Old 01-07-2020, 12:02 AM #16
smokey73's Avatar
smokey73 smokey73 is offline
Real Name: Roddy
smokey73 is on a distinguished road
smokey73's Avatar
Real Name: Roddy
So no timing chains on other 4.7's. I'll likely stick to the most compatible models for a donor.
My new plan is to:
-buy used engine with ~150k miles
-reseal vc's, main's front and rear, cams
-tb kit w/water pump
-engine accessories (alt, starter, etc)
-drive it for another 300k ( give or take a 100k or so )
Meanwhile, I'll have a good core to rebuild slowly, possibly with plans for a power adder in the future.
'03 Limited V8 Toytec Ultimate 3/2.5" General Grabber ATx LT275/70 R17 Rear Grizzley locker
smokey73 is offline   Reply With QuoteReply With Quote
Old 01-07-2020, 11:05 AM #17
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
My new plan is to:
Don't forget to bypass the AIP system if the engine has it
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 01-07-2020, 08:34 PM #18
smokey73's Avatar
Real Name: Roddy
smokey73's Avatar
Real Name: Roddy
Mine is an '03, not sure what year they started that, but it was after '03.
Old 01-08-2020, 12:24 AM #19
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
2005 is when they started having the AIP for the V8s.
2004 Limited V8
Old 01-08-2020, 07:26 PM #20
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
I did a leak-down test a year or so ago when I first noticed it using oil, all cylinders were around 15-20% iirc. This is why I was originally considering just doing the top end. I believe the bottom end is in good shape, for its age. After putting a pen to it, I do believe I can swap in a junkyard engine cheaper than I can go through this one. I think I can get a pull out with about 150k miles, reseal it and do the water pump and tb for about $1000. I figured I'd be that far into my current engine with only doing the top end.
This brings me to the next question. Will a tundra engine swap in? I think I rember there being differences like the fact that the tundra and sequoia engines use a timing chain and maybe a different intake, but will they interchange? I've found several very low mileage (sub 50k) tundra engines for the same prices as the 4runner/GX engines.
Tundra and Sequoia from same year will interchange blocks. The intakes and exhaust parts do not interchange or fit. I rebuilt mine and am very happy with how it turned out, I am still driving it today. I pulled it and put in new pistons, rings, main and piston pin bearings and lightly honed the cylinders before reassembling. I will tell you that the heads are extremely difficult to set up and I would definitely have them decked and rebuilt before installing them into the engine again. And there are a ton of seals you have to change so don't flinch if the cost of the seal kit is astronomical. Mine was about 500 from the dealer.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 02-19-2022, 10:07 PM #21
smokey73's Avatar
Real Name: Roddy
smokey73's Avatar
Real Name: Roddy
I dug up this old thread I started a couple years ago. I still haven’t got around to this project (insert an excuse of your choice). I’m currently looking for another pull out and will go through it before swapping it in. My question is whether or not there is anything else I should address while the engine is out? More specifically, should I do anything with the Trans or TC? I’ve been changing the trans fluid (drain and fill, no filter) every 20k since i’ve had it and it’s never so much as missed a shift. I thought about putting a new TC in just because, since I am sitting at 310,000 miles now. I’m open to anyone’s thoughts or concerns.
engine , lot , oil , plan , pretty
Engine loud metallic engine rattle @1800 rpm after sitting in traffic protist 3rd gen T4Rs 5 08-17-2019 08:04 PM
Intermittent vehicle/engine shake and vibration with check engine light present lloydster 3rd gen T4Rs 26 09-26-2017 11:58 AM
Rough Idle, Engine Sputtering, Engine Ticking, Flashing CEL Sotovo 3rd gen T4Rs 29 04-18-2016 10:35 PM
Engine,VSC,ABS and Brake lights on, no codes, engine running rough chd2001 4th Gen T4Rs 2 04-22-2014 12:14 PM
Engine swap Question..does L6 engine fit into 1990 Hilux/4runner hjalti_gto Classic T4Rs 29 11-28-2011 09:34 AM
