Old 01-08-2020, 01:36 PM #16
gfxcruncher's Avatar
gfxcruncher gfxcruncher is offline
gfxcruncher has a spectacular aura about gfxcruncher has a spectacular aura about gfxcruncher has a spectacular aura about
Originally Posted by rooneyy View Post
I have and I felt like I waited an appropriate amount of time for the HU to boot up but then again I might have been to anxious. Perhaps I'll connect it again and see what happens if I wait a minute or so longer.
I have double checked my crimping and connections to the T01 harness and everything is solid.
I might also note that I bought this from a friend that had it in his 5th gen, is there some flashing I need to do to the Pioneer HU to accommodate it to my 4th gen?
Thank you for your help!
Sounds like something is up, shouldn't have to wait that long for it to boot up.
Take a look here for a HU firmware update:
https://www.pioneerelectronics.com/P...port/Downloads
Check for an update on the Maestro unit too.
FWIW, even though I bought the stuff new, there were updates for both the HU and the Maestro...
Good luck!
2007 SR5 4WD Nautical Blue -- Build Thread
gfxcruncher is offline   Reply With QuoteReply With Quote
Old 01-08-2020, 04:51 PM #17
rooneyy's Avatar
rooneyy rooneyy is offline
rooneyy is on a distinguished road
rooneyy's Avatar
I appreciate it, I'll see if I can give it a try tonight! Also I think I bought the wrong kit to fill in the empty slots on the sides.
rooneyy is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 09:45 AM #18
JONBOY345 JONBOY345 is offline
JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about
Dumb question, maybe, but have you confirmed it has good power and ground?
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
JONBOY345 is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 12:33 PM #19
rooneyy's Avatar
rooneyy's Avatar
No question is a dumb question! Where would the ground be? I'd like to check.
Old 01-09-2020, 12:40 PM #20
It'd be the black wire coming out of the back of the H/U. It can either be run back to the chassis ground via the wiring harness or you can find a grounding location near the H/U behind the dash.
Old 03-11-2020, 05:57 PM #21
evan1242's Avatar
evan1242 evan1242 is offline
evan1242 will become famous soon enough evan1242 will become famous soon enough
evan1242's Avatar
Did you buy the pioneer or the maestro or both from your friend? The maestro module will need to be flashed to your 4th gen.
You won’t have to do anything to the radio itself.
Also it’s normal to have a plug or two left over.
evan1242 is offline   Reply With QuoteReply With Quote
Old 08-23-2020, 11:39 PM #22
SilverBullet01's Avatar
SilverBullet01 SilverBullet01 is offline
Real Name: Taylor
SilverBullet01 is on a distinguished road
Real Name: Taylor
was there ever an update/solution to this? curious to see the installed photos. looking at installing a Pioneer DMH-WT7600NEX and I wanted to see how the maestro is working out for you.
'05 Galactic Grey Mica sport 4.7 4WD
SilverBullet01 is offline   Reply With QuoteReply With Quote
Old 06-10-2021, 06:04 PM #23
rooneyy's Avatar
rooneyy's Avatar
Sorry for the super super late reply. I never got it to work. I still have it in a box just sitting there. I am looking to resurrect this thread and try the install again. Thinking of picking up a different harness to give it another shot:
Amazon.com: Metra TYTO-01 JBL Amplifier Interface Harness & Axxess ASWC-1 Universal Steering Wheel Control Interface: Electronics
06 Limited | 280,000 Miles
Suspension: Tacoma TRD Pro 4x4 Lift w/OME 895e rear springs | 1.25" SpiderTrax | Streetrays 1/2 aluminum spacers
Lights: Caliraised Pod Ditch Lights | Triton 40" Light Bar
Mods: Tailgate Hatch Open button | Tailgate rear window control | Raptor Lights | OrangeBoxx PSD's
8100nex , camera , factory , find , pioneer
Pioneer NEX install in ‘12 Limited zcruiser 5th gen T4Rs 33 04-15-2020 01:07 PM
Pioneer AVIC-8100NEX and trim fit 4flyer 3rd gen T4Rs 10 03-02-2017 09:13 PM
pioneer Avh-p4400bh install on 2003 limited Mbiker_101 Engines / Suspension / Wheels / Tires / Audio / Accessories 32 05-18-2016 09:08 AM
Help w/ OEM Nav (E7008) Install in 2006 4Runner Limited jthompson74 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 09-13-2011 08:28 PM
2006 4Runner Limited JBL with Pioneer Avic-Z1 Bryan1436 Engines / Suspension / Wheels / Tires / Audio / Accessories 33 09-03-2006 08:55 PM
