12-13-2019, 07:05 AM
#16
Originally Posted by 81runner
Just to put your mind at ease somewhat, aluminum as a metal for making engines is really not bad so long as it's designed for the stresses and tolerances it will experience throughout it's service life. The 1GR is fairly hearty in this respect, lots of engines now reporting 400k miles and up. The issue is where the metal is thin, like threading for example. Aluminum threads can be a little soft, so it's recommended that you only tighten to the recommended torque spec so you don't strip the threads out. This is true even outside of engines. I've had aluminum oil coolers on different pieces of equipment where the flange seals are bolted on and the aluminum threads fail because someone was a gorilla and cranked it down waiting for it to get tight and pop goes the threads. Sure, you can usually tap and install steel coil replacements in most cases, but you need to have enough metal surrounding the hole to be secure enough for that, not to mention other wonderful things that can occur when you get into that. Better to go with ounce of prevention (torque wrench) than pound of cure (costly repairs). Just my $.02
Thanks for your input!
One thing about torque wrenches is how can you trust them being calibrated correctly? What's a good all around trusted torque wrench and is it recommended to have a couple for particular jobs?
2008 SR5 2wd V6
12-13-2019, 08:17 AM
#17
Real Name: Elliott
Real Name: Elliott
Very good question. My answer may come as a shock to some, but I used to service air compressors at a company in southern California that specializes in calibration of sensitive equipment and tools like meters, calibrating weights, scopes, gauges and yes, torque wrenches. Given my line of work, I also found this to be important information, so I asked one of the senior calibration technicans this very same thing. His response: in his years of experience, the torque wrenches he has seen that hold their settings the best came from Harbor Freight tools (!?!?!? Wtf???). I was shocked. Then he proved it. A snap-on, a Mac, and an HFT were all tested against a calibrated setup with a 100 lb/ft nut and bolt. The HFT was dead on, the other two were off by at least a couple pounds and needed to be adjusted. His point was simple: they were all used as primary tools from their respective shops, and all saw about the same amount of use over a 2 year period. The important thing with any wrench is make sure it is stored in it's case, try not to drop it if you can help it, and make sure you reset it to 0 lb before you put it away. Leaving it stored without resetting it puts strain on the internals which will cause it to go out of calibration. I had him test my wrench, also HFT, and it clicked when it was supposed to.
Now, there is no way to guarantee that each of the three tested wrenches was cared for in the same way, but the Mac came out of the box locked on to 85 ft/lb. The other two came out of the box at 0. The Mac was the furthest out. The snap-on was only off by a couple pounds. So I figure mileage may vary here. Just find one that reaches your desired specs and care for it as a specialty tool, because that's what it is. Keep it clean and don't store it locked on to a particular setting aside from zero, and you should be fine.
You should have one that's dedicated to foot pounds and one dedicated to inch pounds since the smaller stuff is more likely to be torqued in inch pounds and an inch pound wrench is going to be smaller as well for this type of application. One foot pound is 12 inch pounds, so the tolerances are tighter on an inch pound wrench.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
12-13-2019, 01:49 PM
#18
I would never have guessed HFT would be the place to get a tool such as that! Awesome really!
Not sure if your familiar with Chris Fix on Youtube, but I recently saw a vid of his on torque wrenches and he recommended one priced about $50 from Amazon. I thought about getting it, but then thought it's probably better to not have one shipped as it would probably be thrown and tossed around much more through delivery then getting one at say HFT. I think I'll go with your suggestion. Is there a way to test the accuracy without paying for one to be calibrated after purchase?
Thanks again for your time!
2008 SR5 2wd V6
12-13-2019, 02:37 PM
#19
Pittsburgh
3/8 in. Drive Click Type Torque 3/8 in. torque wrench provides a range from 5-80 ft. lbs.$20
Can't beat that!
2008 SR5 2wd V6
12-13-2019, 06:46 PM
#20
Real Name: Skip
Real Name: Skip
You stated that the BFT torque was the only one that was in calibration, which I find interesting as well, my question would be that HFT actually doesn't make any of the tools they sell, they have 3 different brands of torque wrenches listed on their website... Pittsburgh, Icon, and Quinn...which of these brands is the brand you're referring too as a "HFT" torque wrench?
2004 Limited V8
12-13-2019, 06:52 PM
#21
Real Name: Skip
Real Name: Skip
Pittsburgh
Can't beat that!
I would also suggest you get the 1/4" drive Pittsburgh torque wrench as well since it's the one that will torque in inch pounds, the 3/8" and 1/2" drive both torque in foot pounds, both the inch pound and the foot pound torque wrenches are needed for the various different size bolts and nuts on any passenger type vehicles.
Which one you use will depend on the actual torque specs of the fastener you're dealing with.
2004 Limited V8
12-13-2019, 10:34 PM
#22
Real Name: Elliott
Real Name: Elliott
If memory serves, it was a Pittsburgh 1/2 drive like the one I have. Pretty sure that's all they carried until recently. I've had mine since 2007. Was tested in 2014. Hasn't been tested since.
