Old 12-19-2019, 02:19 PM #1
JoshuaZ JoshuaZ is offline
JoshuaZ is on a distinguished road
Lift Question
Hey, Im looking to lift my 4Runner, but still thinking it over and not ready to pull the trigger yet, but I wanted to ask some questions before I make a final decision.
What I have planned so far:
Front:
- TTAFCS-HA-0309 - Toytec/Bilstein coilovers for 03-09 4Runner(from toyteclifts)
Rear:
Bilstein 5100 Rear Shock Absorber
OME or Toytec coil springs(not sure which to choose and open to other suggestions if they are to much coil for my intended lift)
I was wondering if anyone has had any experience with these, and how adjustable it is. I really only want to do a 2f/1r lift and wondering, is it possible to achieve that with what I have listed? Thanks!
EDIT NOTE: I have a 2004 V8 Limited
JoshuaZ is offline   Reply With QuoteReply With Quote
Old 12-19-2019, 03:07 PM #2
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
5100s with ome 883/895e on 255/75/17s here:
hinmo24t is offline   Reply With QuoteReply With Quote
Old 12-19-2019, 03:38 PM #3
How much is it lifted? Hows the ride? V6 or V8?
Old 12-19-2019, 05:19 PM #4
v6, i think if you ran 884/895 (someone might want to confirm 885/895 for you) combo youd get equivalent. its like a 2" lift, maybe a bit more. keeps the cv angles happy and been a beast offroad.
Old 12-20-2019, 09:25 AM #5
I saw in the suspension faqs that the 885 is what I would want stock, and 886 if I wanted to add weight(steel front bumper?) Aslo, do your 895e give you the 1in lift or are you able to keep it at stock height?
Old 12-20-2019, 10:38 AM #6
sounds correct with your first point and the 895e is their shortest rear spring i believe. its a lift spring and cant be stock height with my setup. you dont want to use the front bilstein 5100 adjustment notches with lift springs on them by the way. leave them at the zero setting - all the lift is from the OME springs. i got everything including new kyb tophats on Amazon for around $800.
Old 12-20-2019, 12:02 PM #7
This helps a lot, thank you! I wasnt actually sure about the adjustment for the Bilstein's as I know they have around 4 different settings. And how did you know where I was gonna order it from?
Old 12-20-2019, 12:03 PM #8
amazon is whats up!
Old 12-20-2019, 02:14 PM #9
Say I got the 885/895e, should I expect around 2.5/1 - 2.75/1.5? And by adding a steel bumper later, would it possibly go down to 2-2.25/1? I want to avoid replacing the UCA and I would like to stay around the 2.5 range upfront, and keeping the rear low enough to balance out the two ends
Old 12-20-2019, 04:11 PM #10
T4R416 T4R416 is offline
T4R416 is on a distinguished road
Question... why would you do 895e in rear and not 895? With the 885 front .? Just wondering...
T4R416 is offline   Reply With QuoteReply With Quote
Old 12-22-2019, 12:31 AM #11
I want to level out the truck, and I知 under the assumption that the front will have to be lifted 2.5 in higher than the rear. And I believe with 895e vs 895 I値l get 2.5/1-1.5(895e) or 2.5/2(895) but I could be mistaken, and if the 895 is the one I should get, I値l definitely get it
Old 12-22-2019, 12:36 AM #12
Also, I never realized you put a picture on here when on my work computer 😂
Old 12-22-2019, 05:12 PM #13
Can somebody confirm ? I was under the belief that 895 and 885 go together like peanut butter and jam... but if 885/895 E is better for equal leveled than would like to know .
Old 12-22-2019, 06:59 PM #14
In my pic I have an aftermarket tire carrier and full size spare and some heavy Rock sliders and tools in cargo and I still have a little bit of rake which I don't mind but the 895 e definitely has a fair amount of lift from what I can tell. 885/895 sounds like a good combo. If no planned weight added w v8 maybe even the 884/895 or 884/895e
I didnt research a ton on the v8 it might be 885 for front more often*
Old 01-15-2020, 11:46 AM #15
Hey guys, I am back. Still havent bought the suspension yet(still gonna be some time due to some money problems that will be resolved in June) but I am still planning.
So, I've been doing research, and I know I will end up with the CBI rear bumper and tire carrier, and will decide between a Relentless Predator, Addicted Offroad Tube Bumper or CBI for the front.
What do you guys think of the 885/895 combo? I really dont want more than 2in up front, and I would like to shoot for a 2f/1r lift.
achieve , lift , rear , series , wondering
One more Bilstein 5100 front lift, 0 rear lift question. Hugo Stiglitz 5th gen T4Rs 29 11-08-2019 04:56 PM
Basic Lift Question - read all the lift info threads BXPhoto 3rd gen T4Rs 11 01-02-2017 09:34 PM
Air Lift 1000 and Lift Question - Spring Seats G8RB8_12SR5 5th gen T4Rs 4 08-24-2014 11:15 PM
quick question, do i need body lift for arb and ome sus. lift? theizzardking 3rd gen T4Rs 7 10-16-2010 12:54 AM
Wheels Question and Lift Question. K6UK Engines / Suspension / Wheels / Tires / Audio / Accessories 22 02-12-2007 11:45 AM
Copyright © 2019
