Old 12-21-2019, 11:20 AM #1
mijbr90190 mijbr90190 is offline
mijbr90190 is on a distinguished road
Fuel Rail Connection Popped Off 1grfe
Hey guys, last night I was going to pick up food. Getting on the highway I punched it to get up to speed. After coming to a stop we noticed an extremely strong fuel smell and smoke coming out of the engine. Didn't see any leaks so I drove it home and parked it. Didn't get a CEL. Came out in the morning to fuel all over the driveway. So I started pulling out the airbox so I could get a better look, thinking an injector was cracked or an oring was bad. No fuel residue anywhere. Started up the truck and fuel came pouring off the drivers side valve cover, onto the catalytic converter. Sourced the leak to the fitting that connects the fuel line to the fuel rail. What looked to be a black retainer clip was hanging off and the fuel line was barely hanging onto the fuel rail nipple, so I pushed it back on until it clicked and put the retainer back on. My question is what would have caused this and should I replace any of the components? My head gaskets were replace Aug 2018 and I'm wondering if they didn't put that back on properly. Any one else have this issue? Thanks.
mijbr90190 is offline   Reply With QuoteReply With Quote
Old 12-21-2019, 01:31 PM #2
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
That sounds like someone didn't push the retainer clip back on all the way and it gradually worked itself off. Scary, that could have ended very badly. Takes a lot for one that's properly installed to just fall off. To be safe, I'd run it in the driveway for a while just to make sure, maybe take a few spins around the block and check to see if you still smell something. Fuel pressure is up around 42 psi, so if that's not connected right it should be obvious. Glad you're okay.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 12-21-2019, 07:46 PM #3
Yeah, it freaked me out. Glad it didn't ignite. Lol. I clicked it back into place and tugged it a bunch without the retainer and it seemed to be tight. I put over 20k on it since that head gasket work was done and drive it hard. Just went to my buddies about 10min away and it did good, no leaks. Going to keep an eye on it and maybe wrap 2 zipties around either end of the retainer to be safe. Couldn't believe the amount of fuel pumping out with no CEL or fuel delivery symptoms.
Old 12-22-2019, 02:11 PM #4
rwelch53 rwelch53 is offline
Real Name: Ryan
rwelch53 is on a distinguished road
Real Name: Ryan
Anytime you have an opportunity to add some zipties, go for it...I'm a firm believer in the power and usefulness of zipties for the win!
rwelch53 is offline   Reply With QuoteReply With Quote
Old 12-22-2019, 03:48 PM #5
Real Name: Skip
Real Name: Skip
Zipties are the modern day equivalent to bailing wire in a mechanical situation, both of which I keep in my tool box, there are some areas/applications where a ziptie will melt but not good old bailing wire!!
2004 Limited V8
back , fuel , hanging , rail , started
Need help on fuel rail removal Pick_T4R Classic T4Rs 8 12-02-2018 05:33 PM
fuel line connection 01thunder 3rd gen T4Rs 5 10-31-2017 04:44 PM
Fuel injector replacement, fuel rail stuck? pwxford765 3rd gen T4Rs 11 08-08-2017 10:51 PM
Bad fuel leak... Injector? Fuel Rail? Clone of the Mean Classic T4Rs 3 06-20-2014 11:50 PM
Replace '04 1GRFE with Dual VVT 1GRFE airforceabbott 4th Gen T4Rs 6 12-22-2010 07:34 AM
