd row Weathertech-laser cut floor mats , OEM Extreme cargo liner, 4LO aint hap'nin
sport2004 is offline   Reply With QuoteReply With Quote
Old 12-06-2019, 04:49 PM #2
Montego Murph's Avatar
Montego Murph Montego Murph is offline
Montego Murph will become famous soon enough Montego Murph will become famous soon enough
I might be inclined to remove and reinstall the offending bulb first and see if that helps. If it's that far off after replacing the bulb, it may not be seated properly and then you've gone and messed up the adjustments for real.
Also its possible that maybe you bumped the adjuster somehow while replacing the bulb?
Montego Murph is offline   Reply With QuoteReply With Quote
Old 12-06-2019, 05:01 PM #3
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
That is possible. However, since the passenger side was easy to replace one-handed, and without much manipulating, seems less probable that is what happened. OTOH, the driver side was more complicated, smaller space, needed two hands, and of course there was road and engine grit everywhere, so I wore vinyl gloves.
What I think I might do is post a pic tonight of the pattern on the garage door. Someone here could weigh in on which one is mis-aligned.
Thanks for the reply.
Regards, sport2004
Old 12-06-2019, 06:46 PM #4
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
Ok, who can diagnose this problem...??!! Passenger side looks weird.
Regards, sport2004
Old 12-07-2019, 06:27 PM #5
BR06run BR06run is offline
Real Name: Bill R.
BR06run is on a distinguished road
Real Name: Bill R.
Switch the right with the left and see what happens. Possible defect in the bulb.Did you twist it in all the way. There's definitely some thing wrong with that pattern.
BR06run is offline   Reply With QuoteReply With Quote
Old 12-07-2019, 06:41 PM #6
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
Messed with the passenger side, much improved, think I can live with this.
Regards, sport2004
Old 12-07-2019, 07:07 PM #7
Real Name: Bill R.
Real Name: Bill R.
That looks fine.What did you do to fix it.
Old 12-07-2019, 07:14 PM #8
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
Pulled it out, took more time to see how the socket fits, replaced it, clicked into place, might even do the same in the other side tomorrow.
It is amazing how dark it is under the hood in broad daylight. This time I used a flashlight.
Regards, sport2004
Old 12-08-2019, 01:32 AM #9
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
are you using aftermarket headlight housings? youll be lucky enough it comes out good after final adjustment, i personally set them level to each other.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 12-08-2019, 01:31 PM #10
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
No, the housings are stock. I'll tamper with the driver side today to see if the aim rises at all. If it doesn't, and still bothers me, not sure what I'll do, since if I mess with it more, could catch a worse case of, 'screw it up-itis'.
Thanks...
Regards, sport2004
Old 12-08-2019, 10:04 PM #11
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
no change after messing around with them, not sure it is worth changing the aim on either of them, and if i were, not sure which one...
Regards, sport2004
Old 12-08-2019, 11:06 PM #12
riceandpho's Avatar
riceandpho's Avatar
height adjustment is the middle bolt lower area, could be stripped inside the pivot point, the horizontal adjustment is on the top sides.
Old 12-08-2019, 11:15 PM #13
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
Thanks, will check it out
Regards, sport2004
driver , garage , passenger , side , thought
How to Adjust Headlights sant6236 3rd gen T4Rs 40 09-04-2022 03:49 PM
how to adjust main headlight? Sworks 5th gen T4Rs 2 06-24-2015 01:12 PM
idle adjust help 3bears 3rd gen T4Rs 7 05-20-2015 07:34 AM
Headlight adjust nut turned - but light still "Loose" bharris68 3rd gen T4Rs 0 04-01-2014 04:02 PM
how do u adjust? 04desertrunner 3rd gen T4Rs 3 09-19-2012 10:29 PM
