Old 01-15-2020, 12:53 PM #16
phatcheeks's Avatar
phatcheeks phatcheeks is offline
phatcheeks will become famous soon enough
phatcheeks's Avatar
I have 885/895 on my V6. I also have JBA UCAs as well. The ride is nice and smooth for me. I am running Eibach pro-truck shocks though. They are said to ride smoother over rough terrain/roads vs the bilstein, but I cannot say because I have never rode on the bilsteins before.
Also running a 1.25 spacer in the rear left to even it all out.
2004 4runner Sport V6 4x4. Eibach Pro Truck Shocks, OME 885, 895. JBA UCA
phatcheeks is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 01:42 PM #17
JoshuaZ JoshuaZ is offline
JoshuaZ is on a distinguished road
I am hoping to keep the stock UCAs, which is why I dont want a lift over 2in up front. Will the additional weight of the v8 help with keeping the 885s down? How does the weight even affect the lift?
JoshuaZ is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 03:31 PM #18
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a jewel in the rough That_Titanium_4RNR is a jewel in the rough That_Titanium_4RNR is a jewel in the rough That_Titanium_4RNR is a jewel in the rough
MY GARAGE
Real Name: Michael
MY GARAGE
If using 885s, plan on doing UCAs. Its like a 3-3.5" lift using 5100s and 885s even on the bottom clip for the 5100s. This is what I run currently. I have SPCs that can be purchased under $500 shipped from Battle Born Offroad. If you're spending crazy money on front and rear bumpers what is an extra $500 for a proper suspension component. Your stock UCA is probably worn the heck out anyways.
Titanium Metallic 2006 Limited 4WD V8 | 5th Gen Brake Swap | Slyfox AIP Bypass | TPMS Bypass | Fog Light Mod | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 03:52 PM #19
mkscrewy mkscrewy is offline
mkscrewy is on a distinguished road
i've been researching the same type of lift as the OP. i also have the V8. it was recommended to me by a rep at Wheeler to go with 5100s and the 2887 front springs (advertised as 2"-2.25") and the Wheeler T12 springs in the back. haven't pulled the trigger yet as I'm waiting until I need new tires. Just passing along info I got from a rep at Wheeler after asking the same question as OP.
mkscrewy is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 04:13 PM #20
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
if you go 3" plus in the front you also strain your CV angles upward too...
(reminded after looking at my new lifetime napa axles and how horizontal they are with the 883/895e setup for v6, 2"ish lift)
hinmo24t is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 04:35 PM #21
phatcheeks's Avatar
phatcheeks's Avatar
885s are 5mm longer than 884s. and the bar diameter is .5mm thicker. Spring rate is the same.
It will sit a tad lower with the v8. I got the 885s just in case I get a bumper in the future.
As for CV angles, mine are fine. No diff drop either.
You probably wont need UCAs for anything under 2.5" lift, but its nice to have them if you ever want to go higher and have better caster and no uca rubbing at full droop.
Old 01-16-2020, 04:48 PM #22
eleven14 eleven14 is offline
eleven14 will become famous soon enough
I'm in a similar boat. 5100s and Moog coils on now but have a front bumper enroute and the Moogs didn't quite get me the height I was after.
Based on Momo.75's build, I'm thinking I can get away with 884s (5100s set to zero) and Superflexes? He has his 884s set on the first clip but also has a V8 and DO front bumper (I'll be running the SW with no winch for the foreseeable future).
Might just get the bumper on and see where we net out. Either will move the 5100s up a notch with the Moog springs or swap front/rear entirely. Not against new UCAs but have relatively new CVs that I'd like to get some life out of. Guessing if I went with 885s, UCAs would be mandatory for road manners.
At the end of the day, looking for modest height 2.5" and level rig.
Thoughts?
eleven14 is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 05:25 PM #23
Thoughts?
they dont recommend going up from bottommost setting of 5100s with lift springs keep in mind
Old 01-16-2020, 05:37 PM #24
Thumbs up
Yup I've read that too but Momo has run that setup for years. I wouldn't go above the first clip but am trying to avoiding pre-loading a lift spring at all if possible.
And just to clarify, moving the settings on 5100s with OEM springs should be fine.
Old 01-16-2020, 05:41 PM #25
that is good to know. if i got added weight in front to go to the first one-up setting. then again considering you have to take the suspension off to lift it to that notch i might end up dropping the $150 on proper springs at that point anyway... good luck
Old 01-16-2020, 05:54 PM #26
Yeah, that's kinda where I'm at, especially with my current lack of free time.
I'm pretty set on Superflexes in back but the conundrum is what to run up front to level me out, avoid preload and support the new SW bumper.
May roll the dice and throw on 884s much to the chagrin of my credit card...
achieve , lift , rear , series , wondering
One more Bilstein 5100 front lift, 0 rear lift question. Hugo Stiglitz 5th gen T4Rs 30 02-20-2020 09:00 AM
Basic Lift Question - read all the lift info threads BXPhoto 3rd gen T4Rs 11 01-02-2017 09:34 PM
Air Lift 1000 and Lift Question - Spring Seats G8RB8_12SR5 5th gen T4Rs 4 08-24-2014 11:15 PM
quick question, do i need body lift for arb and ome sus. lift? theizzardking 3rd gen T4Rs 7 10-16-2010 12:54 AM
Wheels Question and Lift Question. K6UK Engines / Suspension / Wheels / Tires / Audio / Accessories 22 02-12-2007 11:45 AM
Copyright © 2019
