Old 12-10-2019, 01:14 PM #1
RoyBell RoyBell is offline
RoyBell will become famous soon enough
Is wiring the same on models without backup camera/bluetooth?
Does anyone know if the wiring is the same between fully loaded limited models and base limited models?
I have one of each and would like to add the backup camera to my base limited, along with the bluetooth option. I am just wondering if anyone knows if the harnesses are the same...ie: are the plugs there for the steering wheel control and backup camera? I would obviously pick up a radio with screen.
What about the wiring for the speakers? My loaded limited has the subwoofer which sounds a lot better than the regular setup. Is the wiring there for all that stuff just to add, or is everything different?
Just the Toyotas
'86 FJ60
'07 4R V8
RoyBell is offline   Reply With QuoteReply With Quote
Old 12-10-2019, 01:59 PM #2
07basict4r 07basict4r is offline
07basict4r is on a distinguished road
Would like to know this also
07basict4r is offline   Reply With QuoteReply With Quote
Old 12-10-2019, 02:27 PM #3
I just changed the hatch latch before I got the new one. I could had "sworn" I saw an extra plug when I was doing that, but I can't remember now since I wasn't looking for that specifically at the time.
Just the Toyotas
'86 FJ60
'07 4R V8
Old 12-17-2019, 03:18 AM #4
vr4z06gt vr4z06gt is offline
vr4z06gt is on a distinguished road
I recently changed the back door shell on my 08 limited. The donor vehicle did not have factory navigation, mine did. When swapping the shells I needed to swap the wiring harness as well, as the donor door did not have provisions for the gps receiver nor the backup camera. You would also need to template the factory mounting location as the non-nav models dont have the camera mounting hole cut out or stamped into the door. A factory wiring harness leaves very little wiggle room for the camera mounting location. You would also need a nav model exterior door latch trim panel as the camera is secured to it.
I cant speak directly to the speaker wiring provisions but I would guess it's a similar constraint???
vr4z06gt is offline   Reply With QuoteReply With Quote
backup , camera , limited , models , wiring
Backup Camera Wiring LawnDart 5th gen T4Rs 24 08-19-2021 06:22 PM
Bluetooth Interference with Aftermarket Backup Camera bellis 5th gen T4Rs 3 02-09-2017 11:11 PM
Backup camera wiring?? 4th gen maxim240sx Engines / Suspension / Wheels / Tires / Audio / Accessories 8 04-30-2013 03:12 PM
Aftermarket backup camera wiring - need help/suggestions Arterisk 5th gen T4Rs 2 09-29-2011 05:59 PM
Wiring Up Nav & Backup Camera, Where To Tap Into Reverse Indicator? the_josh Engines / Suspension / Wheels / Tires / Audio / Accessories 2 10-12-2010 01:39 PM
