Old 12-26-2019, 09:25 PM #16
mechahayai mechahayai is offline
mechahayai is on a distinguished road
Originally Posted by thegame7 View Post
Good luck, I'm still chasing down a suspension/steering rattle on mine. Rattles when hitting bumps. Replaced LCA bushings and steering rack bushings with polyurethane, installed new inner and outer tie rod ends, removed the rag joint in the steering shaft, installed new uniballs in the UCAs, rebuilt the CVs with new OEM boots and grease, and installed a low mile steering rack. Next I'm doing LCA ball joints then wheel bearings as a last ditch effort. After that if the noise still isn't gone, I'm selling it
x2 on the sway bar bushing suggestion.
mechahayai is offline   Reply With QuoteReply With Quote
Old 12-26-2019, 11:00 PM #17
montijo505's Avatar
montijo505's Avatar
Originally Posted by hinmo24t View Post
dang huh?? for one wheel bearing?
Highway robbery, holy smokes!
Old 11-23-2020, 01:13 AM #18
nlau87 nlau87 is offline
nlau87 is on a distinguished road
Front end clunk
I get a front end noise going over dips or bumps. I’ve removed the skip plates and the sway bar including the links but no luck.. the sound didn’t go away and it drives me crazy. I have bilstein 5100 installed about 4 years ago and also had my LCA’s replaced about 2 years ago. Any ideas what might be the issue?
Video with sound:
Toyota 4Runner (2007 4th gen) front end noise over dips or bumps - YouTube
nlau87 is offline   Reply With QuoteReply With Quote
Old 07-18-2021, 12:31 PM #19
Dav(id)03 Dav(id)03 is offline
Dav(id)03 is on a distinguished road
Front end rattle.
Check pad retaining clips. I had a similar issue. Never had any, installed a set, like $4. Rattle gone.
Dav(id)03 is offline   Reply With QuoteReply With Quote
Old 06-08-2022, 06:55 PM #20
anna.early13 anna.early13 is offline
anna.early13 is on a distinguished road
Hey did you ever figure out what the noise was or did you sell you runner?
Sent from my SM-G970U using Tapatalk
anna.early13 is offline   Reply With QuoteReply With Quote
Old 10-28-2022, 07:27 PM #21
JerydGG JerydGG is offline
JerydGG is on a distinguished road
Originally Posted by Dirtrider216 View Post
Just today I noticed a terrible front end rattle coming from my runner and I can’t figure it out
It seems to be louder on passenger side but Audible from both sides
It happens when rolling on flat smooth pavement and bumps don’t make it that much worse
At first I thought it was my skid plates but they’re tight so I am 96% sure that’s not it
I can reproduce the sound by solidly hitting the top middle of the tire
It is definitely a metal on metal rattle but I can’t find it
From a quick check in the dark, my skid plates are tight, the brake rotor shields are tight and the exhaust heat guards are tight
Hey I know this is about 5-6 years later and not sure if this will help anyone. I do know that this was the thread I found when searching for a fix on 2010 sr5. After plenty of tightening this and that and replacing sway bar links and CV joints, It came down to the brake retaining clips on the front disc brakes. With those retaining clips gone the rods that hold the brakes in place rattle like loose change. $13.58 fixed my whole rattle on my front end. Hope this helps!
JerydGG is offline   Reply With QuoteReply With Quote
Old 10-29-2022, 11:07 PM #22
thegame7 thegame7 is offline
thegame7 is just really nice thegame7 is just really nice thegame7 is just really nice thegame7 is just really nice
Yes I removed the factory steering rack mounting bolts and replaced them with much larger grade 8 1/2" bolts. Had to drill out the stock crossmember to fit them but pretty much zero slop in the steering now and no clunks.
2007 Sport Edition V8 4WD w/Nav, JBL and rear seat entertainment, Fox 2.5 R/R coilovers, FJC rear springs with Fox 2.0 Pro series shocks, Rear ARB locker, 305/70R17 Ridge Grapplers, DT short headers
thegame7 is offline   Reply With QuoteReply With Quote
end , metal , plates , rattle , tight
Front end clunk/rattle sunapeelakers 5th gen T4Rs 1 11-09-2019 04:26 PM
Need help identifying front end rattle. SpookyMulder 3rd gen T4Rs 9 08-02-2017 03:42 PM
Mysterious rattle from the front end, Help?! California4runner 3rd gen T4Rs 7 02-21-2017 05:39 PM
Rattle in the front end Nellie 4th Gen T4Rs 0 08-02-2010 08:40 PM
Front End Rattle toy94x4 4th Gen T4Rs 0 03-20-2007 08:52 PM
