Old 12-19-2017, 04:58 PM #1
hobosapien hobosapien is offline
hobosapien is on a distinguished road
LS-swapped 4th gen? Has it been done?
I only ask because I'd like to do it with an LS3 Erod. I have a v8 4th gen already. Granted a lot of work would need to be done but I'm curious if someone out there has already done it.
hobosapien is offline   Reply With QuoteReply With Quote
Old 12-19-2017, 05:00 PM #2
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
I haven't seen one. Couple FJ's have I think.
Just throw on a supercharger me thinks. Cheaper and another 100 hp/tq.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 12-19-2017, 05:17 PM #3
Where is there a SC that's available for the 4th gen? I haven't seen any for sale.
Old 12-19-2017, 05:22 PM #4
Inv4drZm's Avatar
Inv4drZm's Avatar
You might be able to find an old TRD model, or URD makes a kit. URD's might just be for 05-09 V8's but maybe they make one that is compatible with the older V8's, I'm not sure.
Old 12-19-2017, 06:02 PM #5
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
I swapped an LS1 into my old Camaro years ago and I've been considering one for my T4R. Even a 5.3L truck LS engine would be a good upgrade in my case w/ a 165K mile V6 and stretched timing chain.
The engines are plentiful on LKQ and car-part.com and cheap.
Just offhand recalling the old Camaro swap, here's a stab at the problems to solve:
Engine mounts (I bought my Camaro mounts pre-fabricated)
Wiring: could use a standalone harness and 12VDC feeds?
Fuel pressure: LS wants 58psi constant delivery pressure
Cooling hoses to radiator and heater core
Transmission bellhousing and torque converter/flywheel bolt patterns
Instrumentation e.g. coolant temp, tach, etc.
LS PCM programming to disable VATS and unused sensors
But this swap also adds the complexity of engine control outputs to the Toyota controller(s) which are used for transmission, 4WD, ABS, etc. These may need to know engine RPMs, for example...how to convert the LS PCM tach output into useable form is a big question.
waypoint is offline   Reply With QuoteReply With Quote
Old 12-19-2017, 06:18 PM #6
For the money it would take to pay someone to figure all this out doesn't seem worth it.
Old 12-19-2017, 06:44 PM #7
kyle_uran's Avatar
kyle_uran kyle_uran is offline
Real Name: Kyle
kyle_uran is on a distinguished road
kyle_uran's Avatar
Real Name: Kyle
But it would be so sweet
2003 4Runner 4WD V8 - Old Man Emu 885 w/ 90000 shocks - Bilstein 5100 w/ Icon 2" - Shrockworks sliders - 255-80r17 Cooper ST Maxx - Treaty Oak Offroad 120 series recover point - Midland 75-822 - 4' Firestick - CBI passenger side antenna mount
kyle_uran is offline   Reply With QuoteReply With Quote
Old 12-19-2017, 07:40 PM #8
Real Name: Skip
Real Name: Skip
I agree and not to mention just a LS3 E-Rod crate motor will cost you more than most 4th Gens are worth and then you still have to work out ALL of the other stuff which will most likely add up to be the same as the cost of the motor, BUT you would have one very expensive but Bad Ass 4th Gen in the end, stuff like this is what "Dreams are made of"!!
2004 Limited V8
Old 05-05-2019, 09:18 PM #9
Cody01 Cody01 is offline
Cody01 is on a distinguished road
Sorry to rivive an old thread but if I lose a head gasket in my 03 like they seem known for I would rather try this route than drop $3k on just replacing gaskets. The while OHC thing with the V6s and timing belts on the V8s seems to be a pain in their later years.
Cody01 is offline   Reply With QuoteReply With Quote
Old 05-06-2019, 11:32 AM #10
ZiaMan ZiaMan is offline
ZiaMan is on a distinguished road
Timing belt for the V8 is about $500 in parts and 1-2 days labor. Cheaper and easier than a LS swap.
2008 Nautical Blue GX470
Bilstein 6112/5160
ZiaMan is offline   Reply With QuoteReply With Quote
Old 05-06-2019, 05:38 PM #11
JONBOY345 JONBOY345 is offline
JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about
Would rather see a Cummins Repower swap, imo.
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
JONBOY345 is offline   Reply With QuoteReply With Quote
Old 05-06-2019, 07:53 PM #12
Direwolf82 Direwolf82 is offline
Direwolf82 will become famous soon enough
I would think the easiest thing to do would an ls with a 4l60 and your choice of transfer case. Make up some driveshafts to convert to the Toyota diffs and start rolling. Or go all out and swap to Dana's at the same time.
Direwolf82 is offline   Reply With QuoteReply With Quote
Old 05-06-2019, 08:26 PM #13
mar5168 mar5168 is offline
mar5168 is on a distinguished road
Replacing an A750 with a transmission that has a horrendous track record in regards to reliability hardly seems like a logical solution.
A 4l80 or any 80/90 series, yes. Any 60 or 65 series, absolutely not, they're garbage.
mar5168 is offline   Reply With QuoteReply With Quote
Old 05-06-2019, 08:58 PM #14
grave's Avatar
grave grave is offline
grave has a spectacular aura about grave has a spectacular aura about
grave's Avatar
swapping your 2UZ-FE for a chevy motor? GTFO
pet every dog
grave is offline   Reply With QuoteReply With Quote
Old 05-07-2019, 07:06 AM #15
Well, I guess you can go ahead and where I said 60 just imagine I said 80, no attitude meant. Or put a trans in that if it does blow up there are many many replacements for way cheaper than the stock trans. Whichever way you'd prefer to look at it. I'd put a six speed manual in if I had a choice.
Although I personally have not had any of my Chevy friends have issues with the 60's in their vehicles. I guess it's the same as I don't know anyone who has had a v6 head gasket blow out but you hear plenty of stories of it happening.
4BT Swapped Rig PlanetExpress General Discussions 4 04-12-2016 07:44 AM
Finally swapped the rad kpinthebay 3rd gen T4Rs 11 09-13-2015 11:10 AM
Swapped my trunk lid - Need help Notsteveo 3rd gen T4Rs 3 10-28-2012 12:36 PM
Has anyone swapped a Supra V6 for a 3.0 in an 88 4R? maf49er Classic T4Rs 9 12-01-2011 04:12 PM
91 3.4 swapped 4runner hektikwon Classifieds - buy & sell (no commercial ads please) 0 08-26-2006 01:16 PM
