01-06-2020, 10:21 AM
P2757 dtc
Hey guys. Looking into why I'm getting this DTC. Description: "Torque Converter Clutch Pressure, Control, Solenoid Control, Circuit Performance or Stuck Off". The trans shifts smoothly and I am not experiencing any issues. Just wondering if there's any advice before I drop the pan.
01-06-2020, 01:53 PM
Real Name: Elliott
Real Name: Elliott
You could try flushing the trans fluid if you haven't yet done so. Beyond that, not much you can do.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
01-06-2020, 02:37 PM
I think that's where I'll start. Do you happen to know where this particular solenoid is located?
01-06-2020, 05:08 PM
Real Name: Elliott
Real Name: Elliott
Off the top of my head, no. I would guess it's internal, which would mean if the fluid is low or dirty it won't work right
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
